08-01-2014, 01:03 PM | #2901 |
Member#: 231489
Thank you. After having this car for 12 years and watching it evolve from a daily (1 year) to a more dedicated autox car (6 years), to a test mule, etc....we decided to put together a few items that we've talked about for a long time. We're happy with the way the car performs on the dyno as well as on the street and testing out a 2.0 liter was refreshing, because we do so many 2.5 liter cars at our facility. We look forward to finishing a few items and getting it out on track asap!
08-03-2014, 12:26 PM | #2902 |
Member#: 116797
South East
Borg Warner Registry, post your BW setup & #'s here.
BW EFR 7163 /w medium wastegate actuator
Event: Dyno pull/tuning session Location: Performance Race Solutions, Sanford, FL. Ambient Temp: 90 Elevation: approx 100 ft. Weather: Hot Wheels/Tires: 235/45/17 Car: 2004 WRX STi Mileage: 130k on engine Tuner: Mike @ Mtuned Dyno Info: Mustang Peak HP at RPM: 327whp Peak Torque at RPM: 321wtq Target Boost: 19psi Target AFR: 11.1 Fuel: 93 unleaded Tranny: 04 STI 6spd Engine/Power Modifications: 2.5l ej257 stock block motor, Perrin Equal Length Header, Full Race catted down pipe and uppipe, Maddad Whisper 3” exhaust, DW 1000cc injectors, APS 65mm/K&N filter, Perrin 3" turbo inlet, Cobb Afta Maf, GrimmSpeed EBCS, Walbro 255lph fuel pump Software: Cobb Last edited by Ravel36; 08-06-2014 at 03:14 PM. |
08-04-2014, 02:08 AM | #2903 |
Member#: 15445
E. Canada
Vehicle:1986 Leone STi EJ22T JDM White |
EJ22T, V9 Spec-C DOHC heads, ViPec, Full Race Twin scroll kit & Airworks S300SX FMW.
American Pump 93 (21psi for now), if it was Canadian gas 94 = 400hp |
08-04-2014, 12:24 PM | #2904 |
Member#: 133386
SWIC
Vehicle:00 too many turbos white |
Ravel36 - What gear was that dyno pull in, and which WG actuator are you using?
NICO Turbine - I was telling a friend about this car the other day, absolutely love it!! |
08-04-2014, 12:46 PM | #2905 |
Member#: 116797
South East
08-05-2014, 11:07 PM | #2906 |
Member#: 15445
E. Canada
08-05-2014, 11:29 PM | #2907 | |
Member#: 208971
NWIC
Vehicle:2003 WRX sedan |
08-06-2014, 12:42 PM | #2908 |
Member#: 123978
NWIC
Vehicle:3in1 04/06/08 STi 'Identity Crisis' |
Thanks Geoff and Bigreteric, I appreciate the input!
Sent from my iPhone using NASIOC |
08-06-2014, 04:38 PM | #2909 | |
Member#: 45640
NESIC
Vehicle:2012 WRX STI blue |
any videos? youtube that badboy
08-06-2014, 04:41 PM | #2910 |
Member#: 330625
NESIC
Vehicle:2006 WRX WRB |
Low end seems really weak on that dyno for a 7163. Going to just blame it on the dyno operator though setting the pull duration too short and starting at 3k rather than 2k.
08-06-2014, 06:55 PM | #2911 |
Member#: 116797
South East
08-06-2014, 06:58 PM | #2912 | |
Member#: 116797
South East
Possibly, I wouldn't know. But drivability is great, boost comes on strong once the turbo starts to spool. I have only hit 19psi once in a third gear pass, I had to grip the steering wheel pretty hard because you can fill the chassis twist when the boost comes on crazy, but awesome. Puts that ear to ear grin on your face. |
09-17-2014, 01:26 PM | #2913 |
Member#: 231966
VIC
Vehicle:2003 WRX Pure Silver Metallic |
Maybe i missed them, but is there any EFR6258 dyno numbers on a 2.0L in here?
fwiw my motor is the usdm 2003 WRX variant. I'd like to get a sense of the general characteristics related to spool for this turbo, on this motor. When is peak poost? how steep is the curve, etc etc. I suppose a dyno plot would be ideal. Thanks! |
09-17-2014, 01:31 PM | #2914 | |
Member#: 133386
SWIC
evans-tuning.com in PA did 2 identical cars (WRX 2.0L) with stock motors and identical setups except 6258 vs 6758 was the only difference. same engine setups, same dyno, same timeframe. this is the first stock location EFR kit this tuner has done, he said "that 6758 turbo is awesome. Seriously. I am impressed" EFR6258 on stock EJ20 longblock, 93octane pump gas @22psi from Evans-Tuning: EFR6758 stock EJ20 longblock, 93octane pump gas @22psi: both of these setups have the soft "mid boost" wg actuator, since they are 93 octane pump gas builds only. I recommended to install the stiffer wg spring and check back edit: subiefest is this weekend, we are doing a big sale on these subaru EFR setups - and free ride alongs from Mark Jager at the event for anyone who can make it Last edited by Full-Race Geoff; 09-17-2014 at 04:12 PM. |
09-17-2014, 02:04 PM | #2915 |
Member#: 231966
VIC
Looks like the quicker spooling 6258 would be more up my alley.
