05-10-2006, 01:23 PM | #1 |
Member Sales Rating: (3)
Member#: 100265
Vehicle:1999 powered '90 Miata |
FS: 1988 Toyota Celica Alltrac - RARE - SW VA
Location: Blacksburg, VA Means of Contact: AIM: MTBGAEL or PM Description: 1988 Celica Alltrac - White/Red Miles: 105k Price: $1800 obo Information: This is a 3S-GTE (turbo, DOHC 2.0L) powered all-wheel drive celica. Best estimates are 5,000 of these cars were made worldwide between 88 and 89. You will almost never see another one on the road! I am open to RWD trades. 240, MR2, Miata. The motor was just rebuilt by me. Hone/deck/cleaning for the block with new rings, bearings, etc. Used crank. Head was cleaned with new valve seals, seat job, and deck. It's currently leaking oil in a few places, probably to be fixed by me. If the rear main is leaking, which I suspect, I won't be fixing that. Suspension is in pretty good shape. I have about -3 degrees of camber in the front from slotting mounting points. Eibach pro-kit. Brand new stock struts front, blown stockers rear. Bushings seem good in general. Drivetrain is pretty much indestructible. Tranny/axles/diffs will hold 10s stock. Open diffs front and rear, viscous center. Occasionally will grind 2cnd gear on the quickest of shifts. Brakes aren't in bad shape. I had planned to do some work to them, but it was low on the list. Body... Well, it's rough. It's been wrecked and fixed multiple times. Currently the front end doesn't line up too well, and has rust. Everything behind the front of the front doors is fine IMO. A few spots of rust here and there. It would do great to have two new quarters, and have all of the "widebody" kit removed, cleaned, and reattached. I repainted the engine bay black last summer...it's in good shape minus some areas from doing the engine rebuild. Turbo has shaft play. My buddy has a turbo for sale for $300 that would be great on the car. You would have to reuse my exhaust housing or get one off an MKIII supra to make it work. It has problems, some of which I'm fixing. Some...won't be fixed. It won't pass inspection as it sits. To the best of my knowledge it needs (that I'm not planning on doing): Two CV boots Windshield Muffler (2 1/2" straight pipe currently) Cat if you live in an area where they do end-of-the-pipe testing (it has a shell) Probably tires. The ones on it are "good" still, but there is a flat spot on one that won't pass. (current tires are hankook R2 Z212 195/60/14) If you have questions or want to see it, get in touch. If you have any questions about parts availability/upgradability/etc I can probably answer those. This would be a GREAT car for getting into rally without worrying about messing up the bodywork. I was going to run the car in SOLO DSP class, but I'm running my 2006 WRX in DS instead. Thanks for looking! -Justin Pictures: http://filebox.vt.edu/users/jrest/Alltrac/
05-12-2006, 04:40 PM | #3 |
Member#: 100265
Make offers if you're interested! I'm open to trades, deals, whatever I just am no longer interested in exploring this car.
FS: 1988 Toyota Celica Alltrac *$500* | alltracin | MAIC Private Classifieds | 6 | 04-10-2007 04:38 PM |
FS: 1988 Toyota Corolla Sedan | haunt | NWIC Private Classifieds | 3 | 03-23-2007 08:35 PM |
FS: 1990 Toyota Celica GT-FOUR/Alltrac || Seattle, WA || 124k Miles || PIX! | BraveUlysses | North West Impreza Club Forum -- NWIC | 19 | 09-06-2005 11:59 PM |
FS: 1990 Toyota Celica GT-FOUR/Alltrac || Seattle, WA || 124k Miles || PIX! | BraveUlysses | Private Vehicle 'For Sale' Classifieds | 15 | 09-06-2005 03:16 PM |
FS: 1991 Toyota Celica Alltrac | parklax | Private Vehicle 'For Sale' Classifieds | 2 | 10-03-2004 09:00 PM |
