01-12-2007, 10:16 PM | #1 |
Member#: 94597
TXIC
Vehicle:2003 Corvette Z06 Black/Black |
HELP! My trunk won't open!
I have a Seibon CF trunk, which has had no problems thus far. Yesterday before I left on leave, I put my tool box and some other things in the trunk, no problem. About 10 minutes into my drive I went to get a rag out of the trunk to wipe off my windshield and the trunk wouldn't open. I pulled the latch, but when I pulled it it pulled and felt as though the trunk was already open (no thunk)...but it wasn't. Has anyone experienced this or something similar and what was the problem? It feels almost as if the trunk release cable is messed up.
01-12-2007, 10:22 PM | #2 | |
Member#: 131299
NESIC
Vehicle:2006 Impreza Aspen White |
01-12-2007, 10:31 PM | #3 |
Member#: 115291
Vehicle:2003 MBP WRX COBB Stage II |
01-12-2007, 10:33 PM | #4 |
Member#: 94597
TXIC
Right, but I have a Seibon CF trunk. It has no keyhole, and as far as I know - no safety lever thing that is on the stock trunk (I know about the lever). I could be wrong about the lever if someone knows for sure if it does or doesn't that would be great.
01-12-2007, 10:35 PM | #5 |
Member#: 115291
hmmmm now I have no clue. good luck
01-13-2007, 05:13 AM | #6 |
Member#: 94597
TXIC
to the top...i will be on the road for another 300 miles this morning. if anyone knows the answer please give me a holler..2542478396
01-13-2007, 06:50 AM | #7 |
Member#: 94447
Vehicle:2005 2.5RS PSM |
im in the same situation
my trunk wont open! |
01-13-2007, 07:17 AM | #8 |
Member#: 116636
Vehicle:2003 impreza black |
do you have that center section acess from the back seats? find a small child if ya do, if not im gonna have to say your kinda ****ed
01-13-2007, 09:48 AM | #9 |
Member#: 64226
NESIC
Vehicle:2004 Impreza WRX World Rally Blue |
It really does sound like the lever. Just take out your back seats (which is about a 10 minute operation providing you have the right tools- just a socket wrench), have a small child climb in and try to open it that way. The latch must still be there even though the keyhole isn't, otherwise how would your trunk stay shut?
01-13-2007, 10:15 AM | #10 |
Top Scoob 024
Member#: 56364
International
Vehicle:RIP stompr :( bagged vulvva |
or find something long to reach it from the backseat, i used a wooden dow to unlock mine.
01-13-2007, 02:00 PM | #11 |
Member#: 116636
perfect job for the trunk moneky!
01-13-2007, 02:03 PM | #12 |
Member#: 94283
NESIC
Vehicle:'19 Ascent |
Damn, I was thinking you might have sent this message from your phone because you were stuck in the trunk.
01-13-2007, 02:04 PM | #13 |
Member#: 116596
South East
Vehicle:2012 STI SWP |
01-13-2007, 02:07 PM | #14 |
Member#: 96315
SWIC
Vehicle:1995 STi V5 replica World rally blue |
defenatly take your back seats out and crawl into your trunk and unlatch it with your finger, look for the lever on the right side of the trunk lock, i belive it should be pushed down to enable the pull lever from the inside.
01-13-2007, 02:45 PM | #15 |
Member#: 39905
NWIC
happend to me once when i didnt have my sub box bolted down. you hav to climb in the trunk and mess with the lock
01-13-2007, 02:51 PM | #16 |
Member#: 94597
TXIC
right but does the CF trunk have the same safety lock?>
01-13-2007, 03:19 PM | #17 |
Member#: 39905
NWIC
01-13-2007, 06:11 PM | #18 |
Member#: 1403
TXIC
Vehicle:99 RBP GC8 Impreza |
You have to adjust the position of the latch mechanism or tap it to flatten it
out a bit (off of the trunk mind you). It bolts right in and close just fine but thats when you get caught! Sometimes they just don't come out of the moulds quite right. |
01-13-2007, 06:13 PM | #19 |
Member#: 1403
TXIC
Oh, and make sure you chek it from inside the trunk with a flashlight. Have a
budd pull the lever while you observe the latch to make sure it is good to go. |
01-13-2007, 07:05 PM | #20 |
Member#: 94597
TXIC
can you explain this a bit more in detail, i am not picturing in my mind what you are trying to convey.
01-13-2007, 07:06 PM | #21 |
Member#: 94597
TXIC
01-13-2007, 10:22 PM | #22 |
Member#: 1403
TXIC
Okay...
I'm reffering to the actual latching mechanism that attatches to the trunk. You had to bolt this onto the new trunk when you swapped them. If it's not in the correct position, it will not open properly. You should also know though that from time to time, the cable can get stretched for whatever reason. Make sure that you do not have a bunch of play in it. |
01-14-2007, 09:26 AM | #23 | |
Member#: 94597
TXIC
01-14-2007, 12:22 PM | #24 |
Member#: 94447
^^^ i need to know how to tighten up the cable too
mine is loose and the trunk release wont open up the trunk anymore |
01-14-2007, 12:38 PM | #25 | |
Member#: 1403
TXIC
You got me on that one though. I never had the issue of my cable stretching out (yet ). I know some others just had it replaced under warranty. Make sure that is your problem first though. |
Trunk won't open....Help!!!! | jmpdave | Tri-State Area Forum | 3 | 03-22-2010 02:59 AM |
HELP My trunk wont open! | bkikawa7 | Interior & Exterior Modification | 21 | 08-15-2009 06:34 PM |
Trunk won't open when I lift the trunk lever | Buktheng | Service & Maintenance | 5 | 11-22-2008 03:26 PM |
Trunk won't open... | ignitor | General Community | 12 | 02-11-2005 01:45 PM |
Trunk won't open coz I got too much junk in cargo net. | Snoopy | Off-Topic | 15 | 01-12-2004 09:32 AM |
