03-09-2009, 02:37 PM | #1 |
Member#: 173738
VIC
Vehicle:STG2 93' Legacy SS Can't thouch This |
Stripped the hex fitting on top of strut ???
what to do?
i threw a pipe wrench on the top of the strut to keep it from spinning, didnt want to grab though. i am trying to break the nut free to swap springs. |
03-09-2009, 02:42 PM | #2 |
Member#: 105104
VIC
Vehicle:1979 BRAT / 01 RSTI 99 2.5TS (DEAD) |
you pretty much have to use an impact gun now...
and i actually separated a set of struts with the intent of shipping them to you however i quickly realized that i had just taken apart the rear and you need fronts right...? then it started to snow so i retreated indoors... |
03-09-2009, 04:55 PM | #3 |
Member#: 173738
VIC
i was looking for rear sti 02 03 springs.
so now i need a 16mm impact socket. any other ideas before i go this route? i was thinking of lightly disc sanding underneath the bump stop so my pipe wrench could grab? |
03-09-2009, 05:10 PM | #4 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Instagram | arthurlam89 |
If you stripped the allen head I doubt a pipe wrench would have enough grip to prevent it from spinning.
Use an impact gun. It will come off in like 2 seconds. |
03-09-2009, 05:37 PM | #5 |
Member#: 4718
VIC
Vehicle:I gotz a Subaru again |
+1 for the impact gun.
I wouldn't do most suspension removal without one. |
03-09-2009, 06:57 PM | #6 |
Member#: 166183
VIC
Vehicle:2007 2.5i SE Newport Blue |
+1 impact gun
If you need to rent and electrical one and don't mind coming up to Burnaby, lemme know. You can pay me in beer. -Tim |
03-09-2009, 08:50 PM | #7 |
Member#: 173738
VIC
okay, i burrowed one from work and bought a 16,17,and 19 mm impact sockets to add to the set.
and a 3/4 to 1/2 adapter. i wish my compressor was working. thanks for the offer tim. i'm going to work on it in a couple minutes. whoa, is this guy new this is like some ymca **** |
03-09-2009, 11:32 PM | #8 |
Member#: 173738
VIC
alright, got er done. the one strut that i stripped is trippin me out. it had a slightly smaller size hex hole than the other 3. i think it would be a 5.5 or 6.5mm hole. so after a good 10 minutes of almost pure impact gun the nut was finally almost off. it took so long because the strut spun freely.
it is still a bitch to get the nut back on because it just doesnt want to spin on easily, the threads look fine on the nut and strut and i have no idea how im going to torque it to spec. at least it is a front one so it is easily accessible once installed. btw i bought these used and are already off the car for me to work on. my route for the other three worked out great. i simply layed the strut on the floor and cracked the nut loose with a 17mill. after that i used my hex key attached to vise grips and a socket with a pipe wrench to easily work the nuts off the rest of the way. now i just have to swap my rear tops on to the new rear struts and it's time for the swap. thanks guys for ur help Last edited by Joynt93; 03-10-2009 at 12:49 AM. |
03-10-2009, 12:02 PM | #9 |
Member#: 166183
VIC
When you're impacting that nut off and on, do it in short pulls. Spinning up the shaft enough can kill the seal at the top.
I used soapy water to clean a rubber dishwashing glove and the shaft. Then grab the shaft with your fingers and have somebody else apply impact. -Tim |
Similar Threads | ||||
Stripped allen/hex hole on freeze/core plug, any ideas? Block heater install woes. | roninsoldier83 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 38 | 02-12-2014 03:18 PM |
I just stripped the hex off a lug | Sonic Yellow 2K3 WRX | Tire & Wheel | 20 | 11-17-2003 05:20 PM |
What's the purpose of the coolant reserve tank/header tank on top of the engine? | garface | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 08-28-2003 01:47 PM |
dust caps on top of the front struts | tmat3 | Brakes, Steering & Suspension | 0 | 05-10-2002 11:11 AM |
Guage package on top of dash fit TV? | Sobelizard109 | Car Audio, Video & Security | 1 | 11-02-2001 07:59 PM |
