01-04-2008, 09:37 AM | #1 |
Member#: 143011
Vehicle:2012 128i M-sport Black |
Anyone with a kind heart want to help with Excel?
http://www.mediafire.com/?1do5smnxizv
^ Spreadsheet example. Hello everyone: I was hoping that someone would be able to help me on a pretty decent size project that I am working on. I am hoping that I will be able to do everything with excel functions, and not have to use a macro, however I am not sure how possible that will be. Although it looks like a lot, I fell like it should be pretty straight forward for anyone who is pretty decent at this kind of stuff. Here is what I have: First of all, I am provided with a number of lines of data (weather data to be precise) 75010101000000000000?00000?00000?00000?00000?00000 ?00000?005B803B8-080B8-125E7067B80788B8060B8057B89999?099999?009999999990 05F8020F8008A700E7 Each line look like this except with varying numbers. This is the raw weather data that is provided to us, and each position consists of Month, date, hour, dry bulb, etc***8230; For each city there are about 8760 of these lines and they are broken down like such Month 1, Day 1, Hour 1 - Month 1, Day 1, Hour 2 - - - Month 12, Day 31, Hour 12. Now the spread sheet that I am attempting to make will allow the user to choose the days of the week, and hours during the selected days. I then need to somehow pull out the wet bulb and dry bulb temperatures and display the number of hours during the month that the temperature is between a certain range. For example, I want to see the results for Weekdays (M-F) during the hours of 6AM to 6PM***8230;For a more comprehensive layout one can examine the attached spreadsheet. (Note, The numbers in the spreadsheet were manually entered from a random city's data and is simply meant to display the finished product) In the attached sample for example, we can see that during the month of January the temperature was in the range of 40-45 for a total of 79 hours. On the next page you can see an example of the weather data string. The location of important data is as follows: Possition Information 4-5 Month 6-7 Day (not really needed) 8-9 Hour 68-71 Dry Bulb temperature. As a note, there is a space before each line which counts as a character position. And if at all possible, I would love to be able to keep the adjustable temperature scale as seen on page 1. Hopefully someone will be able to help me out with this, as I am not the most skilled person when it comes to Excel Functions and what not. Thanks a bunch everyone.
01-04-2008, 09:41 AM | #2 |
Sufficient for Sharky
Member#: 55173
Vehicle:with paddles. |
I'll help you, but you have to promise me undergrad p***y when I come up for Arts Fest in July.
01-04-2008, 09:46 AM | #3 |
Member#: 143011
Haha sure, and free booze...30 pack of Coors sound good? Maybe something a bit more upscale?
01-04-2008, 09:47 AM | #4 |
Member#: 55173
01-04-2008, 09:47 AM | #5 |
Member#: 25227
Vehicle:2012 Escape Black |
I can do anything in Excel......
.. . . . . . but I didn't understand a word of that. |
01-04-2008, 09:51 AM | #6 | |
Member#: 8679
Vehicle:2010 The most hated vehicle on the internets |
Does your data always occupy the same number of spaces? That is, would you represent five as 005 and ten as 010, or would they be represented as 5 and 10? If it's the former, you can use the MID function to extract the different parts of the data. For counting the number of times the temperature is within a range you'll need a few IF statements and a few COUNTIF statements. |
01-04-2008, 09:54 AM | #7 | ||
Member#: 143011
01-04-2008, 09:57 AM | #8 | |
Member#: 143011
01-04-2008, 10:00 AM | #9 |
Member#: 55173
There are a few ways to do it, but I can't tell with any certainty which is most efficient because I don't know the Excel API or internal functions.
In psuedocode: 1. Write a function to iterate through the cells and find the desired data (find cell where data at position XXX = cell XY--where the desired values have been entered into XY). 2. Assign a cell to the value of that function (remember, this is psuedocode, and in reality you'd actually choose the cell and write the function in there). 3. Repeat steps 1 and 2 to fill cells with desired data. 4. Manipulate data in those cells as desired. OR Replace #2 above with: Assign a cell and fill it with references to the cells that match. This may not be very helpful, so the chick doesn't have to be all the hot and the Yuengling can be in cans. |
01-04-2008, 10:06 AM | #10 |
Member#: 8679
01-04-2008, 10:09 AM | #11 | |
Member#: 143011
Don't worry your still get your brews...I wouldn't want to miss a chance to be verbally berated by a drunk Asinine in person as opposed to over the interwebs. |
01-04-2008, 10:10 AM | #12 |
Member#: 55173
What's it called when you use stuff like "=SUM(A3:A7)!" in a cell? Not called a function?
01-04-2008, 10:13 AM | #13 | |
Member#: 25227
tighe15 at gmail dot com |
01-04-2008, 10:13 AM | #14 | |
Member#: 143011
With a function you don't need to use VBA, unlike with a macro. |
01-04-2008, 10:15 AM | #15 |
Member#: 25227
In Excel, you can create a CUSTOM function, and that uses vb. Standard Excel functions do not use vb.
01-04-2008, 10:16 AM | #16 |
Member#: 143011
01-04-2008, 10:31 AM | #17 |
Member#: 143011
01-04-2008, 10:47 AM | #18 |
Member#: 8679
SUM is a function, and it doesn't use VB. However, if you want a custom function, that's when you need VB. The trick is getting Excel's functions to take the conditional actions you want and return the values you need without using any custom code. It's a fun challenge because it's less of a sand box than a traditional language. Psuedocode usually doesn't help a person because they already know the psuedocode -- it's the process of transforming that psuedocode into the analagous Excel functions that's the difficult part.
Anyone NJ or near by want to help with a swap | serg | Tri-State Area Forum | 20 | 08-16-2004 12:14 AM |
Anyone near N. Mississippi want to help with 6 spd install???? | eightballrj | South East Region Forum | 4 | 08-21-2003 02:54 PM |
Anyone want to help with installs? | blindclown | New England Impreza Club Forum -- NESIC | 19 | 08-12-2003 07:26 PM |
Does anyone want to help with uppipe or spring install? Also need install suggestions | rex n effect | Mid Atlantic Impreza Club -- MAIC | 4 | 10-03-2002 01:54 AM |
I'm buying Bill Harvey's old brakes on Mon...anyone want to help with the install? | Sean | New England Impreza Club Forum -- NESIC | 5 | 09-23-2001 03:36 PM |
