10-27-2011, 05:39 PM | #76 | |
Member#: 282175
Vehicle:2004 WRX Red |
Any update on this setup? I have some issues with oil consumption from blow by and am thinking about trying this.
10-28-2011, 11:46 AM | #77 |
Member#: 109367
South East
Vehicle:2004 STi Wgn Hybrid JBP |
I set mine up about 1k miles ago, and I've had 0 oil consumption since then. I redid all my lines with silicone ones, and I'll try to post some pics of my setup at some point.
10-31-2011, 11:21 PM | #78 | |
Member#: 199004
Vehicle:04 WRX BuiltHybrid Black & Gold |
I have 550 miles on this setup and it works great so far!! |
11-01-2011, 05:42 PM | #79 |
Member#: 282175
11-02-2011, 02:58 AM | #80 |
Member#: 259182
Vehicle:2005 Legacy GT Pearl White |
who else has tapped the valve covers, ive pmed a few people but no responses yet? I want to do this project ASAP but I have a question. what size drill tap do I need to use with the 5/8 Barb fitting? (its not 5/8)
11-02-2011, 09:58 AM | #81 | |
Member#: 124663
South East
Vehicle:2003 AW WRX 2008 GG Evo X MR |
You should be able to find the specs for the drill+tap for 5/8 NPT. Remember: A NPT tap is different than a regular tap. you need a NPT tap. |
11-02-2011, 10:47 AM | #82 |
Member#: 3687
Vehicle:MY99 GF4 JDM 6spd NF Performance |
The top breather on the 257/255 block will allow any blowby at the TOP of the crankcase to filter to the unbaffled port on the valve covers. If this cap is blocked, the crankcase will have to breath it through the rear oil separator, which connects to the restrictor valve/turbo inlet. The crankcase also breathes blowby through the oil drain passages from the head-to-block. The heads and crankcase will see the same pressure no matter what. The smaller port on the 257/255 valve covers are baffled. They go down, and back up. There is a little drain hole at the bottom of the baffle to let out any oil.
I tell the guys to just run a catch can at the rear chimney before going back into the turbo inlet and also the one that comes from the heads. Run TWO catch cans regardless if it's a 2.0L or a 2.5L. If not two then run a large baffled catch can/box and have both hoses going to the turbo inlet come to the baffled can/box and then back to the turbo inlet. If it where a single catch can I'd run it to the rear chimney. If you do NOT wish to cap off the top breather on the 257/255 block, run it to a catch can or you can T it to the rear chimney hose, to a catch can and then back to the inlet. They BOTH are breathing from the crankcase. If no then just have fitting welded onto your 2.0L valve covers. NOTE: The fittings on the head that are for the crankcase vent are NOT baffled. The fittings that are on the heads, which goes to the turbo inlet are baffled. Last edited by FuJi K; 11-02-2011 at 10:52 AM. |
11-07-2011, 02:15 PM | #83 |
Member#: 124663
South East
You do not need (or want) a catch can on the non-baffled block vent-to-valve cover ports. You only need one on the pcv-to-valve cover ports.
12-03-2011, 07:08 PM | #84 |
Member#: 298075
Vehicle:2002 wrx silver |
[quote=justooln2;34810898]I've posted this elsewhere. But here it is again.
I think this is a great picture for this (borrowed from slorice): on this pic if the hoses from the valve cover that t- to the intake dont have a pcv wouldnt it force boost back into the engine and cause crankcase pressure again, iam having issue with crank pressure, when i get under boost and let out the throttle it pulls oil into the intake or its backing up into the turbo? by the way mine a built hybrid with a rotated presicion 5862, any ideas? and i do not have extra ports weled on to my valve coers just the stock ones... |
12-04-2011, 10:54 PM | #85 |
Member#: 298075
bump anyone ^
12-05-2011, 05:42 PM | #86 |
Member#: 168922
Did you delete your PVC? That can happen, but if you have a PCV once the pressure in the intake goes above Stochiometric and into boost the PCV valve will close and wont allow any blow by into the intake. You remove PCV valve and you got oil going to your intake uneder boost. If you go to page 1 and 2 they to show how the two systems are different between STi and WRX.
This thread is quiet useful and offers a lot helpful images on how to do things. By far the best one would be to cut into the passenger side valve cover and make a port there. Very good. Also, people with STIs tend to run 2 AOS or 2 catch cans, one is for the heads, the other is for the block. If that is not your question then sorry for wasting your time. |
12-05-2011, 06:02 PM | #87 | |
Member#: 298075
12-09-2011, 10:16 PM | #88 |
Member#: 258482
I'm still running my c-case vents just like pictured. I've gotten a good 1500 miles on the new build, the turbo seals went out and I was getting a little oil mixed with condensation. My catch can vent set up seems to be doing just fine. One other thing ive done, is to thread a nipple onto the can and ran a ball valve and drain hose for ease of draining, plus it adds to more overall volume of the can. (1/2" hose) It's has already came in handy. Just a little updated 2 cents.
