06-28-2010, 01:41 PM | #351 |
Member#: 56183
South East
thanks unabomber for being so humble i win i will honor you in my signature
07-09-2010, 11:10 AM | #352 |
Member#: 164267
International
Vehicle:2011 Forester S-E Black |
Brazilian 09'Forester XT
Hello everybody!
I have a 09'Forester XT in Brazil. Now I have to do the 30.000km inspection and the dealer in Brazil insists that I have to change the engine coolant to keep the warranty. Here in Brazil we don't have a "Subaru of Brazil" just a representative company that import Subaru (and Hyundai too ). Considering that all 09 subies use the Subaru Super Coolant, why would I need to change the coolant in Brazil? Does anyone know if Subaru uses a different engine coolant for cars that come to Brazil? My VIN number beginnings with JF1SH9LT59G..... I appreciated any comment. Cheers. Cassiano |
07-09-2010, 11:12 AM | #353 | |
Member#: 56183
South East
07-09-2010, 11:25 AM | #354 | |
Member#: 164267
International
Anyone has a contact of International Subaru? I already explain this to the dealer but he says that is the policy for not loose my the warranty. He just says: "It's the due to the maintenance schedule in Brazil" Thanks!! |
07-09-2010, 12:23 PM | #355 |
Member#: 17328
Vehicle:2002 WRX Wagon 4EAT Appliance White |
Do you have a copy of the owner's manual?? Just show them the maintenance schedule in the book. Proof enough!
Also, have them show you any legal documentation from Subaru that states the BS they are telling you! |
07-09-2010, 12:42 PM | #356 | |
Member#: 164267
International
07-12-2010, 12:49 PM | #357 |
Member#: 183633
TXIC
Vehicle:'06 Cobb STG2 Wagon WR Blue of course! |
Normal coolant temp?
This question may have been answered before, but I just searched and didn't find it. I just changed my coolant with 50/50 Subaru OEM coolant ('06 WRX, stock power except Cobb turboback and APv2). I haven't seen any indication of overheating on the dashboard temp gauge, but I'm paranoid, so I'm reading the coolant temp with my Accessport while I drive around. The highest temp I saw under normal driving was 201 F.
What is the normal operating temperature that I should be reading with my AP? If it's reading 200+ should I be concerned with air bubbles still in the system? Thanks a lot! |
07-13-2010, 06:25 PM | #358 |
Member#: 241311
South East
Vehicle:95L V6WRXSTI type R HE?RP DERP |
help
i just replaced my coolant according to the diy on the link. and after i did it i ran the car and everything seemed fine. so i drove to qt and i noticed the coolant was leaking? so i drive home and it stopped. then it started all over again? is my water pump going bad? or did i over fill it?
http://www.iwsti.com/forums/newreply...te=1&p=2903815 |
08-27-2010, 07:54 AM | #359 |
Member#: 43853
NESIC
Vehicle:2004 WRX Sedan Stg 2 Platinum Silver |
So I need to replace my thermostat gasket and went looking for Peak Global and you cannot find this stuff anymore. This was readily available at Walmart for a long time. I called all around and found it at NAPA in concentrate form.
The Subaru super blue coolant is $22.95 a bottle. Are you kidding me?? If Peak Global is going away we may need to update the FAQ cause at the very least it is super hard to find. UPDATE: I found this stuff at a local autoparts store that supplies most of the repair shops in town. So I guess the chain stores will not this carry anymore so need to seek out the smaller places. Unfortunately the price is not Walmart cheap $7.50 v. $12, but still better than $23. Last edited by WRXSleeper; 08-27-2010 at 09:01 AM. |
08-27-2010, 08:18 AM | #360 |
Member#: 123843
NESIC
Vehicle:2016 STI LTD CWP Let LED's light your way! |
Here is an aftermarket alternative: Zerex® Asian Vehicle Antifreeze / Coolant
*5 year/150,000 Mile Guarantee *Recommended for all Asian Vehicles *Compatible with Asian coolants and cooling systems. *Silicate Free, Phosphated HOAT Chemistry *Protects against freeze-ups and boilovers *Protects against rust and corrosion *Premixed with demineralized water **Available by request through NAPA http://www.valvoline.com/products/br...antifreeze/105 |
12-01-2010, 09:34 AM | #361 |
Member#: 27724
South East
Vehicle:1970 F100 Black/White |
Thanks to this excellent FAQ and associated threads I was able to swap a Mishimoto and hoses into my '03 last night in 2.5hrs from opening the box to cleaning up after a test drive. I really appreciate all the effort that Unabomber has put into these documents.
The failure on my oem part was the same thing that a lot of others have experienced recently...fractured/cracked plastic end tank. Hopefully I'm good for another 125k now! |
12-11-2010, 04:46 PM | #362 |
Member#: 240684
Vehicle:2006 Impreza 2.5i Black |
I just had a coolant change by a mechanic a month ago, and the tube connected to the radiator got disconnected and sprayed coolant all over the place, so I lost a lot of coolant (it's now below the low line).
