04-27-2014, 09:42 PM | #5251 |
Member#: 336257
Vehicle:2013 Imp Sport P 5MT Black |
This thread is now over 213 pages/5300 posts... is there some way a summary could be written up and stickied?
I mean, I have my own opinions after 35k miles in my 13 Sport. The light never comes on, but it does consume oil. I honestly don't want to read the entire thread before posting, and don't want to look like an idiot for posting without doing it.
04-27-2014, 10:07 PM | #5252 |
Member#: 302570
Vehicle:2013 XV DGM! |
post away, no one will blame you- thats why I have mentioned for hundreds of pages tue trolling and off-topicry...
lol let me summarize... Peoples cars showed oil loss, strangely others trolled and belittled. Subaru quietly admits there is a problem, but only after denying it and pissing off many owners. Problem still persisting. They say its normal and even decorate service depts with oil info placcards, explaining how its normal to top off new cars from day one when they are guzzling oil. At that same time a tsb was quietly released that contradicted the other statements they had made about oil loss. Now there are plenty of oil burning unhappy subaru owners all over the web. As soon as one troll goes away, another comes back for more. Thus, the actual discussion is effectively derailed, buried, or otherwise disrupted. |
04-27-2014, 10:36 PM | #5253 |
Member#: 336257
Nice. Ok, here's my take on it -
99% of CVT Imprezas never had the rings properly set during break-in. The CVT is programmed to short shift for max mpg. It also has an extra (simulated) 'overdrive gear' to keep revs down for hwy mpg. The motor never gets up into the power band and rings don't get properly set. Of course by this logic, this is the same type of consumption that would appear on any motor with bad rings, accompanied by oily exhaust and compression loss. Easy enough to check and identify. I think it would be worthwhile to track which suspect motors are in CVT cars compared to 5MT cars. If the rings are properly set, consumption would be a different type. Easier to set them initially and check it on a manual. Get a fresh oil change then pull into the power band, between 4k to 6k. Smell that? That's the smell of 0w oil vaporizing every time you use the motor. This type of consumption will vary depending on driving habits. What I call 'using the motor' would probably be classified by Subaru as 'severe driving'. Then again, they also include downshifting, humid conditions, and idling in traffic under their definition of 'severe driving'. I'm up to 35k miles in my 2013. The oil light has never come on. My consumption rate is pretty consistent at half a quart about every 1200-1500 miles. I try not to go over 4000 miles between oil changes; the motor doesn't like it. |
04-27-2014, 10:51 PM | #5254 | |
Member#: 314216
Vehicle:2012 2.0i Sport 5MT DGM |
At about 60 miles, i did 2 near redline pulls through 3rd gear, otherwise my breakin was by the book. I usually shift around 4k even after 44k miles. I didn't use cruise until 1600 miles, and i varied rpms a lot during the first 1600 miles. I use about .5-.7qt/7500miles |
04-27-2014, 10:53 PM | #5255 | |
Member#: 336257
04-28-2014, 07:45 AM | #5256 |
Member#: 314216
Nope, my commute is 41 miles, 39 of which are some sort of highway and 3 stop signs and 4 lights. Engine is turning 3000-3500rpm for most of it
04-28-2014, 12:43 PM | #5257 |
Member#: 337395
Vehicle:2014 Impreza SP Ltd ISM |
this may be a stupid question,
how do you check oil level with dip stick when the oil on the dip stick looks vertical line instead of nice horizontal looking line? I was on my way to work, and I got low oil light, so I got to parking lot and check oil.... |
04-28-2014, 12:45 PM | #5258 |
Member#: 314216
04-28-2014, 12:49 PM | #5259 |
Member#: 319157
Vehicle:2012 Impreza 4DR 5MT |
Roll your car on to its side before checking the oil level.
The dipstick setup isn't the best on our cars. You might have to wait a while after shutting off the engine for the oil to drip out of the tube. |
04-28-2014, 01:00 PM | #5260 | |
Member#: 337395
I think it's level surface.. (http://tinyurl.com/mufbq3n)
I parked at one of those multiple story park and ride top floor where it's flat and before I got to parking lot, I was stuck in traffic with light on, and I turn off and on the car, and after that I drove at least 20 minutes on freeway 55~65mph and light was off during that time it's funny that low oil pressure light is red and actual low oil light is yellow.. Quote:
Thanks for the input, I'll check after work |
04-28-2014, 01:03 PM | #5261 | |
Member#: 319157
Yellow light = $5 Red light = $5,000 |
04-28-2014, 01:19 PM | #5262 |
Member#: 259587
Vehicle:2014 Impreza White |
Just a followup.
