04-15-2010, 12:39 PM | #1 |
Member#: 234611
Vehicle:2006 WRX Black |
Ecu Pulling 10% Fuel. (-10)
Okay, so here is the question. Could someone please explain how this works... If I had a leak at either the 90 degree elbow off the turbo or any piping on the turbo to the bov, would that cause the !important to experience rich conditions and consequently cause the ecu to pull fuel? So it is pre turbo leak causes to run rich and ecu pulls fuel & post turbo causes car to run lean and ecu adds fuel? How does this work? LOL... Sorry for noob questions. Still learning alot
04-15-2010, 06:55 PM | #2 |
Member#: 232940
Why don't you tell us what the actual symptoms are instead of presenting a hypothetical scenario
04-15-2010, 11:55 PM | #3 | |
Member#: 234611
Okay. So here we go. The last time I got a learning view on my car it was pulling 10% fuel... Actually was -10% learned at 40+...... Any ideas? Car has massive loss of power and not boosting normal. My target boost is 20psi but I'm normally only getting to around 15 unless I really really throttle the car and let it run WOT for more than I'd like. The spool is also quite a bit slower.... |
04-17-2010, 09:04 AM | #4 |
Member#: 232940
pressure test for boost leaks
Similar Threads | ||||
ECU pulling fuel. -10%.... | lordizzy626 | Newbies & FAQs | 7 | 04-16-2010 11:48 AM |
ECU pulling timing? | rich728 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 9 | 12-18-2003 11:01 AM |
ECU Pulling timing back... | GregUnd | Texas Impreza Club Forum -- TXIC | 6 | 08-06-2002 02:34 PM |
Stock WRX - ECU pulling timing - advancing it again? | SnortWagon | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 16 | 06-06-2002 02:46 PM |
Just how much timing DOES the ECU pull? | BYBYV8 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 03-12-2002 01:38 PM |
