Brakes & Suspension Forum sponsored by The Tire Rack |
05-26-2007, 12:27 AM | #1 |
Member#: 41939
TXIC
Vehicle:2001 RS 2.5 BRP |
Rear brake seems to stick
Came home in my 01 RS and noticed a brake smell. Well, I checked the right rear brake and it was extremely hot. I just got off the highway so no stop and go traffic and the other brakes were fine. What could cause this brake to stick and what is the possible solution?
05-26-2007, 01:28 AM | #2 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
Most likely the caliper sliders are seized. You need to remove them and re-grease with a suitable high-temp brake grease. If they are too far gone you may need to replace them.
05-26-2007, 10:14 AM | #3 |
GC84Ever
Super Moderator Member#: 301
NWIC
Vehicle:1970 FF-1 & '70 Van 02 WRX/01 RS |
caliper pins sieze often
boots tear, dirt/dust get inside - grease flows out and you get lock up buy a rebuild kit + slider pin regrease - reboot - replace pin and you'll be golden you might want to double check your pads to see what you've got left back there? typically a stuck pin destroys brake pads. Jamie |
05-26-2007, 11:57 PM | #4 |
Member#: 41939
TXIC
Have replaced the pads like 3 weeks ago. I'll get a rebuild kit.
05-27-2007, 10:46 AM | #5 |
GC84Ever
NWIC
05-28-2007, 12:31 AM | #6 |
Member#: 41939
TXIC
I shall disassemble the caliper and grease everything. I shall then drive it and see if the problem persists.
05-28-2007, 12:36 PM | #7 |
Member#: 105290
South East
Vehicle:97 Legacy GT Wagon Silver |
how do you rebuild them, mine is doing the same thing?!?
05-28-2007, 09:40 PM | #8 |
Member#: 41939
TXIC
Am in the process as I type this. I have no idea how to get the boots off the pins!!
05-28-2007, 09:50 PM | #9 |
Member#: 41939
TXIC
I got em. I just pull back the boots off the pin. Was a little dry so I put some caliper grease in there. We'll see if that does the trick.
05-28-2007, 10:04 PM | #10 |
Member#: 132786
W. Canada
Vehicle:2001 Impreza TS Artic Silver Metallic |
I would also check your roto for warpage,grooving and allowable thickness. you may want to use a brake silicone compound, no grease of any kind because they have petrolem and may cause damage to boots and under high temp greese gets fluid like.
05-28-2007, 11:23 PM | #11 |
Member#: 41939
TXIC
It's high temp synthetic caliper grease. It's specifically made for this application.
05-29-2007, 10:38 AM | #12 |
Member#: 41939
TXIC
Well, I got everything back together and got home to find the rotor red hot. GREAT! So, I am guessing the piston is sticking. Going to have to order a whole new caliper. Lovely. Damn Yankee cars!!! Rust is a bitch!
wrx rear brake convert to sti rear brake | sonic rex 03 | Brakes, Steering & Suspension | 0 | 12-22-2005 08:29 PM |
Shifter seems to stick when cold | NegativeC | Transmission (AT/MT) & Driveline | 8 | 12-23-2003 08:21 PM |
Front left wheel seem to stick out more than the right one... | pj_cab | Tire & Wheel | 2 | 11-13-2003 11:02 PM |
JDM rear brakes? Where to buy? | IA Performance | Brakes, Steering & Suspension | 1 | 10-06-2003 08:29 PM |
My brakes seem to suck... | drhyed | STi Forum Archive | 15 | 07-19-2003 07:22 PM |