I just checked my wife's 2014 Impreza and it was a 1/2 quart down. So, 1 qt down at 1500 miles, topped off with 5W/20 and now at 2500 miles, down a 1/2 qt. The dealer will be doing a consumption test once we get to 3000 miles. She is the primary driver and doesn't drive it hard. We do drive it to the mountains to go skiing, but I don't think that qualifies as "severe conditions". |
04-28-2014, 02:00 PM | #5263 | |
Member#: 302570
04-28-2014, 02:03 PM | #5264 | |
Member#: 315353
Vehicle:2012 Impreza Sp Prem 5MT OBP/DGM |
The dealership has always told me to check the oil level no less than 5 minutes and no more than 10 minutes after the engine has been shut off for the most accurate reading. Also, the oil level will read a little higher, or lower depending on which side of the dipstick you look at. I was told to always go by the lower side. Last edited by jr0bb5; 04-28-2014 at 02:18 PM. |
04-28-2014, 02:28 PM | #5265 | |
Member#: 314216
i always check mine in a verified level spot (4ft level used). i have been burned in the past by checking the impreza elsewhere and thinking it was 1/2qt low to only get home and check it and find out I way overfilled it (probably didn't need any) |
04-28-2014, 02:45 PM | #5266 | |
Member#: 322264
Vehicle:2012 Impreza Sp 5sp Obs Blk Prl/Drk Gray Mtl |
I generally check my cars' oil levels when the engine is stone cold, so clearly I'm waiting more than 10 minutes. |
04-28-2014, 03:12 PM | #5267 | |
Member#: 89967
Vehicle:2020 Volvo S60 Gray |
04-28-2014, 07:43 PM | #5268 | |
Member#: 315353
04-28-2014, 09:12 PM | #5269 |
Member#: 302570
Yes that is the key.
04-29-2014, 12:07 AM | #5270 |
Member#: 337395
so I checked oil level after work it was at the lower dot.
I bought pennzoil 0w-20 and fram ultra synthetic filter and replaced oil last time it was in December and 11000 miles now about 15300mi. also replaced air filter with K&N and found couple of dead bees... Thanks for the help everyone |
04-29-2014, 02:28 AM | #5271 |
Member#: 389102
Vehicle:2015 Civic Si Sedan White |
Hey everybody,
I'm about to pick up a 2014 Impreza with a cvt on Wednesday. I'm planning on using the paddle shifters to get it to hold ~ 4000 rpms for a little longer than the auto mode wants to. I'm going to avoid downshifting /compression braking, and I'm going to take the long way to work for the first 1000 miles instead of the highway. Sound good for a new engine hard break in? My wife has a 2012 Impreza with a cvt that she got used with 7000 miles on it. No idea how that engine was broken in, but hers does lose about 1qt every 3000 miles right now. We're keeping an eye on that. |
04-29-2014, 07:22 AM | #5272 |
Member#: 322264
I would argue that avoiding downshifting and engine braking is the wrong thing to do. These are the very kinds of activities that help seat the rings properly.
For the first 1000 miles, DO downshift and engine brake, but do it in a way that won't exceed 4k RPM. |
04-29-2014, 07:37 AM | #5273 |
Member#: 302570
I would downshift a lot.
04-29-2014, 07:40 AM | #5274 | |
Member#: 302570
04-29-2014, 08:38 AM | #5275 |
Member#: 389102
VanBortel said it was a loaner. Apparently they sell them every model year and replace them. She got a great deal on a 7 yr 100k mile bumper to bumper warranty. We're not too worried about it.
And I'll do a bit of compression braking on the '14 |
Similar Threads | ||||
Are there any DIY independent fog lights write ups yet for 2012 impreza sports? | JDMSTA | Electrical & Lighting | 59 | 07-21-2013 08:04 AM |
2012 Impreza 2.0i Mobil1 oil filter model # | jr0bb5 | Service & Maintenance | 27 | 01-04-2013 05:18 PM |
('11-'14) OC interval and the first oil change on 2012 Impreza 2.0 | Oceanguy | Impreza Forum | 80 | 11-18-2012 12:56 PM |
My Oil Light is Flickering and I have No Leak??? | kakarotoni | Newbies & FAQs | 39 | 08-16-2012 10:36 AM |
('11-'14) 2012 Impreza High beams = Low beams lighting | Jmzda | Impreza Forum | 28 | 06-01-2012 12:14 PM |
