07-19-2007, 06:43 PM | #1 |
Member#: 148146
AKIC
What is the difference between a 2.5RS and a 2.5i Subaru Impreza?
hey there, I am just wondering what is the differnce between a 2.5RS and a 2.5i Subaru Impreza, besides the fact that the RS is older. And I would also would like to know, why don't they make so many parts for the 2.5i?
07-19-2007, 06:58 PM | #2 |
Member#: 149392
Vehicle:2007 2.5i Wagon New Port Blue |
Well the RS goes up to the 2005 model so it an't that old. But most RS parts are for the older RS Versions that pre date the WRX in north America. Also note the 2.5i means 2006 and 2007, so its still new, so not as much development time for that car as of yet.
The engine in the 2.5i is the iAVLS (http://en.wikipedia.org/wiki/AVLS) which is basiclay a version of honda's vtec. Like vtec all it dose is make the 2.5i engine more gas efficent at lower RPM's while allowing you to keep good power in the higher RPM bands. There are other things as well and it also matters what year you are talking about as between the 2.5i or 2006 and 2007 there are minor differences apparently, tho none I know of. In the end the 2.5i is the continuation of the RS line, just re badged. |
07-19-2007, 07:33 PM | #3 |
Member#: 129715
Vehicle:03 Wagon Silver |
Searching is your friend. Looks different...slightly stronger motor due mainly to the equal length headers as opposed to uel's.
07-19-2007, 08:44 PM | #4 |
Member#: 148146
AKIC
okay thanks, for the answer
-Robert Hinh |
07-22-2007, 10:35 PM | #5 |
Member#: 36629
Vehicle:07 2.5i Regularly Being Modified |
The 2.5i does not have a throttle cable. All electronic Drive-by-Wire.
I personally would prefer the old fashioned cable. |
07-23-2007, 12:00 PM | #6 |
Member#: 136493
NESIC
Vehicle:2015 WRX GBP |
Ok, i think GT_Hawk just confused me. I have an 05 RS with DBW, I didnt think i had iAVLS but then again, do I? I know i have DBW so im pretty sure i have the new ECU to match it and im also pretty sure i dont have the stock EL headers that teh 06+ have. So the real question is do i have the iAVLS?
07-23-2007, 12:36 PM | #7 |
Member#: 36629
You don't have the iAVLS. And you have throttle cable though a DBW? I'm partially confused too.
07-23-2007, 12:59 PM | #8 |
Member#: 141189
Vehicle:2007 2.5i (NBP) 2018 STI Limited (ISM) |
2005 got DBW but it has a 16bit ECU...
2006-2007 have DBW with a 32bit ECU with iAVLS 2005 has UEL headers and 2006-2007 have EL headers... i believe the engine code for the pre-2005 cars is EJ251 and now it's EJ253 (according to the service manual) |
07-23-2007, 01:23 PM | #9 |
Member#: 136493
NESIC
Ok, that clears things up for me. Stupid transitional years.
I always get stuck with cars with transitioning technology. I used to have a '93 S10 blazer with their CPI motor. It had 1 spider shaped fuel injector (which failed often) buried inside the intake plenom. That motor lasted on the market for 2 1/2 years before being replaced. |
07-23-2007, 04:47 PM | #10 | |
Member#: 145883
SCIC
Vehicle:2008 wrx psm |
07-23-2007, 04:49 PM | #11 |
Member#: 145883
SCIC
excuse me, it has crossover,no lift
07-23-2007, 05:06 PM | #12 |
Member#: 97251
NESIC
Vehicle:'13 Impreza 2.0i DGM |
Just give it some time on the parts. If you check around you'll actually find that many parts are compatable from previous years. What are you looking for?