How would the 6258 graph look with the if it was the 0.64 A/R IWG option? Sorry, i don't understand enough about EWG/IWG to know what that would mean. The subiefest sale is one reason i'm here looking for more data. I appreciate you guys having a meaningful sale, not just "save $50 on our kit!" |
09-17-2014, 02:17 PM | #2916 |
Member#: 133386
SWIC
6258 0.64 a/r IWG is exactly the setup shown in the top graph - it is a great performing setup that spools earlier than stock and delivers a broad powerband. Mark Jager ran that turbo in his street class time attack car previously with excellent results
09-17-2014, 02:20 PM | #2917 |
Member#: 231966
VIC
you mean it spool earlier than stock (VF39) right? ... i'm currently running a stock TD04 @ 19lb for reference.
09-21-2014, 02:41 PM | #2918 | |
Member#: 239278
I'm in the process of building my engine with a 83/74 1.05ewg. I like the sound of my blitz bov and was willing to go raceport bov. So, I'm wondering if anyone tried to run the EFR turbo with and WITHOUT external BOV.. did you lost lot of response/transient spoolup ? ( I'm mainly wondering how effective if the internal BOV actually) I'm running a haltech with map based. thanks guy! |
09-21-2014, 10:27 PM | #2919 |
Member#: 330625
NESIC
I only run the internal BPV, it makes the engine bay much simpler and saves weight.
09-21-2014, 11:28 PM | #2920 |
Member#: 116797
South East
I also only run the internal. I have never had an external so I have no real world experience with them, but fwiw the high boost WG actuator with my 7163 works perfectly. I have my set up posted here.
09-22-2014, 12:38 PM | #2921 |
Member#: 179846
NWIC
Vehicle:07 STi Limited EFR 8474 TS EWG |
I had tial 50mm, and I switched to internal efr bov now when I shift I get instant 5-10 psi in next gear
09-22-2014, 04:05 PM | #2922 | |
Member#: 239278
I.E: With the internal BOV, if you can get instant transient response of 5-10psi and with external, you get an instant 5-7psi. I'm willing to accept this performance drop. However, if by going external, you loose 100% of the transient response then its not worth it. Thanks for your help! I read lots of your threads but never post |
12-04-2014, 04:41 PM | #2923 |
Member#: 231489
Event: dyno pull
Location: Innovative Tuning, Buffalo NY Ambient Temp: 51 degrees Fahrenheit Elevation: 620 feet above sea level Weather: wet Tires: Dunlop Direzza Car: 2007 Subaru Forester XT Sports Tuner: Mike @ Innovative Tuning Dyno Info: Mustang AWD dyno Transmission: 2005 USDM STi gearset Gear: 4th Peak HP at RPM: 513@6000 Peak Torque at RPM: 479@4850 Baseline hp/tq for a stock on same dyno: 08 STi = 240 hp Target Boost: 26.5psi Target AFR: varies with boost Fuel: E65 Ethanol Engine - 2.5L stock nitrided crank - JE Pistons - Manley Turbo-Tuff rods - ARP head studs - B25 heads with all stock valvetrain/cams - competition-style valve job/lash -custom catch can with -12/-10 provisions Fuel System -Walbro E85 400 pump -Injector Dynamics top feed ID2000 injectors -Fuel labs 10 Micron in line fuel filter -Russell fuel filter -Fragola -8 feed, -6 return -Moore Performance fuel rails -Aeromotive A1000 EFI bypass regulator -composite TGV's into flipped LGT manifold Turbo and Exhaust -BorgWarner EFR/Airwerks hybrid - 57mm FMW - equal length twin-scroll header and up-pipe with custom T4 adapter -twin Tial 44mm wastegates -Perrin 3 Port Electronic Boost Controller -full 3.5" exhaust with flowmaster canister-style 3.5" muffler Intake system -4” intake to turbo -Green Filters cone filter -Tial 50mm Q Blow off valve -Custom double-pass intercooler with Bell 4" core -3" out, 2.75" in intercooler piping with Tial BOV Calibration -Cobb Accessport v2 - full SD mode -AEM 3.5 bar MAP sensor -GM fast acting IAT sensor -JDM STi Gauge pack (made by Defi, boost, oil pressure, Oil temp) -Defi Gauge suite -Zeitronix Ethanol Content Analyzer -JDM Forester STi instrument cluster |
12-07-2014, 11:20 PM | #2924 |
Member#: 96204
W. Canada
Vehicle:2013 STI GR White |
I tested the proto-type Turbosmart 2-port IWG actuator on my EFR6758. It worked great, should be the actuator that comes with the BW turbos IMO.
You can read more here: BW B1 Turbosmart 2-port IWG actuator |
11-13-2015, 09:45 PM | #2925 |
Member#: 243992
Vehicle:2006 WRX TR WRB |
Just purchased a BW SX-E 8376 for my 06 WRX. deciding on hot side right now. I have a few options.
.63, .70, .88 T3 open depending on who it's from .88 T4 open .91 T4 divided. With a spool valve, and if the spool valve deems not good on our platform, twin scroll. Leaning toward the .91 divided. |
"Official" Post your suspension setup and settings thread. | ScreaminFast | Brakes, Steering & Suspension | 19 | 09-14-2011 09:59 AM |
Post Your Winter Setup in here. | car_cursed | Member's Car Gallery | 43 | 10-26-2008 01:12 PM |
Post your Exhaust setup. | Teh Legacy | Legacy Forum | 32 | 06-24-2005 03:44 PM |
Post your room setup here. | file_id | Off-Topic | 26 | 04-15-2004 12:03 AM |
Post your SM setup!!! | Davenow | Motorsports | 66 | 01-10-2004 03:12 PM |
