10-21-2014, 08:17 PM | #6201 | |
Member#: 302570
Vehicle:2013 XV DGM! |
10-21-2014, 10:27 PM | #6202 |
Member#: 315353
NESIC
Vehicle:2012 Impreza Sp Prem 5MT OBP/DGM |
10-22-2014, 06:45 AM | #6203 |
Member#: 302570
10-22-2014, 06:37 PM | #6204 |
Member#: 301387
Vehicle:2012 Impreza HB Black/Dark Grey |
Nothing new here. Car should be in the process of a short block change as we speak. No call from the dealer yet.
10-22-2014, 07:49 PM | #6205 |
Member#: 348055
Vehicle:2013 Impreza 5MT ISM |
Couple interesting notes...
Changed my oil today and picked up the OEM filter. Guy at the parts department said it isnt abnormal to be low on oil after 3k miles. Said I could certainly go in for an oil consumption test though. Will consider it after monitoring myself after this change. Also... weird... asked a guy I work with who is big into Jeeps how often where he buys oil. Was just trying to see if he knew somewhere with a good price. He said, and I quote, "Didnt you know? I dont change my oil". He said that modern oil doesnt need to be changed and he simply adds if its low. Dont have the motivation to research or argue that one. |
10-22-2014, 09:42 PM | #6206 | |
Member#: 315353
NESIC
In all seriousness though, I've never heard that one before. There are oil manufactures that claim you can go 10k, 15k, 20k or more miles with their oil, but I sure as hell wouldn't chance it. All oil, even modern synthetic oils, break down after a while. Not only that, but you would most certainly void your warranty should something happen to your engine and you didn't follow the manufacturers recommend oil change intervals. Last edited by jr0bb5; 10-22-2014 at 10:36 PM. |
10-22-2014, 09:45 PM | #6207 |
Member#: 315353
NESIC
Double post
10-23-2014, 07:32 AM | #6208 | |
Member#: 302570
I think that this may be where people get the idea. Totally stupid not to change the friggin oil. I have a coworker who has a heavily modified and abused Jeep and I cringe at some of the stuff he does/has done to it. |
10-23-2014, 01:15 PM | #6209 |
Member#: 315353
NESIC
I suppose you could make the argument, as others have suggested, that it's unnecessary to change your oil often, or at all for those who have engines that consume oil at a high rate because you're always replenishing with fresh oil. I would still highly recommend changing the oil filter at least every 7500 miles.
Personally, I wouldn't run an extended OCI even with oil that says I could or with an oil thirsty engine because of the risk of voiding the warranty. Last edited by jr0bb5; 10-23-2014 at 01:31 PM. |
10-23-2014, 01:30 PM | #6210 |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
I wouldn't run an extended OCI on any car that's under warranty, regardless of how oil thirsty it is. Once the warranty expires, I'd let a UOA dictate my OCI.
10-24-2014, 06:15 AM | #6211 | |
Member#: 302570
10-25-2014, 02:35 PM | #6212 |
Member#: 392361
I have a 2013 imprezza and it is eating oil way more than it should. The dealership told me they know about the problem but won't replace my short block because "yours isn't that bad".
Why is this happening to a brand new car? Sent from my iPhone using NASIOC |
10-26-2014, 08:40 PM | #6213 | |
Member#: 302570
Basically, like any other product, cars are being built crappier and cheaper every year. Consumers view the brands and companies as "holy institutions" and expect nothing for their dollar. Long gone are the days of Nader's Raiders and consumer activism. |
10-27-2014, 08:41 AM | #6214 |
Member#: 322264
Please provide some more details. How long have you owned your car? How many miles are on it? CVT or manual? How did you go about breaking it in? How often have you changed its oil? What is its oil consumption rate? Have you gotten the oil level light, or do you know it's consuming based on dip stick readings?
10-27-2014, 12:54 PM | #6215 | |
Member#: 88514
HIIC
Vehicle:2010 Outlander XLS Brown Metallic |
If SOA thinks excessive oil consumption on a new vehicle is "normal", then they've been huffing their own burning oil I can tell you our "new" 2013 Mini didn't/hasn't consumed ANY oil with 15k on the odometer |
11-06-2014, 07:49 PM | #6216 |
Member#: 383746
maybe a bad sensor?
11-06-2014, 11:20 PM | #6217 |
Member#: 405726
NWIC
Vehicle:2003 wrx wagon yellow |
Have you guys ever thought that maybe it isn't the car. That maybe the 0w20 oil you put in the car is pretty much water. Car companies like Subaru are under the gun to get better mpg and one way to reduce friction in engines is to make the oil thinner so it's easier to move around.
I use a thicker oil and my oil consumption has gone away. I drive a lot of subarus for my job and all the oil consumption problems started when they went to 0w20 oil. Sent from my iPad using NASIOC |
11-07-2014, 12:46 AM | #6218 |
Member#: 372100
Vehicle:2013 Premium 5dr CVT DGM |
Were you putting 0W-20 in your bugeye?!
11-07-2014, 08:40 AM | #6219 | |
Member#: 315353
NESIC
11-07-2014, 10:32 AM | #6220 | |
Member#: 315643
South East
11-07-2014, 12:20 PM | #6221 |
Member#: 405726
NWIC
No I'm not putting it in my bugeye. You did really read my post did you. I said for my job.
I never said that there may not be a problem I just said that the main problem is to thin of oil. Most of the problems will be cleared up with thicker oil. And yes there will be some that continue to have problems. What kind of Subaru do you have I can't see if you have it listed cause I'm on a iPhone. If your car dosent call for synthetic oil that may be the problem to. You may not believe this but in some cars synthetic oil will not stick to the engine components as well as conventional. it just slides right on by. Try switching to a conventional oil if that what your car calls for a couple oil changes and see what happens. Sent from my iPhone using NASIOC |
11-08-2014, 10:12 AM | #6222 |
Member#: 302570
11-08-2014, 10:15 AM | #6223 | |
Member#: 302570
11-10-2014, 06:44 PM | #6224 |
Member#: 301387
Can someone once again tell me how to drive during the break in period? I got the car back with a new shortblock.
11-10-2014, 06:50 PM | #6225 |
Member#: 348055
Like a bat out of hell! As the saying goes...
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? | JDMSTA | Electrical & Lighting | 59 | 07-21-2013 08:04 AM |
2012 Impreza 2.0i Mobil1 oil filter model # | jr0bb5 | Service & Maintenance | 27 | 01-04-2013 05:18 PM |
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 | Oceanguy | Impreza Forum | 80 | 11-18-2012 12:56 PM |
My Oil Light is Flickering and I have No Leak??? | kakarotoni | Newbies & FAQs | 39 | 08-16-2012 10:36 AM |
('11-'14) 2012 Impreza High beams = Low beams lighting | Jmzda | Impreza Forum | 28 | 06-01-2012 12:14 PM |
