01-21-2003, 10:58 PM | #1 |
Member#: 13736
BAIC
Hi flow cats & emissions sniffer test in NJ..
The Perrin 3" downpipe with the cat has peaked my interest. I'm worried about how my car would fare when it goes in for inspection next January. I'm not worried about visual inspection, as I intend on bringing the car to a local private shop that my family has been dealing with for over 25 years. The problem is the sniffer test. These guys are dead honest when it comes to performing and logging emissions diagnostics. I've failed the sniffer before there (w/ a previous car) and I had to reinstall my stock exhaust in order to pass again.
I already have a GReddy catback on the car. I've ordered a JDM catless uppipe, I/C hoses, and intend on getting a ECUtek reflash in the near future. I've heard good things regarding hp increases with aftermarket dp's, and I like the idea of one with a hi flow catalytic converter. On the other hand, I have no idea how competent a "hi-flow" aftermarket cat will be at performing the same function as well as the two post-turbo stock cats. Mind you also, I'm going to be working full-time and going to law school at night, so I most likely will not have copious amounts of free time to crawl under my car and swap pipes come inspection time. Your thoughts??
01-21-2003, 11:10 PM | #2 |
Member#: 21847
Vehicle:2002 WRX Sedan World Rally Blue STX#555 |
whats up man? Im getting the Perrin UP and the same DP you are considering put in this weekend, hopefully. I have wondered about the same thing, but the inspection folks shouldnt care as long as they see ONE cat under your car, which they should with the HF cat in the perrin DP. As far as passing goes, I dont think itll be a problem.
chris |
01-21-2003, 11:33 PM | #3 |
Member#: 24046
Vehicle:2007 STi, EVO, M6 E55, ML63, & Old 02 WRX. |
Chris the honest guy, hee hee. I am not too sure about the one cat solution on the downpipe. If you still have your stock downpipe and the third cat in your house, I suggest you to find sometime to install them. Did you say next January? You still have a year to go man, don't worry too much.
01-22-2003, 05:09 PM | #4 |
Member#: 13736
BAIC
alright..but all I am really asking is how well a single "hi-flow" cat will compare in its capability of reducing emitted toxins, to the two stock midpipe/dp cats?
Is a hi-flow cat just a gimmick? I mean, I care somewhat for the enviroment here. If I find out that a hi-flow doesn't perform nearly as well as each stock cat, the I'm not gonna get the dp. Anyone have any information on "hi-flow" catalytic converters? |
01-22-2003, 10:36 PM | #5 |
Member#: 12147
Vehicle:2005 g-35 ivory pearl |
I've seen highflow cats before they go into an exhaust and to me I can see why they claim to flow more air, and the other thing is that they tend to have a larger opening too.
And anyway we have awd cars.....All they can do is put the sniffer in the tail pipe and rev the engine. I can't see the car failing if it has at least a portion of the emissions system still in place. |
01-23-2003, 12:25 AM | #6 | |
Member#: 13736
BAIC
...even when there is only one catalytic converter remaining, in a system that originally called for three?... How about that Guaranteed 2 Pass crap. Would THAT help at all? |
01-23-2003, 11:18 AM | #7 | |
Member#: 11056
TXIC
Vehicle:2012 MB C250 CPO Black on Tan |
01-23-2003, 11:54 AM | #8 |
Member#: 13736
BAIC
So basically its safe to say that my car would safely pass the emissions sniffer test with only ONE "hi-flow" catalytic converter?
01-24-2003, 02:36 AM | #9 |
Member#: 13736
BAIC
bump
01-24-2003, 11:37 AM | #10 |
Member#: 13736
BAIC
anyone else??
01-24-2003, 03:56 PM | #11 |
Member#: 17885
Vehicle:2006 Scion xB 93 RB25det powered 240sx |
i love how theres 9 posts in here but not one answers your question... nasioc is great.
anyways SoLiDbReAkZ, the best thing to do in my opinion is, go get sniffed with your single high flow cat. if it fails, you have 45 days to put the stock exhaust on (no big deal) and go for a retest. my advice though is to take off the greddy muffler and put the STOCK muffler back. from what i hear, any aftermarket muffler will fail. |
01-24-2003, 11:08 PM | #12 |
Member#: 10757
Vehicle:2013 BRZ Limited 6MT DGM |
Not necessarily. When I had my Accord coupe, I had a Greddy EVO exhaust on it and a DC Sports 4-2-1 header and passed inspection without any problems. So the assumption that they will fail you just because you have an aftermarket exhaust is not necessarily true. I would just take it in and see if you pass. If you don't, then just go to a local shop and "tip" the guy really well.
Calvin |
01-25-2003, 02:20 AM | #13 |
Member#: 13736
BAIC
I AM talking abouta local shop. I failed the sniffer with a previous car utilizing a high-flow cat.....I WAS running considerably rich though
We'll have to see...I'mall for taking the plunge...just as long as my environmentalist girlfriend doesn't find out |
01-25-2003, 01:48 PM | #14 |
Member#: 17885
Calvin, i know they used to allow aftermarket exhausts as long as they passed teh sniffer test. but recently, as in just started enforcing it, i've heard that you need to have the stock muffler in place (just the rear section)
01-25-2003, 01:55 PM | #15 |
Member#: 1581
Vehicle:MY00 RS/STi7 MY01 RS Both Silverthorne |
How much is the Perrin DP with cat?
01-25-2003, 02:21 PM | #16 |
Member#: 13736
BAIC
About $569 from Nino.....that price INCLUDES gaskets.
01-25-2003, 06:02 PM | #17 | |
Member#: 10757
Calvin |
01-26-2003, 11:58 AM | #18 |
Member#: 21847
Couldnt you put an MBC on in like 5 min. drive to take you test with it running a bit lean? then let them test it?
chris |
01-26-2003, 12:20 PM | #19 |
Member#: 13736
BAIC
Can some one just stick the sniffer to the pipe and run a test for us....or does every test HAVE to be logged and transmitted to Trenton?
I mean, Chris...you're getting both the up and down installed. If a guy is willing to do a test (obviously not counted) to see how it fares...wanna split the cost? |
01-28-2003, 01:48 PM | #20 |
Member#: 13736
BAIC
Can a sniffer be donw without having to send the results to the state?
01-28-2003, 05:10 PM | #21 |
Member#: 25413
WILL SOMEONE PLEASE JUST ANSWER THE QUESTION?? =D
01-29-2003, 02:00 PM | #22 |
Member#: 13736
BAIC
yeah..does ANYONE know??
01-30-2003, 02:14 AM | #23 |
Member#: 13736
BAIC
hmm..I guess not.
01-30-2003, 02:20 AM | #24 | |
Member#: 14732
SWIC
01-30-2003, 02:26 AM | #25 | |
Member#: 14732
SWIC
Hi Flow Cat that PASSES CA smog test? | cppchrisdh | Southern California Impreza Club Forum -- SCIC | 8 | 01-14-2007 11:56 PM |
MRT Downpipe with Hi Flow Cat stainless steel NJ | handyman28 | Private 'For Sale' Classifieds | 17 | 10-13-2005 10:54 PM |
hi flow cat up+dp+catback+cobb accessport=emissions?? | BriSalig | Newbies & FAQs | 5 | 07-09-2005 06:35 PM |
Emissions and hi-flow cat converters | mrpedal | Normally Aspirated Powertrain | 1 | 07-02-2005 09:24 PM |
Brullen Headers & Hi-Flow Cat | jdsimpreza | Normally Aspirated Powertrain | 6 | 12-12-2001 12:02 AM |
