10-17-2009, 11:48 PM | #1 |
Member#: 183596
South East
Vehicle:2005 WRX/9-2x Obsedian Black Pearl |
ABS light on, what sensors trigger it? wheel ABS sensor, speed sensor, what else?
Besides a ABS failure, just talking about sensors, what sensors trigger it?
I want to replace all the sensors which this goes goes to, I need to replace both speed sensors (only know where one is though, the one on the tranny, no idea of #2) and the 4 wheel ABS sensors too.. what else
10-18-2009, 10:43 PM | #2 |
Member#: 4021
Vehicle:1999 Legacy GT Ltd Quick Silver Metallic |
Next to each of your wheel hubs is an "inductive pickup". These things sense the motion of the "tone wheel" located on each of your axle joints (The ends of each axle has what is known as a "constant Velocity" or "CV" Joint). The "Tone Wheel" is basically just a small metal band of what look like gear teeth. Over time these things can rust, get bumped or even crumble in to pieces and eventually just plain fall off.
Basically when the car knows it is motion and cant get a signal from any one or more of these "inductive pickup" devices and the brakes aren't being applied it figures that something is wrong. These "tone wheel" things are cheap. I would try replacing them first if you can. If you have to replace all four CV axle assemblies then maybe they aren't so cheap after all. The ABS system functions in a nut shell by monitoring each of the four signals generated by these tone wheels and if the car is in motion, and one (or more) of these inductive pickups stops getting a signal when the brakes are applied, then the ABS assumes that one (or more) wheels have locked up and it "pumps" brakes on all four wheels very rapidly. Someone please correct me if I am spreading incorrect information. |
10-22-2009, 03:27 PM | #3 |
Member#: 32503
TXIC
Vehicle:2011 Tribeca 1995 Legacy Wagon |
Both speed sensors are on the tranny - one in the back, one in the front.
10-23-2009, 05:31 AM | #4 | |
Member#: 46248
SCIC
Vehicle:82 Brat Tan |
With the 4 channel ABS you have a sensor at each wheel that reads the wheel speed> 5 mph IIRC. If anyone of those sensors fails your ABS light will be illuminated. You will need a scanner that reads ABS to verify which one is bad. A lot of times when these lights come one there is just too much brake dust stuck to the sensor (It is a magnet) and the sensor can no longer read the exciter ring. Pull all 4 brakes and rotors and check the sensors. If one or more is full of little metal things clean it off with brake cleaner, reset battery and drive. You will know as soon as you break the 5 mph mark wether or not it is fixed. |
06-19-2010, 10:37 PM | #5 | |
Member#: 183596
South East
I'm going to trace the connector, I think it's on the sensor side and not where it plugs up into the car (hopefully.) So basically this weekend: Investigate speed sensor issue. Oil change Thermostat (may have to wait though until it comes in.) Coolant Spark plugs Spark wires (they seem okay for now so we'll see) And see why my fans don't come on properly... |
Similar Threads | ||||
Replaced wheel studs, now ABS light on...Arghh | wadejg | Brakes, Steering & Suspension | 5 | 06-29-2010 01:21 PM |
ABS light on, diagnosed with a front right ABS hold valve malfunction | C-daleRidr | Service & Maintenance | 0 | 09-04-2007 03:39 PM |
What would make this happen you think? ABS light on and chunks of metal | BoostinEJ20 | Brakes, Steering & Suspension | 5 | 07-12-2006 09:18 PM |
How hard is it to replace the speed sensor? | ski mobile | Transmission (AT/MT) & Driveline | 1 | 08-01-2004 01:41 PM |
Help...please...ABS light on and I don't know why | Cliff Ditchhanger | Brakes, Steering & Suspension | 6 | 04-16-2001 09:23 AM |