Can I just add coolant to the reservoir? Do I have to add the conditioner as well at this point? |
12-11-2010, 05:40 PM | #363 |
Member#: 50699
TXIC
Vehicle:2004 WRX Platinum Silver |
Depends on previous mixture. There is a device that you can get for a few bucks to check the mixture. Personally I would add water cause to much coolant is not good. Pure water is the best to run in a hot environment.
12-11-2010, 07:12 PM | #364 |
Member#: 240684
12-11-2010, 07:31 PM | #365 |
Member#: 50699
TXIC
Then try to keep the mix at 50/50 so you get the max antifreeze temp. the 70/30 is for hot climates that rarely freeze.
12-11-2010, 10:28 PM | #366 |
Member#: 216984
NWIC
Vehicle:1996 Impreza outback Green |
Ok guys, my car is being a pain in the butt... A little while ago, I had to change out the timing belt, tensioners and water pump and thermostat. I put everything back together along with putting new coolant in. Everything worked for awhile then I noticed the coolant getting lower at a very slow rate in the over flow tank. Well, I discovered that the upper radiator hose was not quite tightened down enough so I fixed that. Well, after a little while again, the coolant is getting lower in the over flow tank. I see nothing leaking any where now, I check the oil regularly and it's not going in there so this has me puzzled. The only other place that I can think of where the coolant could be seeping is through the little rubber gasket found in the idle air control valve unit as the coolant does pass through there at the throttle body. Right now the coolant is down like 3 cups maybe but is down none the less.
Any help would be appreciated! |
12-12-2010, 12:25 PM | #367 |
Member#: 27724
South East
Are you sure you had the system completely full the first time?
12-13-2010, 06:04 AM | #368 |
Member#: 216984
NWIC
^^^ I am pretty sure as it stayed the same level for almost 2 weeks. I keep checking the oil but nothing in there. And no leaks any where that I can see. Maybe some air trapped in the heater core not allowing me to completely fill it?
I however haven't added any coolant conditioner yet, so am going to get on it soon. |
01-07-2011, 11:34 AM | #369 | |
Member#: 175608
W. Canada
Vehicle:2006 Impreza 1998 Honda VFR 800FI |
Thanks. |
01-09-2011, 12:15 AM | #370 |
Big Ron
Super Moderator Member#: 18062
You missed this part: "The "best" coolant differs from stock SOA advice, so use at your own discretion"
03-21-2011, 04:27 PM | #371 |
Member#: 207528
Vehicle:2005 Legacy GT |
Here is an interesting 2010 article on coolants:
http://www.motor.com/article.asp?article_ID=1655 "..........In all the years we've been reporting on cooling systems, we've never seen the antifreeze situation more confusing......." |
03-21-2011, 07:48 PM | #372 |
Big Ron
Damn....I thought my confusing article was confusing but the link you posted makes me go cross eyed!
03-22-2011, 12:27 AM | #373 | |
Member#: 207528
03-22-2011, 01:00 AM | #374 | |
Member#: 207528
In Subaru TSB 09-42-05, from 2005, Subaru tells us: "Subaru Long Life Coolant is a phosphate (non-amine) type....................... If an equivalent must be used, make sure it is a phosphate (non-amine) type." I have never seen Subaru specify a non-phosphate Long Life coolant in a TSB, or in an EndWrench communication, or in the FSM, or in the owner's manual. Perhaps the blue Super Coolant is phosphate free ( ? ), but the green Long Life coolant contains phosphate, based on everything I have seen. |
03-22-2011, 01:55 PM | #375 |
Member#: 207528
Here is another excellent article (2004), from Motor Magazine, called "Coolant Confusion"
http://www.motor.com/article.asp?article_ID=816 "Japanese conventional coolants contain no silicates, but they do contain phosphates for fast-acting protection, plus other inhibitors. Extensive Japanese tests have shown phosphates to be a good corrosion inhibitor for aluminum, and particularly effective in protecting water pumps from corrosion after cavitation erosion/corrosion." |
Spark Plug FAQ: Read if you want spark plug information! | Unabomber | Service & Maintenance | 744 | 10-12-2023 04:31 AM |
Oil FAQ: Read if you want more information on oil, oil filters, and oil changes! | Unabomber | Service & Maintenance | 1079 | 08-29-2022 08:29 PM |
Tool FAQ: Read if you want information on Subaru specific tools and sundries | Unabomber | Service & Maintenance | 42 | 08-07-2022 11:49 PM |
Uppipe FAQ: Read if you are thinking of buying one! | Unabomber | Newbies & FAQs | 396 | 07-09-2020 02:25 AM |
