08-14-2011, 03:03 PM | #1 |
Member#: 209473
South East
Vehicle:06 sti on effanolz Juantuned |
Beta Testing Maperformance Ball Bearing Billet 20G 430whp- Juan Tuned
Event: Road Dyno
Location: Simpsonville, SC Ambient Temp: 90 Elevation: 1000 Weather: clear Track and Conditions: asphalt, clean, flat Tires: 225/45/17 falken ziex Car: 06 WRX Sti Tuner: Juan Medina Dyno Info: Virtual Dyno and Airboy Transmission: 6spd Gear: 4th VD-Peak HP at RPM: 430whp @ 6897 RPM VD-Peak Torque at RPM: 409wtq @ 4509 RPM Peak HP at RPM: 400whp @ 6680 RPM Peak Torque at RPM: 377wtq @ 4500 RPM Baseline hp/tq for a stock on same dyno: 215whp Target Boost: 25psi Target AFR: 11.5 Fuel: E85 Engine/Power Modifications: Maperformance BB Billet 20g 8cm2, DeatchWerks 1100cc side feed injectors, Perrin v2 fuel rails, full 3" TBE, injen catted downpipe, Borla Hush CBE, Hallman MBC, air intake shield, Walbro 255, TGV deletes by Juan Medina, 70mm APS CAI, APS hard inlet, GT Spec gen 2 headers/uppipe, Grimmspeed PnP intake manifold, 11 STi TMIC Driveline Modifications: ACT HD SS. Suspension Modifications: tanabe gf 210 springs Other Modifications: Gruppe N motor/transmission mounts, pitch stop, ss brake lines, wrx trunk swap I decided to go big this time and see if I could get 400 whp out of the stock block conservatively and maintain my sneaky daily driver. Juan was down with the plan from day 1 and helped a ton to reach that goal. Upgraded from Blouch 18g to Maperformance 20g, 70 mm APS CAI from homemade CAI, APS turbo inlet from stock, 2011 sti tmic from 06 STi TMIC, GT Spec gen 2 headers/uppipe from stock. This goes with 1100cc DW injectors on e85. The tune is great, turbo has great spool and the car feels super smooth. Even idle and start up are nice and consistent. Power is great and immediate, numbers indicate that it makes more power every where than my 18g. The car was tuned in Hades and now that the weather is cooler, it is getting even stronger. Huge thanks to Juan and Tyler for all the help, it was definitely worth it! week old learning view best pulls in better conditions.
08-14-2011, 03:05 PM | #2 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
this car is sick, it turn out awesome the response is amazing. It hits torque kind of late because is catted. Yes it has a CAT . But if you look at 3000rpm it makes more power than some VF39s on E85.
The turbo also sounds sick, here is a crappy video but you get the idea. This was on low boost 20-21psi Huge thanks to Maperformance for letting me test this turbo, you can't beat the performance of this turbo for the money. Last edited by juanmedina; 08-15-2011 at 06:44 PM. |
08-14-2011, 03:28 PM | #3 |
Member#: 134211
very nice..been thinking of getting this unit or the 1.5xtr, they are similar in power but a big price difference....
08-14-2011, 04:46 PM | #4 |
Member#: 64511
SCIC
Vehicle:2003 WRX sedan |
This Internal wastegate?
08-14-2011, 10:08 PM | #5 | |
Member#: 133146
Yes sir is IWG, I don't see a need to waste money in EWG setup. Rusell the OP is suppose to get a 4 bar OMNI sensor this week. I will post high boost plots as soon as we get it. At lower boost setting it holds boost all the way and the delivery is very smooth. On the virtual dyno graph the red line is his blouch 18g 7cm2 on E85 , you guys can see there is gains every where. Like I said before no turbo will beat this power band. Last edited by juanmedina; 08-14-2011 at 11:23 PM. |
08-14-2011, 11:21 PM | #6 |
Member#: 81102
South East
I hate this tuner, he is the worst tuner ever...
