09-24-2013, 01:10 AM | #1 |
Member#: 366807
Vehicle:2002 WRX WRB |
Researching for a build
UPDATE: Decided to switch to 2.5L platform.
I've been doing as much research as I can for an upcoming build. Trying to slowly amass the parts I need for my desired goals. I'd like to attempt 350 whp range. (Mustang Dyno in Cincinnati Ohio area) From what I've read this setup should put me in the area. Yes I am familiar with that much power and am sure I want it. Figured I would state that before the "Are you sure you want 400 hp" thread pops up. It's a nice thread and all but I am sure. I plan on running the stock WRX 5spd until it dies. I do understand that if abused the transmission will not think twice about grenading. (Unsure about going with the 6spd or heavier gears. Haven't researched that enough yet. Also would like to drive a 6spd from an STI first.) Let me know if I'm missing something or there's a better route. Feel free to suggest different brands. Currently have: Unknown brand Turboback exhaust. Unknown brand up pipe Cobb AP Engine. Intending to go with a 2.1 stroker setup as what I've seen is the general consensus on hybrids is bad. Looking at this kit. http://www.6starspeed.com/suwrxejpe2st.html May attempt to assemble piece by piece. Hoping to not have to bore. Forged 92 mm Manley Platinum series 2618 alloy pistons from (8.5:1 C.R.) 08+ STI Crankshaft ACL Race series engine bearings Manley Sport Compact H-Beam Rods Valve springs/retainers (suggestions would be nice) Cams - will stock ej205 cams work? Or use STI cams that are modified for non-avcs ARP 11 mm head studs STI oil pump Perrin lightweight crank shaft pulley TGV deletes - will bore out and delete CEL Subaru OEM Gasket kit Crank and rods balanced. Engine honed by shop. Will have the heads gone over by a shop. Belts - suggestions? Spark plugs One step colder - brand suggestions? 1000 CC injectors as I would like to run e85. suggestions? Walbro 255 fuel pump. Big enough? - or DW equivalent as I've been informed they rate their pumps for e85 Blouch 20g xt turbo Grimspeed up pipe and 38mm tial wastegate vented to atmosphere STI TMIC - will that be sufficient? Resurfaced flywheel clutch - will 350 require a stage 1? - brand suggestions? Of course tuned by a reputable shop AFR gauge - Defi gauges suggested - confirm/deny? EGT gauge - Defi gauges suggested - confirm/deny? EBC - suggestions
09-24-2013, 12:40 PM | #2 |
Member#: 223137
Vehicle:14' super ultimate race car project |
Looks like a fun setup, I fought with building almost the same setup for a couple years, then decided I was going to do a kit car build instead. So I'm setting up my ej255 for that.
Only input, I usually run a DW fuel pumps only because they rate their pumps for e85 use unlike Walboro. Yes people use em and have good results, but it's just a piece of mind. And the stock cams will work, but with the upgraded springs why not get some cams and rev it a little higher? You should totally start a build thread too, I wanna follow your build, I might go back and do one in the future! |
09-24-2013, 01:43 PM | #3 |
Member#: 366807
I'll start a build thread as I start ordering parts. Thank you for the suggestion.
09-25-2013, 09:22 AM | #4 |
Member#: 301037
Vehicle:2004 Forester XT Aspen White |
Have you talked to who is going to tune the car yet. They may be able provide some suggestions and insight as to what they like and see working the best.
09-25-2013, 02:48 PM | #5 |
Member#: 366807
Unsure who I will have tune. I figured I'd try to hammer out the build a little more before talking to a tuner. Just have them fine tune what I've come up with.
09-25-2013, 10:20 PM | #6 | |
Member#: 29292
SCIC
Vehicle:2004 WRX wagon silver |
oh yeah, for your pistons if you are reusing a block, you might want to go up to 92.5 just for good measure, and a good bore |
09-25-2013, 10:51 PM | #7 | |
Member#: 366807
I have heard the 92.5 suggested a bit, couldn't find any information on if it would cause sleeve issues down the road. Also what about going all the way with 93mm for the extra displacement? It's not much but it all adds up. |
09-26-2013, 12:04 AM | #8 |
Member#: 345258
Vehicle:2003 WRX Sonic Yellow |
what have you read about that says hybrid builds are bad? any links? im thinking of doing it for money reasons because the AVCS system is a pain to get by.
09-26-2013, 02:17 AM | #9 |
Member#: 178426
Vehicle:2010 S4 Gray |
You will need a bigger tmic. Fmic would be better.
