11-23-2007, 03:53 PM | #1 |
Member#: 94415
Vehicle:2005 STi |
CEL & Idle issues after tune
Last night I got a P0420 CEL while driving home. I reset the ecu and reflashed the base map and loaded the real time map. Then when I started the car and drove around I was having issues with the idle and the car would stall in neutral. So I tried reflashing the maps again and then when I started the car I got a P0171 System running lean CEL.
Could there be any mechanical reasons why this is happening? Everything was running just fine up until I reset the ecu that first time.
11-23-2007, 04:44 PM | #2 |
Member#: 107099
Vehicle:'07 STI Satin White Pearl |
Sounds like a bad tune?
Car stalls consistantly after tune problem!! | Kenji815 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 34 | 06-10-2010 02:11 PM |
Idling issues after installing new pitch stop mount | Sandhawk | Newbies & FAQs | 9 | 03-02-2010 12:35 AM |
Idle issue after turbo inlet install | 07wrx4life | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 10 | 04-13-2008 12:32 AM |
Got P0120 CEL after emanage install & other issues | mxpunk | Normally Aspirated with bolt-on Forced Induction Powertrain | 27 | 07-27-2007 12:27 PM |
