09-04-2007, 12:06 AM | #1 |
Vendor
Member#: 73568
Vehicle:'05 STI 11.1 @ 127 03 Evo 8 9.5 @ 149 |
ICS Project '07 STI - new mods - EBC and TGV deletes
We are continuing to massage the power delivery on our '07 STI and try to make it have more of a drag racuing power band - we are tryting to stay with the stock turbo and stock tmic and see how fast we can go with the new configuration
Mods were AP 2 tuned by Dyno Flash APS Cold air intake APS 3.5" exhuast and upipe Walbro fuel pump Aquamist HFS-5 50/50 water - meth We just added APS TGV deletes E boost 2 EBC Note in the dyno sheet the spool up looks a lot later due to a different starting point on the dyno and also due to the change from a MBC to a EBC. With the new mods and some more refined tuning the car picked up opver 30 whop in the meat of the drag racing power band - should be intreresting to see how that top end power equates on the track
09-04-2007, 07:20 AM | #2 | |
Member#: 56945
Vehicle:08 STI Base Model Black |
We made the best of 340whp, but the eliptical moved and it didn't pick up RPM (Tourque) and besides the cops almost gave me another ticket for running the dyno late again. lol -George |
09-04-2007, 10:22 AM | #3 |
Vendor
Member#: 73568
I am very curious to see how far we can get with the stock turbo and fmic.
The car is a very potent street driver at this point - I have some videos I am going to throw up on youtube later this evening Al |
09-04-2007, 10:25 AM | #4 |
Member#: 59454
Vehicle:'10 E92 M3 M-DCT brentuning.com/blog |
Looks to me like holding the gate shut with the EBC along with possibly more top end advance/leaner AFR gave you some redline gains at the expense of quick MBC spool up. Both lines start at the same time. Probably good for another MPH.
09-04-2007, 11:23 AM | #5 |
Member#: 132764
Vehicle:07 STI Ltd UGM |
nice!
09-04-2007, 11:45 AM | #6 | |
Vendor
Member#: 73568
Also - it will be interesting to see how much the 30 additional whp in the higher rpm range nets us on the track where most of the action is at high rpms. I would hope it is more than one mph -but - we will be testing it to find out. The EBC is not set with a rpm dependant gain adjustment yet - but it is holding one (1) psi more boost at red line 15.7 psi vs 14.7 with the MBC. We may try to dial in some rpm based gain up top and see if it nets us any additional power trying to force the turbo to 17 psi or so (it may be just hot air at that point). When I was experimenting with the stock turbo on my '05 STI after I got a EWG and the E Boost I quickly threw the stock turbo in the trash after I started making less power with more top end boost. There seems to be a sweet spot with the stock turbos. One more thing we are going to try is instaling a small water jet near the turbo discharge to help with cooling the intake charge, I feel the stock tmic is really working double time. Al |
09-04-2007, 11:54 AM | #7 |
Member#: 59454
Your right, there becomes a point where the stock snail is happy boost wise and leaner afr and more timing advance is the only way to make more gains up top. Good luck finding that i remember your previous air fuel had some room in it.
Are you talking pre turbo injection? its a great idea i think. or maybe a boost/rpm dependent IC water spray like the jdm model ecus |
09-04-2007, 12:10 PM | #8 |
Member#: 131762
International
Vehicle:2005 STi-"casper" white on white ! |
i know this ics car is going to be awsome ive seen their work with bmw m3s and they coaxed 1000hp out of an S52 e 36. so whos the suby master @ ICS
George or Vic ?? |
09-04-2007, 12:16 PM | #9 | |
Vendor
Member#: 73568
I am the tuner and guy with the '05 WRB STI - (UR GT35R Kit) My car has been on the back burner for a couple of weeks but it will be comming out to play very shortly ! |
09-04-2007, 12:21 PM | #10 | |
Vendor
Member#: 73568
What I really like about the '07 Project is that the car thus far retains true stock like driveability and feel as far as smoothness and over all power band. We are trying to maximize the power potential with the stock turbo as we feel most customers stay with a Stage II modification level and most of our customer's cars do not get upgraded turbos. I feel the '07 in particular has a lot of potential on the stock turbo. Al |
09-04-2007, 12:22 PM | #11 |
Member#: 61749
All how much more hp would a fmic, external wastegate and ported/aftermarket header add?
