Tire & Wheel Forum sponsored by The Tire Rack |
07-28-2012, 02:42 PM | #1 |
Member#: 41877
Vehicle:02 wrx WRB |
245/40/17 on 17x9 on bugeye
I'm looking at a set of Rota Grids in 17x9+35 offset. I'd probably go with a 245/40/17 tire. I'm lowered a bit. Just about 1.5-1.75 inches on Prodrive springs. Could I get away with not doing any fender modification with factory camber on my 2002 WRX?
07-28-2012, 02:54 PM | #2 |
Member#: 72891
Vehicle:2018 STI 99 2.5RS 2dr - 2017 XV |
You will need to mod the rear quarters. If they were in the +42 range you could get away with rolling the rears flat. I think a +35 would need some more camber in the rear or a little pull and roll.
07-28-2012, 03:12 PM | #3 |
Member#: 41877
What are shops charging nowadays for pulling and rolling? I can find these in a +48 offset too.
07-28-2012, 03:42 PM | #4 |
Member#: 175334
TXIC
Vehicle:2003 Impreza WRX JDM v8 EJ207 WRB |
This is my bugeye with 17x9 and 245/40/17s. Offset is +44, and I haven't had to roll fenders. At +35, I'm pretty sure you will, but it also depends on your suspension setup.
07-28-2012, 04:02 PM | #5 | |
Member#: 41877
What's your suspension setup Torquey? Last edited by m4r10; 07-28-2012 at 04:08 PM. |
07-28-2012, 04:49 PM | #6 |
Member#: 175334
TXIC
Mine was JDM STi pink springs w/ 3/8" 'saggy butt spacers' in the back. I think your Prodrive blues will be lower than that. My Conti DWS 245/40s already have a mild stretch mounted on 9". 235s may really be stretching it (pun intended =).
07-28-2012, 04:54 PM | #7 |
Member#: 41877
Thanks. I noticed the stretch. That's why I thought they were 235. Is your alignment stock?
07-28-2012, 05:34 PM | #8 | |
Member#: 72891
If you don't want to do any fender mods the above set up is about the biggest you can go with out either fender or camber mods. Some may disagree but I've had my 04 since it was new. I've had 4 different suspension set ups and maybe 10 different sets of wheel and tires so I have a good idea what works with out fender mods. |
07-28-2012, 05:56 PM | #9 | |
Member#: 41877
07-28-2012, 06:20 PM | #10 |
Member#: 72891
No, it's the width of the wheel and offset that maters most. When you go up in wheel diameter you go down in side wall size to keep the same "rolling diameter" (or close to it). Example 225-45-17 to a 225-40-18. There aren't as many 17x8.5 wheels out there so your choices are limited.
If you are set on 17x9 and a 245-40-17 tire. Get a +44 or +42 and roll the rear. If you take a close look at the pics posted above, you can clearly see that those will rub with any significant suspension travel. |
07-28-2012, 06:28 PM | #11 | |
Member#: 41877
07-28-2012, 06:34 PM | #12 |
Member#: 41877
They got them in royal bronze only at 17x8. I would go with this size but I don't care for the color.
07-29-2012, 12:20 PM | #13 |
Member#: 97135
if you are set against not rolling fenders then honestly you don't need to be looking for wheels that wide.
18x8.5 grids are offered in hyper black - or just pick a different color. |
07-30-2012, 01:56 AM | #14 |
Member#: 41877
so 18x8.5 would require no fender rolling? What about weight? Anybody know for sure how much heavier a 18x8.5 Grid wheel is gonna be vs a 17x9 Grid wheel? I'm getting all kinds of different numbers on google search.
07-30-2012, 02:10 AM | #15 |
Member#: 97135
if you REALLY care about weight, you are looking at the wrong wheels, and thinking about things completely backwards.
07-30-2012, 02:28 AM | #16 |
Member#: 41877
Yes I know what you mean. Look is my main concern followed closely by handling and cost. Weight/fuel mileage is a distant 4th. This wheel has almost everything I'm looking for. I'm just trying to save a little weight since I drive a lot. It prob won't make that huge of a difference. I think I'll just go with the 17x9's with rear fenders rolled. I think they'll look nicer, are cheaper and might be a little lighter than the 18x8.5's with tires added.
07-30-2012, 03:58 AM | #17 |
Member#: 4414
Vehicle:2002 WRX Sedan Midnight Black |
IMO 235/40/17 is THE tire size for a 2.0L / 5 speed combo.
You get the gearing advantage that the engine and transmission desperately needs, and this outweighs advantages of fitting fatter tires. The added bonus is the smaller diameter means much less need to roll fenders and such. |
07-30-2012, 11:35 AM | #18 | |
Member#: 41877
I'm also worried about the stretch. I don't wanna be worrying about my tires in a hard curve. Not much difference between 245 and 235 but I thought 245 was already a slight stretch. The tire choices at 235/40/17 are much more limited and expensive. The General G-MAX AS-03 tire I was going with is not even available in that size. Last edited by m4r10; 07-30-2012 at 11:46 AM. |
07-30-2012, 11:55 AM | #19 |
Member#: 207905
TXIC
Vehicle:2005 forester xt silverf |
I have 17x9 +42 grids on bugeye running 245/45/17's. Fronts are fine but the rears need rolling, but not much. I run -1.5 camber all the way around and Im not lowered at all.
07-30-2012, 12:04 PM | #20 |
Member#: 41877
07-30-2012, 12:30 PM | #21 |
Member#: 97135
The gearing advantage is huge.
A 235/40 federal is square on a 9" wheel. |
07-30-2012, 12:35 PM | #22 |
Member#: 257681
Vehicle:2013 WRX Plasma Blue Pearl |
I currently have the same problem, except I have an 07 Wrx. I have a 17x9 +35 rpf1 and lowered on coilovers, just got all 4 fenders rolled but don't which tire size to go with. Can some one help me outt ?
07-30-2012, 02:05 PM | #23 |
Member#: 41877
Hey Frank, after doing some reading, I will be going with 245/40/17 General G-MAX AS-03 tires on the 17x9+42 wheels. I know different models vary slightly in how they fit wheels even though they are technically the same size. But I know these will be fine. I'd rather have a more accurate speedometer than the gearing which would improve acceleration a bit but don't think will save me any fuel. I only really step on it merging onto highways nowadays.
07-30-2012, 02:08 PM | #24 |
Member#: 41877
here's a link I found helpful:
http://www.rimsntires.com/specs.jsp |
07-30-2012, 05:44 PM | #25 | |
Member#: 97135
I'd say the difference between a 235/40 and 245/40 is negligible, however I probably chosen different tires. |
