Tire & Wheel Forum sponsored by The Tire Rack |
08-07-2003, 03:20 PM | #1 |
Member#: 40567
Vehicle:RIP Worcester 6 St Florian protect us all |
Question for owners of Continental ContiExtremeContact Tires
Hi again, everyone. I've done several searches and I still can't find a solid opinion on this...I'm driving a 2002 RS with a 20mm rear swaybar and Prodrive springs on stock struts. I'm running 205/55-16's on the stock rims, and I'm wondering what psi front to rear works best. I do some fairly aggressive driving with a monthy rallycross or two thrown in. I realize that there are other threads that address psi issues, but usually there's 3 or 4 different opinions, plus some people think that the conti's need to be aired up higher than stock. Any help would be appreciated! Thanks, Brian
08-07-2003, 04:35 PM | #2 |
Tire Rack Moderator
Member#: 1215
Vehicle:800 -428-8355 ext. 4362 |
34 front 30 rear is a good compromise between steering response and ride quality
08-07-2003, 09:28 PM | #3 |
Member#: 37143
Vehicle:02 WRX Wagon Alpine White |
36 front and 34 rear - I don't race or auto-X so can't speak on that part but for road driving I am very happy with these settings.
08-07-2003, 10:22 PM | #4 |
Member#: 39576
Vehicle:1999 OBS Green |
Im on a chalk soapbox. Do the chalk!
just my 2cents for testing tire pressures with chalk...
I think it’s a really cool way to find out how your driving, in your vehicle, in your environment is interacting with the contact patch. Sean's directions on how to use chalk: http://forums.nasioc.com/forums/show...hreadid=267049 I like Luke’s suggestion of 34/30, a 4lb spread steers more neutral than a 2lb spread, which will hook your nose in more (not necessarily bad) when you come off the gas in a turn… personal preferences vary. Also, Im sure the 36/34 gets better gas mileage, but worse rain and snow perfomance. A 30 rear will hang on in snow much better. Try the chalk, you’ll enjoy it :-) Jonathan |
08-08-2003, 11:50 AM | #5 |
Member#: 3441
Vehicle:05 OB XT Blk |
Read my description of the Conti's in Jonathan's thread.
08-09-2003, 07:48 PM | #6 |
Member#: 11989
Vehicle:2006 LegacyGT LTD Brilliant Metallic Silver |
I run Conti's 205-55-16 at 36F 34R. Any higher and you lose traction and braking suffers.
I have a 2002 RS with the SPT strut spring kit, 20mm rear bar, 99 RS wheels, and 4pot fronts. Last edited by Yebisu69; 08-09-2003 at 07:56 PM. |
08-10-2003, 12:41 PM | #7 |
Member#: 24546
BAIC
Vehicle:2009 WRX Silver |
I just bought 4 225/40/18 new from a dealer and all of them are out of round. They all had major runout and could not be balanced, which gives a mean shake on the freeway. I was told by the dealer that this has happened more than once with these tires. I am getting them replaced by another brand. Just a heads up.
mark |
08-14-2004, 04:53 PM | #8 | |
Member#: 31835
Vehicle:2002 WRX WRB |
I like my ContiExtremeContacts
I have the same size contis that you do and I haven't had any problems...purchased from discount tire. I have read that the tires need more pressure than most. I run 40 in front and 38 in back. My personal reason is because the conti's sidewall is not that stiff and the extra pressure gives you a minor degree of extra protection from pot holes. I don't track the car...just hall a$$ to and from work.
Question for owners of BSM or CGM colors | 24 | General Community | 9 | 12-05-2005 09:08 PM |
Question for owners of deadbolt's Monster TD04 | Hank3 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 17 | 03-13-2004 04:53 PM |
Question for owners of the WRX OEM bodykit | Hank3 | Interior & Exterior Modification | 7 | 09-19-2003 06:57 PM |
Question for owners of kappa 62.5 | paulatwork | Car Audio, Video & Security | 1 | 03-06-2003 07:00 PM |
Question for owners of an RS w/ 4EAT | ivbdn | Normally Aspirated Powertrain | 8 | 07-26-2001 02:01 PM |
