07-10-2012, 07:09 PM | #76 |
Member#: 25194
RMIC
Vehicle:2008 Forester XT 5mt Dark Gray |
The nipple furthest from the electrical plug goes directly to the intake manifold. The other nipple goes to the metal line under the intake manifold that ultimately goes to the firewall and all the way back to the tank area.
Stephen
07-11-2012, 03:50 PM | #77 |
Member#: 154534
Vehicle:2018 WRX STI Limited Black |
Okay I think that might be the problem if I understand correctly. Here is how I had it hooked up and was getting the cel.
SO your saying to hook it up like this then? |
07-11-2012, 04:19 PM | #78 |
Member#: 25194
RMIC
2nd way is correct. Did you fabricate coolant tank or was it a moroso universal?
07-11-2012, 04:25 PM | #79 |
Member#: 154534
alright thanks and i fabricated it to for where i located the turbo
07-18-2012, 02:15 PM | #80 |
Member#: 107302
I think there's a bit of confusion about what nipple on the solenoid goes to what. Maybe it's different on cars.
This is how my MY06 WRX is setup. The bottom nipple feeds to the T-fitting, evap pipe and purge valve and the top nipple feeds directly and only to the intake manifold. I'm guessing I should keep this configuration when I do the delete? ___ Man, I'm glad I came across this thread. My purge valve is dry rotted and the local dealer gets $50 for them! SubaruGenuineParts gets $27. |
07-18-2012, 03:18 PM | #81 |
Member#: 268190
TXIC
Vehicle:2005 STi |
I'm missing my purge valve solenoid. Would this cause my car to pump gas really slow? I'm thinking I need to fix it.
07-18-2012, 07:43 PM | #82 | |
My 05 was same as yours..
07-18-2012, 10:27 PM | #83 |
Member#: 107302
I noticed there's a directional arrow on the solenoid and there's a diagram on the hood for the purge system, if anyone gets confused.
__ I was able to get it sorted today. I was hoping to find a bolt for the nipple on the manifold but had no luck. I even tried a big industrial fastener place. The thread pitch is 0.90mm and I believe the diameter is 8mm? Might be able to get it online. But Autozone had some nice nipple caps. Good stuff. Happy to clean up the engine bay a bit and remove something that could cause issues. |
07-20-2012, 10:15 PM | #84 | |
Member#: 154534
07-21-2012, 11:00 PM | #85 | |
Member#: 154534
why would they be switched when deleting everything? |
07-21-2012, 11:51 PM | #86 | ||
Member#: 107302
The flow is from the evap pipe to the intake manifold/purge valve. So evap pipe goes to the nipple with the arrow. Quote:
__ So I ran this "re-routing" by Matt at 555 Motor Sports (he's my tuner) and he suggested to remove the solenoid all together and vent the evap pipe to atmosphere. He said there are start up issues when routed like the JDM cars. |
07-22-2012, 12:48 AM | #87 |
Member#: 107302
Actually, you may be right. Wiki says 1/8 NPT thread pitch is 0.94mm. It did look like it was tapered too.
07-22-2012, 10:22 AM | #88 |
Member#: 154534
07-22-2012, 02:53 PM | #89 |
Member#: 107302
Cool, I'll try that.
Well it's just vapor. The only problem I could see, if you don't run a hose underneath, is maybe some fuel smell in the cabin. I just sent Matt an email about that. I'll let you know what he says. |
07-22-2012, 05:10 PM | #90 |
Member#: 154534
Sounds good. I'm sure a CEL will be thrown without the solenoid but that wouldn't be difficult to turn off.
07-22-2012, 07:29 PM | #91 |
Member#: 107302
Ok, Matt said he doesn't get any fuel odors with his car and that it will cause a CEL but it can be disabled.
07-23-2012, 08:33 AM | #92 |
Member#: 83043
Vehicle:05 sti Black |
Does anyone have the part number to that black connector thats circled in the pictures? I snapped mines yesterday and need the a replacement one. Couldn't find anything close to matching at the local parts store, so will need to purchase it directly from Subaru...
07-24-2012, 06:22 PM | #93 |
Member#: 154534
I can't remember if that is straight through or not but maybe lowes or homedepot will have them in the plumbing section
07-24-2012, 09:50 PM | #94 |
Member#: 107302
08-06-2012, 10:03 AM | #95 |
Member#: 58957
Vehicle:2010 WRX STI SSM |
will it work if you delete the solenoid and just leave the evap line to vent to atmosphere?
08-06-2012, 06:44 PM | #96 |
Member#: 154534
I think that is what Keif said his tuner did. Im sure you will throw a Cel by doing that but you can probably just turn it off
08-13-2012, 06:04 PM | #97 | |
Member#: 72636
Vehicle:2005 WRX STi OBP |
This is the part number for the new hose assembly with the black plastic connector you are looking for. It's not that much to replace all the hoses and connectors |
08-13-2012, 06:09 PM | #98 |
Member#: 72636
Mine was hooked up with the nipple closest to the plug going to the Manifold, I showed it in my pictures. Not sure why it's the opposite on others but mine is an 05 STI
08-21-2012, 04:01 PM | #99 |
Member#: 256205
i broke the nipple closer to the plug side. what do i do about removing this setup an plugging lines. just connect outer nipple to intake manifold right an can i just leave the broken one vent
08-21-2012, 08:24 PM | #100 |
Member#: 25194
RMIC
808_wrx - my advise is to fix it properly with a new/used unit. It's simple, pay for your mistake and move on.
If you have zero dollars then remove the solenoid and try to JB weld it in place, but I can guarantee it will break over time. Leaving anything open to vent to atmosphere will harm the motor and kill your HP and most certainly result in a CEL. Stephen |
Similar Threads | ||||
WTB: Purge control solenoid valve | jblaine | Private 'Wanted' Classifieds | 7 | 04-21-2009 08:51 PM |
Purge Control Solenoid valve? | Synx | Service & Maintenance | 4 | 07-02-2008 05:40 PM |
Broken Nipple on Purge Control Solenoid Valve | 48mpg | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 02-24-2008 07:40 PM |
Purge Control Solenoid Valve?? | abosworth | Normally Aspirated Powertrain | 3 | 07-21-2005 04:20 PM |
Code 35 purge control solenoid valve troubles | theascen | Service & Maintenance | 2 | 04-02-2004 04:36 AM |
