Old 09-11-2012, 02:08 PM   #1
03boxer4
Member#: 66622
2002 WRB wrx
Default Windsheild Wiper question... wipers going past the windshield?
alright, last winter I had a lot of ice here in the midwest... it built up under the wipers and I believe pushed them off track, or broke something.
They still work, but when you turn them on, they either dont go all the way to the side of the windshield like their normal path, or they go past the edge of the windsheild, and hit the pillar... and sometimes they dont go back down all the way and come to rest towards the bottom of the windshield, but still in view.
What could this be? linkage?
and if it is the linkage... do you think an 04-07 linkage would work in my 02? since they are technically the same?
Thanks guys
03boxer4 is offline   Reply With Quote
Old 09-11-2012, 03:20 PM   #2
yellowscoob
Member#: 331877
Blaze Yellow
This started happening to my wife's 02 WRX.. was scraping up the pillar on the drivers side. I popped the hood, popped out the black circular plastic covers near the base of the wiper and tightened the nut holding down the wipers.. they work good now. stay right where they are supposed to.
yellowscoob is offline   Reply With Quote
Old 09-11-2012, 03:22 PM   #3
03boxer4
Member#: 66622
2002 WRB wrx
EXACTLY what is happening to mine. Pillar too
Thanks, I will get on that tonight asap.
Old 09-12-2012, 12:23 PM   #4
billzebub
Member#: 40248
2003 WRX
Midnight Pearl
I keep saying this and the radiator explosion and the front wheel bearing all need to be stickied.
http://forums.nasioc.com/forums/showthread.php?t=676373
billzebub is offline   Reply With Quote
Old 09-13-2012, 03:25 PM   #5
03boxer4
Member#: 66622
2002 WRB wrx
Man that is A LOT of trial and error... where is the actual solution in that thread lol.
Old 09-13-2012, 11:01 PM   #6
Phuie72
Member#: 324953
2012 Wrx
Grey
Either the base of the wiper arm is stripped or the bolts are loose. Easy fix but very aggravating when they hit the a pillar.
Phuie72 is offline   Reply With Quote
Old 09-14-2012, 12:34 PM   #7
03boxer4
Member#: 66622
2002 WRB wrx
After reading further, this is false. The bushings are most likely the problem and a set of jeep bushing and some elbow grease is in order
Old 09-16-2012, 12:08 AM   #8
Phuie72
Member#: 324953
2012 Wrx
Grey
Got ya. The bushing underneath where the arm meets the cowl? Hopefully so, that would definitely end up a bit cheaper than new wiper arms.
Old 09-17-2012, 07:17 PM   #9
03NJWReX
Member#: 298655
03 WRX
WR Blue
I had this problem at the beginning of the summer. I tried simply tightening the bolt that hold the wiper arms to the wiper transmission but that didn't work. When your wipers are at rest do they have a lot of play in them, can you wiggle them up and down the windshield easily? If so you might have a busted bushing in the wiper linkage. Thats what my problem was. Here are some pictures from when I fixed it.
You can see the top joint is completely separated from the bushing
I bought a whole new linkage from the dealer... Old vs New
03NJWReX is offline   Reply With Quote
Old 10-02-2012, 04:12 PM   #10
jdmjack
Member#: 248430
2003 PSM Bugeye
^So you just bought new linkage and that was it? That comes with new bushings, etc? How much $ if you don't mind me asking?
jdmjack is offline   Reply With Quote
Old 10-02-2012, 04:30 PM   #11
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
List price $117
Old 10-03-2012, 11:23 PM   #12
03NJWReX
Member#: 298655
03 WRX
WR Blue
Yeah i just bought a new linkage from the dealer, cost about $160. Apparently they don't sell the bushings by themselves. If you are really tight on cash i saw a guide online, can't remember the site, where some guy hacked up some generic bushings and got them to fit/work. I didn't feel like going through that hassle and figured the money i saved by doing the work myself was good enough.
Old 10-05-2012, 02:39 PM   #13
rick-l
Member#: 33868
2003 wrx
srp
Do the good bushings in the old assembly come out in one piece? I see a way to recover some of your cash outlay.
rick-l is offline   Reply With Quote
Old 10-05-2012, 08:34 PM   #14
nftyper
Member#: 77269
2002 WRX Wagon
I just ordered the linkage. Was gonna attempt to fix it but subarugenuineparts.com has it for $95 shipped.
nftyper is offline   Reply With Quote
Old 11-11-2012, 04:21 PM   #15
nftyper
Member#: 77269
2002 WRX Wagon
Anyone know or have links on how to take the cowl off?
Old 11-11-2012, 04:31 PM   #16
aod12
Member#: 282701
2008 Impreza 2.5i
Dark Grey Metallic
A guy I knew had the bushings crap out on his wipers. We took the old one out and with lots of elbow grease, pliers, a hammer, and an assortment of profanities we were able to install a bushing in. From what I remember it was meant for Nissan but was the right size. Cost $3 at NAPA. The trick is to take your time and do it firm but gently.
aod12 is offline   Reply With Quote
Old 11-11-2012, 05:41 PM   #17
nftyper
Member#: 77269
2002 WRX Wagon
nevermind, got it. Push up clips on the bottom of the rubber molding and pull the cowl off. Now i gotta align the wiper sequence.
Old 11-19-2012, 06:50 PM   #18
rebornS14
Member#: 338337
1997 S14
Thanks guys
I LOOKED UP THE PART #'S ON THE 02 AND 05 AND THEY ARE DIFFERENT# AND LOOKS DIFFERENT TOO
2002 WRX 86521FE010 :LINK AY WINDSHIELD $116.57
2005 WRX 86521FE090 :LINK AY WIPER DRIVER $116.57
IF I WERE TO BUY NEW ONES, I WOULD GET THEM SPRAYED WITH THAT STUFF THEY OFFER AT THE DEALERSHIP FOR RUST OR EVEN JUST SPRAY IT WITH SOME PAINT JUST TO GIVE IT THE EXTRA PROTECTION
rebornS14 is offline   Reply With Quote
Old 11-19-2012, 06:54 PM   #19
aod12
Member#: 282701
2008 Impreza 2.5i
Dark Grey Metallic
You should get your keyboard checked out, caps lock key seems broken.
Message Board Statistics All times are GMT -4. The time now is 11:32 PM.
