11-08-2004, 12:43 PM | #1 |
Member#: 29355
NWIC
Why does the stock tow hook say "only for use when towing"?
i see a lot of cats running around with JDM style and their tow hooks screwed in... why is this advised against? what could be bad about it?
11-08-2004, 01:46 PM | #2 |
Member#: 5887
BAIC
Vehicle:2002 GDAA (bugeye) 797 (blaze yellow) |
From one engineering point of view, imho the tow hook was designed specifically for towing (obviously). But what that also means is that other analysis of the vehicle (e.g. bumper design for frontal & offset crash requirements) are not done with the tow hood attached. Instead of not placing that warning and having to reissue a redesigned tow hook that does not affect other factors for example, it would be better to be safe on the legal side by stating the obvious.
A related example would be the tow hook that was standard in USDM MY1995 Impreza (& perhaps older models), which was a fixed hook accessible under the bumper cover. It was later found out/ believed / suspected that it is possible to deploy the airbags if the tow hook, which is somewhat lower than other components in the front underbody side, hits a massive enough object on the ground. As a precaution, they had to issue a recall in which the tow hook was trimmed off, and a replacement sticker was given showing an alternate method of towing using front suspension components. I'm not saying that this is the reason for the warning, but surely stating that the tow hook shouldn't be attached unless while towing would reduce the need fo such warranty/precautionary corrections. my 2 cents |
11-08-2004, 06:55 PM | #3 |
Member#: 73196
Vehicle:2002 WRX Cobb Stg2 2003 Sil/Blk R1 |
could it have something to do with you definately causing damage to anything you hit?
i mean bumpers work ok when you both have them but if a metal hook is smashing into something with the full inertia of the car...you are going to break something!!! |
11-08-2004, 08:44 PM | #4 |
Member#: 71058
Vehicle:2005 2.5RS Wagon Regal Blue |
The owners manual for my 2005 RS wagon states clearly that leaving the tow hook in will interfere with the sensors for the airbag system. "The owners manual is your friend"
11-08-2004, 08:52 PM | #5 |
Member#: 42402
Vehicle:- Finder of Porn -Bringer of tears... |
i screwed an 8" steel spike into my tow hook hole
11-08-2004, 08:54 PM | #6 |
Member#: 5201
NWIC
Vehicle:'02 WRX Wagon '11 Versys 650 |
Because it's a tow hook, duh. But as others have stated, it affects the crashworthiness of the vehicle, and it's possible it could vibrate out going down a rough road.
Who's making the folding tow hooks for front bumper/beam | skimobile | Motorsports | 3 | 11-09-2007 09:47 AM |
Towing another car using the rear tow hook? | athakur999 | Newbies & FAQs | 5 | 12-14-2006 09:28 AM |
Why does the member's list at the bottom say 84,000? | e11ys | General Community | 19 | 08-27-2005 06:16 PM |
Why does the stock system suck so much???? | Hassassin | Tri-State Area Forum | 24 | 04-25-2003 01:13 PM |
Why does the WRX wagon cost more in UK when in the US the wagon is cheaper? | Hyudra | General Community | 10 | 01-29-2003 09:27 PM |
