05-27-2012, 11:25 AM | #901 |
Member#: 158810
NWIC
Vehicle:2005 STI and Baja White |
05-28-2012, 01:47 AM | #902 | |
Member#: 121071
SWIC
Vehicle:2004 Baja STi TeamJDMFresh.com/CSJ |
05-29-2012, 10:59 PM | #903 |
Member#: 14555
Vehicle:1995 Impreza L Baja |
Now if I only had the funds to do a TFE-731 swap in the bed of the Baja. 3,650 LBS of thrust would almost be enough to go vertical. |
05-30-2012, 12:34 AM | #904 | |
Member#: 253456
Vehicle:2005 WRX STi/Baja tu black/gray,silver |
05-30-2012, 12:37 AM | #905 | |
Member#: 253456
05-30-2012, 12:44 AM | #906 |
Member#: 14555
05-31-2012, 08:48 AM | #907 |
Member#: 28410
Vehicle:2012 Outback 3.6R RRP |
Sorry for the cross-post, but I am selling my winter/offroad wheel setup. I am going a bit lower and these aren't going to work anymore...
Here in Midwest Classifieds Nevermind...SOLD! Last edited by lumpy; 06-28-2012 at 08:21 AM. |
05-31-2012, 06:45 PM | #908 |
Member#: 121071
SWIC
BajaSTi Monster build
So it has been a little while since I have posted any mods to my baby, but this might explaiin why...lol
So here goes: Cosworth Piston 100mm 8.2:1cr 850.00 850.00T Cosworth Piston Ring Set Cosworth Connecting Rod Set ACL Main Bearing ACL Race Rod Bearings STI Head Studs ARP R&R engine, disassemble the block, inspect and blueprint. Rebuild Heads Kelford Stage 2 Cams Standalone Automatic DCCD controller for JDM and USDM 6 speed GT 30/76 turbo 44mm ewg 1000cc injectors side feed rails cobb ap 91 summer tune 91 fun tune 109 race tune E85 race tune I will be having all this work done by Joe @ Goodspeed in AZ. I should be taking her in any day now and hope to get her back by the end of July. I eill post updates as I can. I also think Car Street Journal.com might do a small artical on the BajaSTi! Yay!!!! |
05-31-2012, 09:33 PM | #909 | |
Member#: 158810
NWIC
Lose the cobb ap and go open source. Did you get an A/T baja driveshaft for the sti tranny?? |
05-31-2012, 10:05 PM | #910 |
Member#: 121071
SWIC
Have open source had ap and want to go ap again but thanks. Yes the a/t drive shaft is the way to go.
06-01-2012, 03:01 PM | #911 |
Member#: 100818
Vehicle:2005 Baja Sport Dark Blue Pearl |
06-01-2012, 03:41 PM | #912 |
Member#: 121071
SWIC
I had a shop do the swap and they used an 06 sti trans it it works great.
06-05-2012, 09:56 PM | #913 | |
Member#: 158810
NWIC
The a/t driveshaft out of the baja is not only a good idea but it is a must for the 6 speed STI swap. Your final drive must match as well. As for the dccd did you use the coin tray in the center console to install the dccd switches? They make a snap in solution by using the heater switch surround in that spot. Take pictures, don't keep that knowledge of what has/hasn't been done all bottled up. Post a time slip in the 1/4 as well. I have always been curious of that in a baja. |
06-06-2012, 09:16 AM | #914 | |
Member#: 214691
Vehicle:2005 Baja Turbo Blue |
I used 5x8 diamond plate aluminium I picked up from a warehouse that sells metal in Brooklyn. I already had a template from the marine board I tried to use the first time but it warped. Cut it with a jigsaw. I used aluminium bars I got at home depot for support underneath and just bolted it down since I really don't need it to open vertically. |
06-06-2012, 09:19 AM | #915 |
Member#: 214691
This is a sick drawing by the way, I think the Baja would look great like this. Very unique.
06-06-2012, 01:49 PM | #916 | |
Member#: 121071
SWIC
06-06-2012, 02:21 PM | #917 |
Member#: 100818
06-07-2012, 04:08 PM | #918 |
Member#: 146009
E. Canada
Vehicle:2016 STI Pure Red |
06-07-2012, 06:36 PM | #919 |
Member#: 158810
NWIC
Laugh if you want, but this was a free mod and it works EXTREMELY well.
Normally I was datalogging 120-150 degree IAT's. Most I can get it up to now at a dead stop is 91 degrees. The temp drops 10+ degrees in 3 blocks @ 30 mph. Holds a steady 12 degrees above ambient while moving. Best free mod ever! For those wondering, it is an old optimum nutrition 6 pound whey protein canister. I cut the bottom part of the snorkus off (in the wheel well) and sealed it up with gorilla pvc tape. The lid has a 3 inch airtight hole cut in it and attaches to the snorkus. You can place your hand inside the ram air part that attaches to the radiator mount and feel the air being drawn in. I am still in disbelief at how well it works. Last edited by 2.5 turbo hyped; 06-07-2012 at 06:42 PM. |
06-08-2012, 09:39 AM | #920 |
Member#: 4835
Vehicle:2003 Baja 5MT Yellow w/ 220,000 miles |
I always appreciate the home-grown DIY mods like that. I won't laugh at ya. You should see my jury-rigged engine bay! =)
06-16-2012, 07:24 PM | #921 |
Member#: 75078
South East
Vehicle:2011 Forester 2.5X Dark Gray Metallic |
I just did this one today with guidance from a DIY thread on scoobytruck.com
06-26-2012, 07:14 PM | #922 |
Member#: 152508
NWIC
Vehicle:2003 Baja Good ol' Classic Yellow! |
Finally got my ~2" lift on my 2003. Hmmmm, it was actually about a month ago I had it done. I like it.
06-26-2012, 08:08 PM | #923 |
Member#: 121071
SWIC
Pics?
06-27-2012, 04:21 PM | #924 |
Member#: 4835
06-28-2012, 08:41 PM | #925 |
Member#: 152508
NWIC
I had my local custom shop make me the lift since no one could find a lift that fit our vehicle.
I just took the after lift pictures. It's funny that the pictures don't show much..but then, it is only 2". They didn't want to go any higher because they didn't want to put too much stress on the CV joints. It sure feels higher when driving it. Before the Lift: After the Lift: Last edited by Emsanon; 06-28-2012 at 11:25 PM. |
Up to date pics & mods | edoublepo | Member's Car Gallery | 4 | 10-09-2006 08:48 PM |
Modded PStwo (slim) & Modded Gamecube | llhype12ll | Private 'For Sale' Classifieds | 2 | 11-15-2005 01:28 PM |
couple of pics & mods list | WRX Ver.7 | Member's Car Gallery | 15 | 08-01-2002 01:40 PM |
How to change pics & mods? | mav1c | Mid Atlantic Impreza Club -- MAIC | 6 | 08-28-2001 12:51 PM |
STI 3 Pics & 340HP Mods | Hyperex | Member's Car Gallery | 38 | 07-06-2001 06:20 PM |