09-04-2007, 12:51 PM | #12 | |
Member#: 114631
Vehicle:2009 GTR, 735whp 13' Benz, 15' WRX |
Al, I wish you luck with your stg 2 project and hope to see you at the track some day soon. With this being said, I am feeling a strong sense of friendly competition. My personal goals for this car are 11.6-11.7 @113+ with an exhaust, tune, and pump. I am taking this car to the absolute limits before putting another penny into it |
09-04-2007, 12:56 PM | #13 | |
Member#: 59454
Al I would like a continued neutral opinion mod for mod dyno comparison like Buscher did with the 06.....uppipe addition, cai addition etc like you are doing now. This is what the community really needs. Not just a bunch of people self promoting their own parts. |
09-04-2007, 03:14 PM | #14 | |
Member#: 56945
I really enjoy the opportunity to have a project car to work on and a shop owner willing to make things happen as far as doing installs on the car and allowing me lots of dyno time to do R & D. This kind of testing and development is very useful and I find it is of huge benefit. My very next step on this car is going to be a A - B header test with the current mods we have now - I am curious to see what power gains if any are made with a generic 4 - 1 header and also to see what effect a header would have on the power band Al on ICS cpu |
09-04-2007, 03:16 PM | #15 | |
Member#: 56945
This machine is the real Evo fighter of the STI's and I think by next year there will be many of them in the 11 second range on the stock turbo. Al |
09-04-2007, 03:40 PM | #16 | |
Member#: 59454
Looks like you and George already have it covered - look forward to the future udpates |
09-04-2007, 03:51 PM | #17 | |
Member#: 132764
09-04-2007, 10:22 PM | #18 |
Member#: 33175
Vehicle:1998 Impreza 2.5RS 98 Unicorn |
We just finished another swap w/ an 07 Limited STi drive train over here at ECS. Its in a 00 Imp Wagon. Unfortunately, its no longer on stock turbo, or i would love to be in on this fun. The owner chose a green, its going to be tuned Friday, if you want ill chime in w/ the results.
-Paul @ ECS |
09-04-2007, 11:52 PM | #19 |
Member#: 151683
^that sounds sick..... but al, those numbers, and that vid on youtube might just have me make the trip to see you sooner than i thought... great work, Id like to know how it is after 10k or so miles on that tune... I want my car to be fast and actually last...
09-05-2007, 12:07 AM | #20 | |
Vendor
Member#: 73568
09-05-2007, 12:14 AM | #21 | |
Vendor
Member#: 73568
I feel these numbers are representative of what a customer can expect from a similar set up within 10 whp. When you use your car as a form of basic transportation it is always more prudent to err on the side of safe and cautious - that is my approach. However, we usually discuss these matters with customers and seek their feedback as to what they are looking for in a tune. Al |
09-05-2007, 01:52 AM | #22 |
Vendor
Member#: 73568
The results are in on the header test
This was a A - B test - no other changes made The header tested was a groupe S 4 into 1 style header The header is apparently of no help and in fact hurts spool up and top end power on the stock turbo at these boost and power levels I am a little suprized by the results (would have thought the header would have made a bit of top end power at the expense of low end spool up) but the dyno does not lie |
09-05-2007, 08:18 AM | #23 | |
Member#: 56321
Vehicle:2006 Honda El Camino Green |
What would happen if the car was retuned? Thanks, Mike |
09-05-2007, 09:51 AM | #24 |
Member#: 88322
Vehicle:2009 BMW 135i |
09-05-2007, 09:56 AM | #25 |
Member#: 151278
Similar Threads | ||||
FS: mod Perrin 816cc JDM pinks and tgv deletes | sleepysubie | RMIC Private Classifieds | 8 | 05-06-2009 04:23 PM |
FS: STI Injectors, Modded WRX Injectors, TGV Deletes!!!! | dye4life330 | Engine/Power/Exhaust | 17 | 02-25-2009 01:06 PM |
ICS Project '08 STI - new dyno best - 529 WHP on Pump Gas & Meth ! | Dyno Flash | Proven Power Bragging | 52 | 02-29-2008 09:03 AM |
Base Line on ICS Project '07 STI - and test with snorkle removal | Dyno Flash | Proven Power Bragging | 18 | 08-23-2007 09:25 PM |
New injectors and tgv delete - vaccum leak?? | Mactizen | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 06-11-2007 02:23 AM |