12-20-2011, 03:25 PM | #89 |
Member#: 70459
TXIC
Vehicle:2002 AW Bugeye ej257 6spd, GT3076R, Alky & EWG |
glad to see people are still adding good information on this thread.
12-23-2011, 01:39 PM | #90 | |
Member#: 190729
NWIC
Adding or removing the balance tube will not change total pressure in the crankcase. There are no vents on the tube and therefor there is no extra venting effect or any saving grace on cam seals. I have NEVER seen a cam seal blow out from anything other than a head gasket failure. Not to say that it can't happen, but I've never seen it and I've seen a lot of motor failures. the fuction of the balance tube is related to AVCS. That is why it is only on AVCS heads. The AVCS solenoids dump a lot of oil into the valve cover and this creates a higher load on the oil drainback ducts in the heads/block. Blowby moving up the ducts will slow oil drainback. Adding the balance tube prevents blowby from slowing oil drainback. Flow in this tube is insignificant and should NOT be vented to atmosphere or through a catch can. Venting this port to atmosphere will create flow in the tube and you WILL get lots of oil out that hose as the crank slings it right up into the port on the top of the block. This port is not made to handle flow; it is merely for pressure equalization. Blocking this tube on non AVCS engines does nothing bad. Using this tube on non AVCS engines can help will oil drainback and will not have a negative effect IF you run it just like factory and connect the valve covers to the block ONLY. venting to atmosphere or turbo inlets will only create a mess. I didn't read the whole thread to be honest. So if this was already stated, then awesome! |
01-10-2012, 02:35 PM | #91 |
Member#: 124663
South East
I'm going this route:
Using a Peterson Fluid Systems VTA catch can (internally baffled with 6AN drain) Custom work on valve covers |
01-10-2012, 02:41 PM | #92 |
Member#: 190729
NWIC
looks nice. I dig that can!
lol, you have a nice can! |
01-10-2012, 03:11 PM | #93 | |
Member#: 18960
South East
Vehicle:02 WRX MBP It lives! ; ) |
It IS a nice can. That would be alot of blowby to blow a cam seal out. I've seen enough engines weep oil through the sealing surfaces, idle badly, etc to know this is one place where money is well spent. I ended up with a Crawford AOS. I'm not a big fan of having crankcase pressure fighting me in a engine that already struggles with ring seal. S. |
01-10-2012, 04:00 PM | #94 |
Member#: 124663
South East
nevermind. I can't read
01-10-2012, 04:51 PM | #95 |
Member#: 108493
Vehicle:04 WRX Hybrid RI GT30 |
I started of my hybrid setup by capping the secondary crank case vent and was was getting a good amount of oil and vapor to the catch can.
Second time around I added extra ports on the valve covers and tee'd them into the crank case. PCV out and original valve cover vents are venter to a catch can. Im using clear tubes to the catch can and have seen light vapor and no oil. So far so good... here is a pic: The black junction block might look confusing but it works just like how i explained above. The two blue barb fittings feed the catch can... |
02-25-2012, 11:16 AM | #96 |
Member#: 120912
South East
Using a new catch can that I just found...looks pretty cool and has been tested for two years on the makers personal 900hp car. I'll try to remember to follow up with this thread and let people know how it works. We are routing two hoses from valve covers to one port, main crankcase vent to the other port then returning the line back before the turbo (blow through maf on one and speed density on the other. It has a built in "crank bov" which is really just a check valve type assembly that will vent ANY pressure that builds up in the system. We are pretty excited to test it out. Here is a pic:
02-27-2012, 11:06 AM | #97 | |
Member#: 124663
South East
They're backed up right now so it'll be a few weeks before I get it. I'll post pics. |
02-27-2012, 04:38 PM | #98 | |
Member#: 154369
Vehicle:2013 SWP WRX kazoooooooo |
Oops, sorry to missquote you Dom.
03-01-2012, 10:39 AM | #99 | |
Member#: 273528
RMIC
Vehicle:2002 Impreza WRX Silver |
03-01-2012, 12:46 PM | #100 |
Member#: 271720
I have AVCS heads on a EJ22 block which doesn't have the 2nd block breather. Right now I have the unbaffled valve cover breathers capped, should I connect them together with a balance hose? and if so do i need to still try to tie into the crankcase for pressure equalization?
PCV and Crankcase ventilation Question | hustleshark206 | Newbies & FAQs | 4 | 08-20-2009 08:36 AM |
Help me get a better grasp of crankcase ventilation | gpatmac | Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) | 11 | 12-06-2006 02:45 PM |
hybrid crankcase ventilation | sonic rx | Built Motor Discussion | 23 | 09-15-2006 09:27 PM |
Crankcase Ventilation and Lateral G’s | SloRice | Built Motor Discussion | 41 | 08-10-2006 04:43 PM |
really need!! crankcase ventilation (blow by) valve | Seeinstars | Private 'Wanted' Classifieds | 3 | 07-30-2005 06:51 AM |
