05-23-2006, 07:41 PM | #1 |
Member#: 111520
NESIC
Vehicle:2004 STi black pearl |
Help: Clutch Install and Turbo Install
Hey Guys,
Im looking for someone who can help me out. I have a '04 STi and I need a exedy twin plate and fpred turbo installed. If anyone can do this for $250 cash let me know. Please only offer your help if you have done a couple of these installs before. BTW I am currently running the FP 20G with 3" so the FP Red would be a direct bolt on. Please pm me if your able to help me out Preferably someone in MA/RI area. Thanks in Advance!
05-23-2006, 08:15 PM | #2 |
Gone... But not forgotten
Member#: 50895
NESIC
Vehicle:. www.48hrs.info donation chairman |
500 total for both, good luck with that
side note, what are you doing with the 3" green? |
05-23-2006, 09:07 PM | #3 |
Member#: 97841
NESIC
Vehicle:2005 STI Race Ready OBP/Orange |
FPRed install, hummm... You may need to delete the TGV's in order to fit it. Otherwise, the turbo may hit the TGV motor. Also, you will need EM to turn off the CEL once TGV is deleted. Otherwise, it should be pretty easy to install.
The clutch is going to be a little PITA to install if you don't have a lift. It can be done without it, but lot of work. Good luck finding someone to install with that price you offered. |
Install Help: Steering Rack and Front Sway Bushings | Daedalus | Brakes, Steering & Suspension | 4 | 03-21-2010 12:04 PM |
Uppipe and turbo install Q | andrew3776 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 5 | 02-24-2010 08:45 PM |
Clutch kit and flywheel install-Who do you recommend? | ammo0000 | Rocky Mountains Impreza Club Forum -- RMIC | 7 | 02-18-2010 09:07 PM |
DIY Injector and Turbo install good idea or no? | Kraziken | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 04-01-2008 01:48 PM |
Clutch slipping and turbo install/tune is this weekend!! | MK2TMR2 | Texas Impreza Club Forum -- TXIC | 8 | 03-28-2005 05:53 PM |