BWAHAAHHAHA! |
08-14-2011, 11:23 PM | #7 |
Member#: 133146
haha I want my popcorn back carmi
08-15-2011, 12:01 AM | #8 |
Member#: 156247
Vehicle:14' Flex Fuel FXT 15' Flex Fuel WRX |
Slow ! Lol
08-15-2011, 06:27 AM | #9 |
Member#: 139385
good job Juan
08-15-2011, 09:20 AM | #10 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
we need to frumrol!!!
looks good |
08-15-2011, 09:26 AM | #11 |
Member#: 81102
South East
08-15-2011, 11:15 AM | #12 |
Member#: 82146
South East
Vehicle:2005 Legacy GT OBP |
Pump numbers ???
08-15-2011, 01:14 PM | #13 |
Member#: 133146
haha I know
thanks Matt shifting and filming is kind of hard, sure Fuji I have no pump numbers but I would think you can make 370-380whp Dyno Jet with 100-200rpm later spool. |
08-15-2011, 01:14 PM | #14 |
Member#: 64511
SCIC
That's awesome for IWG, rock steady at over 20psi. Definately going to be looking into this turbo once my motor finally dies. Nice to have IWG and a "stockish" turbo sitting there for CA smog inspection.
08-15-2011, 05:03 PM | #15 |
Member#: 268737
Vehicle:2005 STI |
I like
08-15-2011, 05:17 PM | #16 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
im sure the boost is solid with the hallman, but the boost curve plotted is not the actual boost curve....the stock MAP sensor pegs ~23.5 psi....thats why its a flat line at 23.5 psi
08-15-2011, 06:04 PM | #17 | |
Member#: 133146
At 20psi and 17psi the drop on boost from peak to redline is <1psi |
08-15-2011, 06:06 PM | #18 |
Member#: 36033
SCIC
08-15-2011, 06:44 PM | #19 |
Member#: 133146
08-15-2011, 09:12 PM | #20 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
Great job tuning Juan! These MAP turbos seem pretty nice. They deff have my eye...
08-17-2011, 01:50 AM | #21 |
Member#: 34519
South East
Vehicle:03 WRX WRX blue |
How much is this turbo and can you use the stock inlet?
08-17-2011, 02:24 AM | #22 |
Member#: 36033
SCIC
08-17-2011, 02:40 AM | #23 | |
Member#: 164830
SCIC
Vehicle:2002 WRX G61 III OVE 58e |
08-17-2011, 12:38 PM | #24 |
Member#: 155930
Vehicle:2008 WRX Josh Tuned VF39+JoshTune=330hp/350tq |
i will be getting on around tax time, thanks for these videos and results you have set my mind for me!
08-18-2011, 10:59 AM | #25 | |
Member#: 133146
$1200, if you modify you hard lines and get the braided oil line with the restrictor for GT30r it will come out to about $1270. It is a great deal when ball bearing turbos out last journal bearing and also when hybrid ball bearings (ceramic cartridge) out last regular ball bearing by 3 times their life per my work experience. I have an update for later , we installed the OMNI 4 bar sensor so I will post boost plots tonight or tomorrow. We also gained quite a few wtq and whp at 3000rpm an at redline thanks to better weather . We are going to try to run a little more boost also.... |
Similar Threads | ||||
FS/FT : PT 6262 ball bearing & Billet Turbo | oldman_sti | Engine/Power/Exhaust | 7 | 09-13-2011 10:25 PM |
MAP Billet Ball Bearing Bolt-on Turbocharger Dyno Results Are In!!!!! | maperformance | Proven Power Bragging | 85 | 07-27-2011 12:58 AM |
PTE Billet Turbochargers.. IN STOCK! Journal and Ball Bearing! | Built Industries | Engine/Power/Exhaust | 2 | 08-24-2009 02:08 PM |
