08-25-2007, 12:37 AM | #1 |
Member#: 110079
SWIC
Vehicle:06 WRX Black on Black |
06 Clutch gone at 20k
So I've had a super stiff clutch pedal since I've owned my car (about a year and a half) and I finally had it looked at the Dealer wednesday. (late, I know. I had a suspicion I had an aftermarket clutch slipped in from the factory or something ) Immediately the tech says that my pressure plate is probably messed up and that is happens once in a while. Next day I get a call and apparently my clutch is down to the rivets and my flywheel is totally hot-spotted I didn't believe it until I saw it with my own eyes, but yes, the friction material was completely gone. I can't believe it was even holding up until then. It held fantastic right up until they took it out. I am getting charged $200 to replace it with a new clutch, flywheel and pressure plate. Which doesn't seem too outrageous even though it is under warranty. I was going to go the upgraded clutch route but I just didn't feel like spending 1k to get a decent clutch + flywheel package. (ACT stage 1 with Streetlite) They would still charge the $200 even if I bought my own clutch to install so I just said F it. I am pretty sure that the problem with the stiff clutch pedal had something to do with the untimely demise of my clutch. I'm not THAT hard on it and I would expect it to last longer than it did regardless of my driving style. I suppose that is why they are fixing it for so cheap.
06 WRX Stock power for 1k miles Stage 2 for 19k miles 250 whp 315 wtq for 2k miles Use: A few mild launches, slipping the clutch a bit and mainly city driving with a few long road trips mixed in.
08-25-2007, 01:13 AM | #2 |
Member#: 154066
Vehicle:06 WRX Red |
yeah i have a 06 wrx stage 2 i burnt my clutch up in 10,000 miles.. but didnt even go to the dealer for it and ended up putting in the exedey stg 1 clutch in. luckfully i didnt burn up my flywheel so i was happy.. and the new one feels great!! with 23,000miles on my car now
08-25-2007, 01:16 AM | #3 |
Member#: 60142
Vehicle:2011 WRX Grey |
Write the check - a new stock clutch is all you need at that power level and for your driving style.
08-25-2007, 04:35 AM | #4 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
mine gone at 16k....dealership put in new one
08-25-2007, 07:16 AM | #5 |
Member#: 136314
Vehicle:2014 Grand Cherokee |
08-27-2007, 09:20 AM | #6 |
Member#: 157634
RMIC
Vehicle:2007 STi CGM |
Clutch gone
I'm in the same boat. I think my clutch will go to 25K. How does Stage 2 not void your warranty?
08-27-2007, 10:14 AM | #7 |
Member#: 109216
Vehicle:08 STI DGM 76-77 Lancia Scorpion(s) |
Interesting... my clutch feels very stiff, a lot of stiffer than a lot of other cars... maybe I should get it looked at...
32k miles and it feels like it grips absolultely fine... |
08-27-2007, 10:55 AM | #8 |
Member#: 136998
South East
Vehicle:06 30R STi OBP |
mine was gone at 6K, absolutley NO launching, never tracked, denied waranty because of turboback i installed THE NIGHT BEFORE. almost 1,800 to have the new stock clutch and flywheel put in at the dealer. you got lucky my friend.
08-27-2007, 11:16 AM | #9 |
Member#: 118827
Vehicle:2006 WRX Limited CGM |
pretty cool that the dealership stuck to the warranty even tho you're stage 2, im assuming they could get around it.
08-27-2007, 11:39 AM | #10 |
Member#: 2348
Vehicle:2006 WRX TR Steel Grey Metallic |
wow, how are you guys killing your clutches so fast..15k miles no problems (knocks on wood)
08-27-2007, 12:13 PM | #11 |
Member#: 146137
Vehicle:06 WRX R.I.P. 06.06 - 10.08 |
maby it has something to do with being a paranoid 06 5mt owner. i know myself, as well a many others, would rather slip the clutch a little nad have it replaced every 20k for $200 rather than destroy my tranny. like unabomber says, clutches are cheaper than gears.
08-27-2007, 02:31 PM | #12 | |
Member#: 120057
Vehicle:2018 WRX (base) 6spd WRB |
That is why you replace it with the stock clutch(which is exedy) |
08-27-2007, 03:05 PM | #13 |
Member#: 24038
South East
A stage II 2.0l is bottom end and mid-range equal to the 2.5l's. Plenty of us have 100K+ on our clutches (with lots of autox/track etc. etc. on them). Not to mention the higher powered cars.
There is something wrong with the driving if you're killing the clutch so fast. ESPECIALLY on the stock engine, and even at stage II torque, there's no reason you should be killing on in 20k miles. That's crazy. Destroying gears tends to occur after damange from fast shifts or dropping clutches. Unless all of you guys are drag-strip regulars, there is something wrong with your DD technique. My buddy is on 50k + with his 06 stage II. Any bets he'll go to 100k+? (His last RS went 150 on the OEM before he sold it.) It's the driving |
08-27-2007, 07:35 PM | #14 |
Member#: 110079
SWIC
My Pressure plate was screwed up and that is what caused the premature wear, and why they decided to warranty it even though my car is modified.
It's not at stage 2 power level either...It's got a VF-29 made 315 wtq on a low reading mustang with only minor tuning. No doubt my driving puts more stress on the clutch than normal. I drive almost all city, and launch my car using the old clutch slip quite a bit. I wasn't suprised to see that it needed to be replaced at all. Relieved they decided to warranty it though! |
08-28-2007, 10:16 AM | #15 |
Member#: 146091
NWIC
Vehicle:14 Mazda 3 Red |
i just replaced my clutch at 27k... not b/c i needed one, but b/c of all the horror stories you here about burning up clutches on dynos after bigger turbo installs.
my stock clutch was in great condition, i was very happy to see how much friction materail was left... i am keeping as a replacement part if the new goes anytime soon (ACT street clutch/fly) |
08-28-2007, 12:45 PM | #16 |
Member#: 107097
Vehicle:09 Etnies Gray/Black |
My 06 was on stock for 2k miles, stage 1 for 9k stage 2 for about 10k, and i've been on a big 16g putting down your same numbers for about 5k miles before it went into to the dealer for the trans. when i took it in for my trans rebuild at 26k they said the clutch was on it's last leg. And that I needed a new flywheel, pressure plate, and clutch, also had a stiff pedal since i purchased it. when I replaced the clutch at 34k miles after a couple of track days, the clutch was not even 1/3 worn. the flywheel, and pressure plate were perfectly fine (few hot spots here and there).
I've heard a lot of stories about premature wear, but yours is one of they few with actual confirmation of total wear. I |
08-28-2007, 12:47 PM | #17 |
Member#: 107097
If you're not experiencing any problems with it, I wouldn't advise letting the dealer muck it up.
Dealer 06 WRX With clutch replaced at 60k | Hotsho111 | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 8 | 05-31-2009 10:54 PM |
Clutch gone at 18k on a new 07? | PiNPOiNT | Warranty Issues & SOA Problems | 6 | 01-05-2008 09:44 PM |
'o5 LGT Review in C&D: Clutch gone at 36K | fdg008 | Baja Forum | 0 | 07-30-2006 05:56 PM |
Clutch gone at 45 000km. | Flexy | Transmission (AT/MT) & Driveline | 11 | 04-27-2003 10:20 PM |
