06-15-2009, 11:50 PM | #1 |
Member#: 87542
SCIC
Vehicle:2002 Bugeye PSM |
blown turbo..posible engine damage?
My VF30 has had a good amount of shaft play, yesterday I was driving to my buddies house and I believe the turbo finally gave out. I only seem to stay in vacuum and does not hold any boost. the engine seemed to go into limp mode only revving to about 3k and shuttered like i was hitting fuel cut. I drove it home (about 3 miles) I get very little white smoke and the car seems to have a hard idle and sometimes turns off.
any suggestions? Im gonna try to do a compression check.
06-15-2009, 11:57 PM | #2 |
Member#: 95972
Vehicle:2012 Legacy |
kinda sounds like a maf problem along with the turbo
maf for the shuttering and stalling |
06-16-2009, 12:00 AM | #3 |
Member#: 87542
SCIC
06-16-2009, 12:21 AM | #4 |
Member#: 53558
NWIC
Vehicle:2005 Baja Turbo White/Silver/Black 3tone |
Possible you got some contamination on your MAF when the turbo let go. Pull the sensor itself and make sure there isn't anything on it.
My guess would be the MAF is fine, and the turbo is restricting your intake, and possibly exhaust, so much that your engine is having some big problems running right. Solution, put a new turbo on it. If you can't, then don't run the car until you can. |
06-16-2009, 12:23 AM | #5 | |
Member#: 87542
SCIC
Im getting it trailered to a buddys house and taking off the turbo. I wonder what im gonna see there |
06-16-2009, 12:27 AM | #6 | |
Member#: 53558
NWIC
Most likely, the engine just burned whatever oil made it through your intercooler, if any made it that far. If you do find a ton of oil in there, I'd suggest pulling your intercooler off and draining it. My 1985 GL Turbo hydrolocked itself on oil. I don't know how, but it did. The turbo was fine apparently, so it had to have been something else... And it happened on a dry day, so it wasn't water. Coolant was fine, so that wasn't it either. Oh well, that car was a nightmare. |
06-16-2009, 12:31 AM | #7 | |
Member#: 87542
SCIC
06-16-2009, 12:51 AM | #8 |
Member#: 53558
NWIC
04STi - BLOWN TURBO- POSSIBLY ENGINE-HELP | RIP2004WRBSTI | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 136 | 01-22-2009 08:41 PM |
Can blown struts cause any damage to my STi if driven on? | Red Rexx | Brakes, Steering & Suspension | 12 | 07-31-2008 03:06 PM |
Does blown turbo = engine damage ? | Sausage | Newbies & FAQs | 12 | 06-13-2007 12:03 AM |
Pre-turbo cat failure = blown turbo | nicd | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 13 | 10-24-2001 03:18 PM |
Blown 2.5RS engine at Buttonwillow? | Jason | General Forum Archive | 7 | 08-30-2000 05:44 AM |
