01-17-2015, 11:10 PM | #18076 |
Member#: 344260
NESIC
Vehicle:2009 Impreza OBS Sage Green |
Call me crazy but i think the crawford eco-block made my car sound better, so far it has met my mpg expectations....
01-18-2015, 12:29 PM | #18077 | |
Member#: 141373
E. Canada
Vehicle:2022 Crosstrek Sport 6MT |
The noise starts to bug me though, especially after I noticed - to my astonishment - that my Hakkas R2 are significantly more quiet, despite being a winter tyre. |
01-18-2015, 09:56 PM | #18078 |
Member#: 383680
Vehicle:2008 Impreza 2.5i Newport Blue Pearl |
So that chip in my windshield that I had repaired a month ago just couldn't handle the weather. Turned into a nice crack just about the entire length horizontally -_-
Woo. Could be worse though. At least I'll have a brand spankin new windshield. |
01-19-2015, 01:00 PM | #18079 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
Any of you guys run into this problem?
http://forums.nasioc.com/forums/show....php?t=1846211 I installed a sub yesterday and the car stalled on the way to work this morning. I'm concerned but it's got a lot of the same symptoms as when the ECU is reset and learning. Only difference is that it started up on the first try. |
01-19-2015, 01:05 PM | #18080 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
^ Check your battery. My car would do this and my battery was 7 years old. Put in a Optima Yellow Top and no more problems.
01-19-2015, 01:35 PM | #18081 |
Member#: 146287
BAIC
No problems getting started though. I do have quite a bit of corrosion that I need to clean off that isn't helping.
01-19-2015, 01:47 PM | #18082 | |
Member#: 262503
I didn't have a problem getting started either but the battery can't take the extra strain of an amp. I would notice if my head unit was really quiet, one of my amped speakers would start to cut in and out because my battery didn't have enough power. What battery do you have? |
01-19-2015, 01:54 PM | #18083 |
Member#: 146287
BAIC
The original one from 2009.
01-19-2015, 03:28 PM | #18084 | |
Member#: 339342
Vehicle:2009 Impreza 2.5i Silver |
Last time I disconnected my battery my idle speeds were completely screwed until I did this. |
01-19-2015, 03:49 PM | #18085 |
Member#: 146287
BAIC
Battery was disconnected. I've reset my ECU before... I don't recall the steps being that intense. But that sounds like a good possible solution. I'll give that a shot later.
Update: Reset the ECU (kinda half-assed it) and I cleaned up the corrosion (something I've been meaning to do for a long time. The crap ate the anno off my SPT tie down. ). Car seems to be running much better now. I went driving three times today and it died all three times. Went out after the reset and it didn't die. Idle still kinda sucks though. :/ I think that will sort out over a couple of days like it has in the past. Stupid ECU. Update 2: Didn't fix it. Died on the way to work. Last edited by JourdanWithaU; 01-20-2015 at 11:04 AM. |
01-20-2015, 01:28 PM | #18086 |
Member#: 411198
Vehicle:2008 2.5i Silver |
hey guys, just bought rear spats for a 2008 wrx for my 2.5i and i dont have notches in my rear bumper were the spats suppose to go?? any help has anybody ever done wrx rear spats on a 2.5i??
01-21-2015, 11:37 AM | #18087 |
Member#: 366085
RMIC
Vehicle:2010 Impreza 2.5i PE DGM |
08 2.5i
Damn it's been a long time since I've posted on here lol. Anyone know for sure if a 2010 Forester climate control unit would work with my 2010 Impreza? I know it won't fit with my dash trim. Just wondering if I can plug it in and have it work.
This is what I'm looking at specifically: http://m.ebay.com/itm/like/400747349...rue&rmvSB=true |
01-21-2015, 11:47 AM | #18088 |
Member#: 262503
^ If you have analog controls then no.