Get Defi gauges. Do not cheap out!!! You will regret it. Avoid one step colder plugs, especially on E85. Do not reuse stock cams! Stock cams suck, upgrade. The power band is going to taper off up top, which ruins the point of this whole build. Last edited by rexblake; 09-26-2013 at 02:23 AM. |
09-26-2013, 03:53 PM | #10 | ||
Member#: 366807
My setup isn't going to be big enough to need an FMIC, it will only create lag. I am aware that I need a bigger TMIC and was not sure if the STI stock would be sufficient. Also I have heard good things about ebay TMIC's. Thank you for your gauge brand suggestion. Why would I avoid colder plugs? I will also have a tune for 93 and e85. |
09-26-2013, 07:40 PM | #11 | |
Member#: 178426
A fmic is going to make power easier, less prone to heat soak (inherently safer), and cause minimal lag at best (i.e., probably not discernible). My lag "increased" by 200 rpms, I'll chalk that up to environmental conditions. Avoid ebay tmic. Some seem to work ok, some suck, and either way they are just ripping off an actual companies hard work. Support the legit company. You don't need colder plugs. Colder plugs actually seem to work worse in E85 applications. Just like plasma plugs or whatever fancy ones. Stick with stock copper plugs. I had great luck with those on E changing them once a year and gapped way down. |
09-26-2013, 09:00 PM | #12 | |
Member#: 366807
"TMICs and FMICs: Probably the BEST buy on eBay. Having done or seen done many intercoolers, I can honestly say that eBay pretty much ownz in the intercooler business. I've heard and seen some heroic battles with brand name intercoolers that end up looking haggard with miss-aligned pipes, offset intercooler cores, crappy fittings, missing hardware. Every eBay intercooler I've seen or heard of fits like crazy, is cheap as crap, and is 10 times better than the name brand units." - Unabomber http://forums.nasioc.com/forums/show...php?p=22688922 Only going to use copper for tuning. I am not going to run my car full time on copper plugs. They wear out faster and have no actual proof of increasing anything. Still looking for more information on temperature with e85. I've seen both directions. Will talk to tuner. |
09-27-2013, 03:11 AM | #13 | |
Member#: 178426
You want coppers for E85. Period. You can run what you want, coppers are better. If you can't handle swapping them once a year, your in for a world of hurt. Check the "e85 army" thread. Last edited by rexblake; 09-27-2013 at 03:17 AM. |
09-27-2013, 03:14 AM | #14 | |
Member#: 366807
09-27-2013, 09:56 AM | #15 |
Member#: 369440
09-30-2013, 02:10 AM | #16 |
Member#: 178426
Brake upgrades? Suspension upgrades?
09-30-2013, 02:57 AM | #17 |
Member#: 366807
09-30-2013, 03:16 AM | #18 |
Member#: 178426
09-30-2013, 03:17 AM | #19 |
Member#: 366807
You do understand some people understand how to drive their car and know the limits of said car? Not all of us are 16 year olds who just got behind the wheel of a car they shouldn't even touch. Nice attempt at trolling btw.
09-30-2013, 03:26 AM | #20 |
Member#: 178426
Whoa whoa, you said nothing about driving. You go the speed limit in all circumstances. Remember? And never accelerate fast. Nor do you turn quickly. And you certainly, which has been proven repeatedly, never brake quickly. Ever. And certainly absolutely irrefutably never more than once. Hell, I bet you make an emergency stop once and simply get a tow! Just to keep the stock brakes in check. In fact, you are a prime candidate for never modding your car, since you use all of about 50hp of it.
09-30-2013, 03:34 AM | #21 |
Member#: 366807
I understand you're butthurt you got shut down in that other thread and you have no real idea what you're talking about. Quit cluttering my thread please as it might discourage someone who actually knows what they are talking about from posting.
09-30-2013, 11:22 AM | #22 |
Member#: 269543
Vehicle:2002 2.5RS BRP 2004 WRX WRB |
have you looked in to http://www.builtej.com/product.php?p...at=1140&page=1
09-30-2013, 12:38 PM | #23 | |
Member#: 366807
09-30-2013, 01:38 PM | #24 |
Member#: 237145
SCIC
Vehicle:02 WRX 12 FXT |
You sound like you have done a fair amount of research.
So just curious, what type of torque are you looking for? low end or high end? or just an overall bump. I have been looking at threads on how the 2.5 hybrids do not make that much lower end and the 2.1 helps with reduced spinning mass? I'm not sure. I personally am looking for the next step and 2.1 vs 2.5 vs avcs has me lost. I'm looking for more low end torque spike. Also why so against suspension mods? Top hats and a few bushings and better pads from Turninconcepts / Kns brakes are easy to install and made me happy. The 5mt built vs stock 6mt has their pros and cons for both. I listed them in my swap story somewhere. It all comes down to what you think is the best. |
09-30-2013, 02:18 PM | #25 |
Member#: 366807
I'm not against suspension. That's not what this post is about though. Also that guy is trying to troll from a conversation in a different thread.
If you're looking for tq, you want to go hybrid or full 2.5 setup. If you want every bit of tq you can squirt out, you want to get the full harness/ecu for the avcs setup. I'm looking to put tq in the 350-400 range. As far as the transmission goes, some of it is opinion, but durability is a fact. The 6mt is vastly stronger than the 5mt. Yes you can drive a 5mt forever without breaking it, but you cannot abuse it. You cannot launch it. The 6mt is made for abuse. If you want to pm me with questions I will answer them the best that I can. |
