![]() South West Impreza Club Forum sponsored by ScoobyMods.com |
#1 |
Member#: 43918
Vehicle:2007 Subaru STI Blue |
I know this is a common problem, though I never experienced it before until this scooby. Is there anything I can do to fix this problem other than replacing the gearset? I won't drop the cash for that and it's just 1st gear that grinds if I put it in that gear going more than 4mph.
#2 |
Member#: 122305
SWIC
Vehicle:2002 wrx half breed Aspen White |
I always thought the STI's have a dual syncro for first to combat that problem unlike mine that has one.
First thing i would try is put in Unclescottys cocktail that should clear it up quite well deff did for me. I put in a ra gearset and tried to use straight up one type of oil worked for about 2 months and started to just get the little grr so once i heard it put in the cocktail or my own version of it and BINGO got nuthin and its been almost 2 years not a problem. |
#3 |
Member#: 43918
Sorry, this is on my 2002 WRX
#4 | |
Member#: 120273
SWIC
Vehicle:06 WRBWRXWGN I install stuff cheap. |
Second, DO NOT use the uncle scotty's cocktail in that 6spd without some research. Many people report having problems with it and some claim it gums up the internal oil pump, something the 5spds do not have to worry about. There is a good oil thread for the 6spd in the trans technical forum. However, 1st gear grind is not a good thing. I really don't hear or see that particular gear grind often in the 6spd without abuse. 4th and 5th on the earlier boxes (04 and 05) is very common. I don't hear about 06+ boxes grinding hardly ever. Like I said, that doesn't look good... Do you try to force it into 1st without rev matching? This will kill them fast. |
#5 |
Member#: 120273
SWIC
#6 |
Member#: 63605
SWIC
Vehicle:04 Wrx Wagon -TTS 08 Titan, 08 MX-5 |
get the tranny fluid replaced with something good, and see if that helps. avoid shifting into first until the car is at a stop. i had 4th gear syncro go bad and replaced the fluid and mixed it with a thicker redline additive, and the grind went away.
#7 |
Member#: 43918
Wow, well it just seems ridiculous for me to have to always be at a damn stop to change to first gear. That is a danger in everyday driving. What kind of oil do you recommend?
#8 |
Member#: 120273
SWIC
1 quart motul 300 and 3 quarts Redline shockproof... or maybe it's the other way around, but that's what I've always heard. Dunno, I always used Valvoline in my 5MT whan I had it and it sucked as a fluid. However, it was cheap.
#9 |
Member#: 200526
SWIC
Vehicle:02 WRX-EVOIII/16g PSM |
i've never been able to get my car into first gear rolling. well, i almost need to be completely stopped to do it. not sure if there is anything wrong. i remember my car was like that from the factory
#10 |
#11 |
Member#: 120273
SWIC
Yeah, I can't say I miss the 5MT at all except for the tall gears in my 06 box. It had a lot of bad habits.
#12 |
yeah i have to be going 1mph or less to get into 1st gear
and reverse is sometimes hard to get into unless you roll forward a little then put it in |
#13 |
I've found double clutching seems to work when going a few mph and trying to put it into 1st. sometimes rev matching works. Double clutching seems to work best out of the two, just a pain to do
#14 | |
Member#: 63605
SWIC
you shouldn't be downshifting into 1st unless the car is almost stopped, that's normal for any car. doing so is more dangerous. |
#15 | |
Member#: 215057
SWIC
Vehicle:2002 WRX WRB |
also, to the OP: I double clutch. it works very well, but if you over rev it grinds even worse. just practice a little. it's good for those times when you're doing under 3-7 mph, and 2nd would be a little too soon... |
#16 |
Member#: 223892
Vehicle:2002 wrx sedan Silver |
does anyone read the manual to the car? its there for a reason lol.... Subaru made this on purpose. you are not suppose to go into first unless you are in a complete stop... and thats the only time you should be in first...to get the car going
#17 | |
Member#: 120273
SWIC
![]() You! Out of SWIC! |
#18 |
I had a grind going into 4th and had to be completely stopped to shift into first. I switched over to Redline Lightweight Shockproof and no more problems.
#19 |
Member#: 223892
#20 |
Member#: 43918
To the guy questioning my point, it become VERY important to put the car into first gear to get the hell out of the way when making a turn!!! The kind of turn like a California stop at a yield sign or when leaving a parking lot to get onto a road. I don't want to bog way down and get slammed in the ass or make somebody hit the brakes just so I can turn like a normal damn car should be able to do!
To the other guys, TYVM for the info. I will try the double clutching thing first and then use that oil formula to see if that helps at all. |
#21 | |
Member#: 63605
SWIC
#22 | |
Member#: 63605
SWIC
It specifically states in the wrx manual, to not shift into first unless at a stop. My advice would be to change the fluid, add some redline lightweight shockproof and change your 1st gear habits...or don't complain when you need to rebuild the tranny. |
#23 |
Member#: 42145
Vehicle:6-4 jockin da bish- es and slappin the ho's. |
Either you have to change your driving habits or you have to get better at rev-matching.
I'm always aware that I have to almost stop to get first. Once in a HUGE while (not that I drive my car much) I need to get into first on a roll and I know I'm abusing my car when I do it. I never have anyone rev on me, but I get these kids in their scion coupes, that must have blowers or something stupid that just won't leave me alone. Sometimes I need to make my point to these kids so I can give them the "thumbs up, slowly rotated to thumbs down, gladiator style", that REALLY pisses people off. |
#24 | |
Member#: 52313
SWIC
Vehicle:2005 STi CGM DB20G 2007 MazdaSpeed3 |
My fav trans fluid by far is Silkolene's Silktran Syn 5. I started running it early 2007. It's getting harder to find in the states than it used to be, and it is kind of expensive (~$29/liter), but it's real nice stuff. Here's what Dave@Rallispec told MrMcCrackin when he was researching early last year...
#25 |
Member#: 189351
South East
Vehicle:2008 WRX STi Aspen White |
my wife had an 02 wrx and I have an sti (owned it during the wrx ownership)...instead of shifting fast into 1st [from second], I would just fully clutch and hold the shifter against the gate until it slipped in, I would say it grinded about 1/4th of what it used to after that. Shifting was a bit slower but we never raced it, so it wasn't a big deal. If you autocross though...might be a different story. Rev-matching only works if you match it perfectly unfortunately, you'll probably go crazy before you find the sweet spot.
Sucks that so many of these came from the factory like this. |
