07-16-2008, 02:05 AM | #1 |
Member#: 159738
SCIC
Vehicle:2004 WRB STi 620awhp OFCD V3, FR TS, BW8374EFR |
found a vid of my machinist working on a couple Subaru blocks
I just picked up my block today after a 3 wk wait. I had John Edwards talk to CP Piston's tech support to get the right ra numbers for their rings. Cosworth's tech support also recommended an ra of between 20 or lower for the deck surface to have their head gasket seal correctly. So this was the goal when resurfacing the top of the block deck. John also checked the mains for straightness. The crank was sent out to have a .001" clearance on the rod journals. He also balanced the whole rotational assembly to 1/2 gram.
Here's some vids of machinist I used, John Edwards from Costa Mesa R & D in Orange County, Southern California: Honing an STI block YouTube - Subaru STi Block Honing Here's another vid resurfacing a Subaru SVX block with sleeves: YouTube - Subaru SVX Sleeved Block Resurfacing Here's another of his custom 6 qt Subaru oil pan: YouTube - Subaru Aluminum Oil Pan, etc...
07-16-2008, 07:54 PM | #2 |
Member#: 32669
SCIC
Vehicle:2007 2.34LR, EFR7670 LINK G4+ hybrid STi |
Cool vids. Have you ask him about torque plates?
07-16-2008, 10:22 PM | #3 |
Member#: 84105
SCIC
Vehicle:2005 Super Slow STi CGM |
He has them, don't know why he did not use them:
07-17-2008, 12:41 AM | #4 |
Member#: 6886
Vehicle:MY01 EJ207 HTA35r AVCS ON! |
07-17-2008, 04:59 AM | #5 |
Member#: 30798
Vehicle:2001 RS-T Hybrid 2.5>2.2T>257>2.35S |
It's to bad that oil pan isn't for our cars.
07-17-2008, 07:05 AM | #6 |
Member#: 145145
Vehicle:2006 wrx STi |
He may well have bored the block using torque plates. Perhaps he just did the final honing without.
A torque plate is used to simulate the loads applied to the block by a torqued head during machining. When you torque a head down it slightly distorts the bore. If you bore the block perfectly round without a torque plate in place, it will go slightly out of round when you install your heads, negatively affecting ring seal. If you bore with a torque plate in place the bore being distorted will be taken into account. It should actually read slightly out of round without a torqued head/plate, but should be perfectly round when the head is actually installed. |
07-18-2008, 12:48 PM | #7 |
Member#: 6886
intresting..Thanks MartinSTi05 for the explanation
but aren't head bolts supposed to be torqued in a certain order to ensure proper distribution of force on the mating surfaces of the head and block to prevent said distortions, assuming the deck faces are true and level? if the torque plate does simulate the forces, then i guess it would minimize the distortion caused by the assembler that wouldnt be as methodical. |
07-18-2008, 02:52 PM | #8 | |
Member#: 32669
SCIC
No, you torque the head studs in a particular order to ensure an even clamp across the entire head and one of sufficient force. If the block distorts it distorts(and it will). Torque plates should be torqued exactly as heads would be on a block. |
07-18-2008, 02:57 PM | #9 | |
Member#: 145145
The torque plate helps simulate the forces exerted on the block, specifically the threaded holes for the head studs/bolts. These forces have nothing to do with how the head will lay on the block. |
07-18-2008, 03:42 PM | #10 |
Member#: 73842
SCIC
Vehicle:2004 350hp 380tq WRX Tuned by Miguel Alcrudo |
yep i have used COStamesa R&D on about 4 of my builds and i like his work alot, the shop is so busy that turnaround time is a bit slow. but john knows his stuff, over 10 years teaching engine rebuild and he worked for the company that builds the machining tools in his shop.
great guy check him out if your in the socal area. |
07-18-2008, 04:01 PM | #11 |
Member#: 184779
Good info, I'll have to check my machinist now for my upcoming build...
Similar Threads | ||||
i just found out one of my old high school friends is an alleged pedophile | cnw | Off-Topic | 52 | 08-24-2008 11:47 AM |
Found a little vid of my bro, anyway wanted to share. | Hotrodguru | Texas Impreza Club Forum -- TXIC | 7 | 02-13-2006 10:45 AM |
Cool vid of Stig doing a demo run in an Audi Quattro Group-B car | XenoWolf | Motorsports | 13 | 12-07-2005 03:24 PM |
found some vid of my old ride WRX Wagon | Boosted Wagon | Member's Car Gallery | 8 | 03-12-2004 02:43 AM |
A couple of nights ago my girlfriend says, "Why don't we trade my car in for an STi?" | Dorkfish | South West Impreza Club Forum -- SWIC | 7 | 03-13-2003 04:57 PM |
