07-25-2005, 07:04 PM | #1 |
Member#: 9689
Vehicle:1998 Legacy GT Silver |
17" for the Legacy?
Looking at upping the wheel size to 17" and have a few questions.
I like the Superleggeras from O.Z. but I don't like the price ($229/rim). I like some of the rota wheels (tarmac, torque) but notice that the dimensions are 17x7.5. Will 7.5 rub? does anyone know where I can find a color chart for the multitude of finishes available on the rota's? (side by side comparo?). Also, other recommended wheel brands that have similar styling? thanks for putting up with an age old question that I couldn't find a direct answer to searching.
07-25-2005, 07:15 PM | #2 |
Member#: 53410
SWIC
Vehicle:BE-> GD->GR->SG->BL WAawd.org |
7.5 fits the BE's fine. I'm very happy with my rotas, and the low price is a bonus.
fibuz |
07-25-2005, 07:21 PM | #3 |
Member#: 5851
VIC
Vehicle:17 Ford Escape SE Blk |
They will fit your car, I've had some on Bd/BG's previously. As for colors subydude is the best place to check out for them on cars and the vcarious colors available.
07-25-2005, 08:31 PM | #4 |
Member#: 60224
SubyDude's got a bunch of great Rota pics and a fitment chart you can reference:
http://www.subydude.com |
07-26-2005, 02:05 PM | #5 | |
Member#: 5039
South East
Vehicle:2007 Outback XT Grey 5-speed (sold) |
CN: Look more at tire width and wheel offset to see if a tire/wheel will rub. ss |
07-26-2005, 04:16 PM | #6 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
Here's a good link to check if you have the right tire fitment:
http://gs.tolan-hoechst.com/tirecalc.htm |
07-27-2005, 01:58 AM | #7 |
Member#: 70418
Vehicle:1968 Ford Bronco 2000 2.5RS Sedan |
man, thats an awesome page! thanks!
07-27-2005, 03:05 AM | #8 |
Member#: 53410
SWIC
that is a great site, bump for threads to note nomination?
07-27-2005, 08:53 AM | #9 |
Member#: 1594
Vehicle:1999 2.5 RS 2002 Legacy |
Got 17x8 or don't bother IMHO. Lots of room on the Legacy. No reason not to go wider. 235/245 size tires would be a must IMHO too.
Once the tires are worn on our 17x7.5" rotas on our BE, I'm going to try hard to convince to wife to go 17x8 or 17x8.5 for wheels and some 245/40-17 tires. |
07-27-2005, 09:51 AM | #10 |
Member#: 86621
Vehicle:95 If it brakes Mod it |
I have 17X7 Enkei RSV with Yokohama Pradas and they rub with people in the back seat when I hit bumps or go around turns
07-27-2005, 10:06 AM | #11 | |
Member#: 36735
07-27-2005, 10:47 AM | #12 |
Member#: 73102
Vehicle:1998 legacy outback white |
i'm running 17x7.5 with a 225/45/17 on my 98 outback no rubbing at all. gold rota tarmac 2s. it looks fabulous.
07-27-2005, 10:58 AM | #13 | |
Member#: 374
SWIC
Vehicle:'98 2.5 GT Wagon Rio Red |
As always, though. YMMV. Edit: That is a great page! - Eric Last edited by Radio Flyer; 07-27-2005 at 11:11 AM. |
07-27-2005, 12:07 PM | #14 |
Member#: 9689
Yes thanks for that link!!
Rota's it is then. Thanks! peace, Oquipah |
07-27-2005, 12:59 PM | #15 | |
Member#: 5039
South East
I got rubbing on a 205-55-16 on a +53mm 16x7 RS wheel when the rear was dropped with a Ver7 STi suspension. It was catching on the very outside corner of the tire on the inside edge on the trim. A little more camber would have solved it had I kept the setup, but that gives you an idea how prone to rub the BD/BGs are, specifically the rears. ss |
07-27-2005, 04:27 PM | #16 |
Member#: 9689
Hmm...So let's say I will be putting KYB Gr2's on all four corners with either H&R Sport or Eibach Pro-Kit springs taboot. What issues might I have with the 17" rims?
