10-13-2014, 10:33 PM | #1 |
Member#: 352704
VIC
Vehicle:1965 Vw panel bus with an EJ20 Turbo Swap |
Draining the oil to the oil filler ?
Do you think it would be ok to drain the oil from the turbo to the oil filler where the valve cover is? My turbo is pretty high on my conversion and might be easier for plumbing and have it drain to the oil filler rather than the oil pan.
10-13-2014, 10:53 PM | #2 |
Member#: 60415
Vehicle:1973 Gran Torino Green w rust coloration |
Are you swapping an EJ engine into your VW? I don't have an answer, but curious. I would think the only real concern though would be the o-ring on the filler neck possibly leaking, but the returned oil is not pressurized, only hot.
10-13-2014, 11:10 PM | #3 |
Member#: 348254
SCIC
Vehicle:2013 WRX SWP |
Not the best idea. People were trying to do this on miata's a while back when I was working on turbo charging them. Not sure how people were securing them, but there were a few cases of the hose working free.
Just curious, why do you not want to tap the pan? |
10-14-2014, 12:16 AM | #4 |
Member#: 347470
panel. you can also tap a valve cover. i run a drain from 1-3 to sump. subaru is the same with windage as vw ,so tap the 2-4 side.
10-14-2014, 01:24 AM | #5 | ||
Member#: 352704
VIC
Yes
10-14-2014, 01:27 AM | #6 |
Member#: 352704
VIC
If I did it to the filler I'd be using one of these to the side of it.
10-14-2014, 06:59 AM | #7 |
Member#: 60415
10-14-2014, 02:55 PM | #8 |
Member#: 347470
