Mid Atlantic Impreza Club Forum sponsored by Annapolis Subaru |
01-30-2007, 11:09 PM | #1 |
Member#: 58733
Vehicle:2004 STi |
FS: MD Defi BF wht imp boost,oil temp,egt w/link &pod -AND STi UTEC w/3bar map sensor
I am selling my Defi gauge set, I had these in my 04 STi. They are Imperial BF series with white illumination. The link was mounted in dash where the cup holder normaly is and still has the pieces of the cup holder I cut off and attached so that the link would fit seamlessly into the dash. I installed male pins to the end of the power harness of the link so the pins can just be pushed into the harness for the clock. The egt sensor does not have a bung with it, they can be pick up just about anywhere and are about $20. I welded the one that came with the sensor to my header. The connector of oil temp gauge had some moisture enter the backside of the plug and eventualy corroded the connector so you will have to solder or crimp connect the harness for the sensor in the engine bay. $550 obo, just let me know if you have any questions. ----SOLD----
UTEC: I am selling my Utec from my 04 STi. It has been updated to the latest firmware. The remote map switch has been put into one of the larger style blank switchs so it can be installed to the left of the steering wheel by the intercooler sprayer button. Currently the Utec is set up to be run with a GM 3 bar map sensor(lets the Utec see boost up to 32psi and the stock ecu still uses the stock map sensor). IF the stock map sensor is to be used the calibration in the Utec will have to be switched back. This is a great setup for someone who wants to run a rotated mount kit and speed density. Everything listed will be included- Utec updated to the latest firmware, ground for Utec, 9v battery with power cable, GM 3 bar map sensor pn 12223861 with harness ready to connect to Utec, remote map switch, and all standoffs. There is no ABC with the setup. $550 obo, Just let me know if anyone has any questions.
MD FS: Full Defi BF White Setup!! Boost, EGT, Oil Pressure and Oil Temp + Controller! | LeeC | MAIC Private Classifieds | 5 | 03-16-2010 08:58 AM |
MD FS: Full Defi BF White Setup!! Boost, EGT, Oil Pressure and Oil Temp + Controller! | LeeC | Interior/Dressup/Audio & Security | 6 | 07-29-2009 12:54 AM |
Defi Gauges: Boost, Oil Temp, EGT, Hood, Control Unit and All Sensors $600 | 555ideways | Private 'For Sale' Classifieds | 7 | 06-23-2006 01:17 PM |
Defi Gauges: Boost, Oil Temp, EGT, Hood, Control Unit and All Sensors $600 | 555ideways | NESIC Private Classifieds | 3 | 06-23-2006 01:14 PM |