Would an Camber adjustment correct or eliminate any rubbing issues? Sorry perhaps I should be posting in the newbie forums, I have no experience with new wheels. Thanks, Oquipah |
07-27-2005, 05:14 PM | #17 | |
Member#: 5039
South East
I basically agree with what Eric wrote above. If you have absolutely ideal offset for our cars(say +55mm) you can pull off a 225/45-17 on any rim width between 7 and 8"(again rim width basically doesnt matter, although it can have some effect on tire shape and performance) unless you absolutely slam the car. If you are running a +48mm offset wheel on a moderately lowered car, consider a 215/45-17 instead of a 225. Even with a 215/45-17 on a 48mm rim, if you lower it enough you may need to roll the fenders and/or run some more camber at the rear. Rolling the fenders gives ~3/4" of additional lateral clearance at the fender lip - which is a good bit. I havent moved up to 17s largely because I havent been able to find a wheel in a BD/BG friendly offset yet I want. I have been searching for a set of dark grey B4/GT-B wheels but havent found a set. I briefly had a set in champagne but they didnt go well with my car color IMO. They are 17x7 +53mm for reference. If I do find them I will be running 215/45-17s on them. ss |
07-28-2005, 01:28 PM | #18 |
Member#: 9689
What is the stock/OEM wheel offset on 16" Legacy GT rims? The Rotas are 48.
Oquipah |
07-28-2005, 01:33 PM | #19 |
Member#: 67154
Vehicle:2007 Audi RS4 Avus |
AFAIK the stock BD/BG GT rims are 16x6.5 et53, the stock BP/BL GT rims are 17x7 et55
07-28-2005, 01:38 PM | #20 | |
Member#: 5039
South East
ss |
07-28-2005, 02:00 PM | #21 | |
Member#: 36735
Stock GT alloys are 16x6.5 ET55 |
07-28-2005, 04:33 PM | #22 |
Member#: 9689
Thanks for the stock GT rim measurements.
I plugged the info into the spreadsheet from above posts and into the one linked below as follows: Initial Information (Stock Rim) Tire : 205/55r16 Wheel diameter (inches): 16" Wheel width (inches): 6.5" Wheel offset (mm): 55 Proposed Information: (Rota) Tire : 225/45r17 Wheel diameter (inches): 17" Wheel width (inches): 7.5" Wheel offset (mm): 48 http://www.1010tires.com/WheelOffsetCalculator.asp It appears that in wheel difference I will be gaining 6mm clearance from strut and losing 20mm on the fender side. That seems like a lot? I am an idiot when it comes to this topic apparently and I appreciate your assistance to make sure I don't get a wheel package that doesn't work. Thanks again, Oquipah |
07-28-2005, 05:04 PM | #23 |
Member#: 36735
On stock suspension you should be fine. 20mm isn't a great deal to lose - grab a metric ruler (or convert it) and check your car - it'll be fine.
The only issue would be if you lowered the car more than 1-1.5" IMHO... |
07-28-2005, 05:14 PM | #24 |
Member#: 5039
South East
My rough quick calcs say thats correct and I dont mean to disagree, but 20mm is quite a bit and on our cars with a moderate drop(1") enough to rub on turns/laden.
ss |
07-28-2005, 05:20 PM | #25 |
Member#: 36735
You may be right...my previous experience with lowering was with a GC Impreza...but the rear section on the BD looks very much the same to me.
That said, I was using 215/40/17 on an ET45 wheel... |
Similar Threads | ||||
Trade: My Prodrive P1 anthracite 17" for your Legacy GT 17" wheels+tires | Orson | Private 'For Sale' Classifieds | 10 | 02-11-2005 12:49 PM |
Foglights on with parking lights mod for the legacy? | SubaTubaru | Legacy Forum | 7 | 01-17-2003 10:16 PM |
What is the Spring Rate for the Legacy H&R Sport Springs | MY99 2.5GT | Brakes, Steering & Suspension | 5 | 06-19-2001 10:01 AM |
Corbeau Seats for the Legacy for Sale | chris300zxtt | Legacy Forum | 4 | 01-10-2001 02:14 PM |
Tire / Wheel sizes for the Legacy | Radio Flyer | Legacy Forum | 3 | 01-20-2000 04:33 PM |