07-23-2007, 06:55 PM | #13 | |
Member#: 150666
Vehicle:2007 2.5i SE 4EAT OBP |
~Clinton |
07-23-2007, 07:13 PM | #14 |
Member#: 117767
RMIC
Vehicle:2014 Audi S4 DP Stage 2 (~420whp) |
07-23-2007, 07:32 PM | #15 |
Member#: 36629
Wow, these posts are nice n spicy
Still confused does the 05 have a throttle cable or not??? |
07-23-2007, 07:35 PM | #16 |
Member#: 117767
RMIC
07-23-2007, 08:27 PM | #17 |
Member#: 91837
wow... once again another thread with a whole ****load of misinformation
the 04 RS has a cable throttle, UNequal headers and NO fancy valve timing the 05 RS has throttle-by-wire, UNequal headers and NO fancy valve timing the 06+ i has throttle-by-wire, EQUAL headers and fancy valve timing |
07-23-2007, 10:50 PM | #18 |
Member#: 114263
E. Canada
Vehicle:2014 Forester XT Black |
2006+ 2.5 turbo (WRX/STI) has AVCS. 2.5i has AVLS, which IS kinda like VTEC.
AVLS is on intake only, and only affects one of the two valves. One valve is always at full lift, the other is normally on low lift until you hit high load/high RPM. There's a link to this somewhere, I'll post when I find it. |
07-23-2007, 10:52 PM | #19 |
Member#: 114263
E. Canada
found it:
AVLS: http://www.drivesubaru.com/Spring07_whatmakes.htm AVCS: http://www.subarudrive.com/Win05_WhatsInside.htm Currently no Subarus come with both AVCS and AVLS that I'm aware of....but the 06+ 2.5i/se models definetly have AVLS. WRX and STi has AVCS. |
07-23-2007, 11:19 PM | #20 | |
Member#: 36629
Jerry |
07-23-2007, 11:26 PM | #21 |
Member#: 54585
South East
Vehicle:2013 WRX WRB |
07-23-2007, 11:46 PM | #22 | |
Member#: 149392
I made a post a while ago containing all links to info on the iAVLS system and I just wen and found it so anyone who would like to look. Lots of useful info and will get people the understanding of the system. But like I said its vtec like, Honda people just like to think that vtec is this great system when in the end its relay just letting the engine burn less gas at lower rps's so you can keep a little bigger engine. http://forums.nasioc.com/forums/show...ighlight=iavls Also DZnutz is 100$ correct in his post, believe him The intake is also different for the 06+, IE 3 hoses on the intake vs 2 on the 05. Meanes that a CAI for a 05 needs to be modded to fit the 06+ but its a simple fix using a 2fitting to put 2 hoses into 1 connection on a CAI. Suspension wise I have head one yar had aluminum lower control arm and another did not, but this could be the WRX, I would love someone with more details here. Also I have seen a great thread that tells what size and type breaks that the WRX/STI/RS lines had over the years, but I think that there are differences between some of the RS and 2.5i but can't find that link. Last edited by GT_Hawk; 07-24-2007 at 12:02 AM. |
07-24-2007, 12:25 AM | #23 |
Member#: 114263
E. Canada
2.5i has steel control arms
06 WRX has aluminum control arms, 07 WRX has steel ones |
07-24-2007, 01:31 AM | #24 |
Member#: 132962
BAIC
Vehicle:06 2.5i supersport crystal grey metalic |
what i want to know is where can i get a service manual. My dealer will not sell me one and my clutch is gone in my 06
07-24-2007, 06:56 AM | #25 |
Member#: 141189
it's on their site i believe...well i know they have the owners manual on there...not sure about the service and maintenance
https://my.subaru.com/vehicle/Manual...ers_manual.pdf |
What is the difference between Wrx cylinder heads and Sti heads | likeawind | Newbies & FAQs | 37 | 04-13-2010 04:53 PM |
what is the difference between a "small block" and a "big block?" | alacrity024 | Off-Topic | 48 | 10-24-2007 04:51 AM |
what is the difference between borla dual tip and single | ryanpietro | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 2 | 07-04-2006 01:03 AM |
HELP!!! what is the difference between JDM rear diff and USDM? | WRXINTX | Transmission (AT/MT) & Driveline | 5 | 10-05-2005 09:57 AM |
What is the difference between republican, democrat, conservative, and liberal | TBOD | Off-Topic | 42 | 09-08-2004 10:04 AM |