01-21-2015, 07:01 PM | #18089 | |
Member#: 236305
Vehicle:2009 2.5i 4dr 5spd Newport Blue Pearl |
I'd be interested to see if resetting ECU with those exact procedures in that post help. I think there's a "complete cycle" that the ECU does when learning again after a reset, and car won't run at it's best until that happens, and a complete cycle consists of a lot of different parameters than might not happen for a while in daily driving. Like going past a certain fuel level in tank, and then certain lengths of trips, and other seemingly unconnected things. I would bet if you disconnect battery, reconnect it, fill up the car gas tank, and then run it till almost empty, and then refill it again, it will be running right again. ++++++++++++++++++++++++++ BTW- to all you people complaining about my post (and I don't care) about "putting someone on blast" (which I have never even hear of), I was just warning you all that the guy was acting flaky and to be on alert if buying something from him. It has nothing to do with responding to a PM, it has to do with stopping all communication in the middle of a deal and disappearing for months, only to return to try to sell more stuff in this same thread.. Last edited by BWX; 01-22-2015 at 02:24 AM. |
01-21-2015, 08:27 PM | #18090 | |
Member#: 395987
TXIC
Vehicle:2008 Impreza 2.5i Dark metallic grey |
Sent from my SAMSUNG-SM-N910A using NASIOC mobile app |
01-22-2015, 02:41 AM | #18091 |
Member#: 146287
BAIC
The car seems to be running normally now. It died once after the reset. Not repeatedly like it did before.
That dealer update sounds like a scam. |
01-22-2015, 03:45 AM | #18092 |
Member#: 411558
W. Canada
Vehicle:2005 Impreza Silver |
What exactly does the (i) stand for? I have just been starting to like Subaru's this year and where I am from (Alberta, Canada) AWD would just make a lot of sense. I am having a problem trying to figure out the difference between the Impreza models. Could you tell me what the Impreza 2.5i sport is? and what is the difference from an RS, STI, WRX, TS? I usually use autotrader or kijiji and when i search Subaru Impreza there are alot of different models.
01-22-2015, 09:51 AM | #18093 |
Member#: 141373
E. Canada
http://lmgtfy.com/?q=Impreza+2.5i+sport#
www.cars101.com - all the info is there. Also, keep in mind that the suffixes depend on the impreza generation |
01-22-2015, 12:06 PM | #18094 |
Member#: 301247
Vehicle:09 Impreza 2.5i MT White |
my favourite mod is ecu flash. can't imagine going back to stock. adding a bit of fuel in lower rpms and reducing some on top and adding timing everywhere transformed my car. the biggest gain is ofc throttle response. I wasn't expecting much gains but gains are gains xD
virtual dyno results http://oi58.tinypic.com/2hr3cpf.jpg Last edited by Pickler; 01-22-2015 at 08:40 PM. |
01-22-2015, 12:27 PM | #18095 |
Member#: 146287
BAIC
Interdasting...
Is that on the AT or MT? Does the transmission make a difference? |
01-22-2015, 08:40 PM | #18096 |
Member#: 301247
AT or MT doesn't matter. 2010 or older is defined for opensource.
01-23-2015, 07:46 PM | #18097 |
Member#: 229726
Vehicle:'09 2.Slow OBP |
So, I've had my TPMS light on for probably over 2 years now since I've been too lazy to get them put it in and finally did them today.
It feels weird with no lights on my dash. I feel like something is broken now. |
01-23-2015, 08:25 PM | #18098 |
Member#: 146287
BAIC
Don't worry. The light will come back eventually. The sensors don't last forever.
01-23-2015, 09:48 PM | #18099 |
Member#: 262503
Just an FYI for you guys.. Any time you disconnect your battery.. You need to turn the key to "ON" for a few seconds. And then start the car. I believe this is in the owners manual also.
When I installed new speakers, and then an amp and head unit.. I stumbled across this. |
01-24-2015, 06:30 PM | #18100 |
Member#: 344260
NESIC
Does anyone have a grounding kit they recommend? Was suggested to do the add-on.
Other work that needs done: All 4 rubber transmission lines Stabilizer links Key item noticed: 1 1/2 inch segment along cylinder head where there is mosture |
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
