11-19-2015, 05:21 PM | #19351 |
Member#: 403464
E. Canada
Vehicle:2008 Impreza sport h lightning red |
11-20-2015, 02:32 AM | #19352 |
Member#: 340297
Vehicle:2013 Impreza 5sp Prm Ice Silver |
If anyone here could do me a favor, it would be much appreciated. I'm trying to figure out what cars the 2012+ Impreza's share their suspension with mainly, and nobody seems to know, there is just a lot of conflicting information out there.
If anyone could take their stock OEM 2.5i springs and get pictures of them next to a ruler, and measurements of length and coil diameter, it would be very much appreciated, I've looked all over and can't find anything. Thanks! |
11-20-2015, 08:21 AM | #19353 |
Member#: 262503
Vehicle:2008 Impreza 2.5i |
^ What are you trying to do?
11-20-2015, 11:35 AM | #19354 |
Member#: 340297
Mainly I'm trying to figure out the coil thickness and length of the standard 2.5i Impreza to see if it's the same as the 2012+ Impreza, since nobody seems to know the springrate for that car. It seems the 09 WRX has the same length springs and of the same coil diameter, but I don't know if the rate is the same or not.
11-21-2015, 04:07 PM | #19355 |
Member#: 421814
Vehicle:2009 Impreza 2.5i Newport Blue |
Winter is coming.
11-23-2015, 07:23 AM | #19356 |
Member#: 271655
Vehicle:2009 2.5i Sedan Silver |
Big oil leak from behind the timing belt cover, I hope it is main cam seal and not the head gasket. Got laid off last week and this is not a good time for that :\
11-23-2015, 09:25 AM | #19357 | |
Member#: 262503
How many miles are you at? It's most likely head gasket. I did mine at 65k miles... These NA motors are notorious for head gasket failure. If it is, be sure to get it sanded and use a turbo gasket. Lots of information online about this. |
11-23-2015, 01:19 PM | #19358 |
Member#: 271655
I am at 64k miles. Do you have any suggestions on which gasket to get? I looked around and I see some say that the replacement OEM part has been redesigned.
11-23-2015, 02:19 PM | #19359 |
Member#: 262503
Still wouldn't trust the NA gasket. Both the dealership and local Subaru performance shop said go with a turbo gasket.
11-23-2015, 03:22 PM | #19360 |
Member#: 211395
South East
Vehicle:0000 4wfp Flintstone Mobile made of stone+wood |
The generation(s) notorious for HG failure were those prior to the 08+. Not to say it can't happen, but to say our NA's are prone to it would no longer apply.
11-23-2015, 04:15 PM | #19361 |
Member#: 146287
BAIC
Vehicle:2011 Impreza WRX 5D Satin White Pearl |
I've got signs of a failing HG...
11-23-2015, 04:43 PM | #19362 |
Member#: 262503
11-23-2015, 05:14 PM | #19363 |
Member#: 403464
E. Canada
I just got them redone at subaru, thank god for aftermarket part warrantys, did some suspension work and HG 1200$ nothing compared to 4gs
11-23-2015, 06:30 PM | #19364 |
Member#: 271655
Well, I took my car to the dealership and looks like it's not the HGs. The oil pump is leaking oil. They quoted $950 to replace that and to replace the timing belt and water pump along with it.
11-23-2015, 07:25 PM | #19365 |
Member#: 262503
I paid $800 flat for head gasket (both sides), water pump and timing belt from a Subaru only performance shops. It pays to have friends in the business!
11-25-2015, 08:54 AM | #19366 |
Member#: 330830
Vehicle:2010 Impreza2.5i 5dr Obsidian Black Pearl |
11-25-2015, 11:29 AM | #19367 | ||||
Member#: 271655
The car drives fine now although I will keep an eye out for any persisting problems with oil leaks. |
11-25-2015, 11:34 AM | #19368 |
Member#: 344260
NESIC
Vehicle:2009 Impreza OBS Sage Green |
11-29-2015, 09:11 PM | #19369 |
Member#: 434114
Hey guys does anyone know if an access port exists that works on a 2011 2.5i AT I've been looking everywhere and I emailed a few tuners nobody has gotten back to me yet. Please help im trying to get a stage 1 tune already have intake just need the access port
11-29-2015, 09:19 PM | #19370 | |
Member#: 355937
SCIC
Vehicle:2010 Impreza OBS Black on Black |
Nope no ap |
11-29-2015, 09:22 PM | #19371 |
Member#: 434114
Non existent or you just don't know. Do you think that the 2009 access port would work I don't know if there's any engine differences
11-29-2015, 09:25 PM | #19372 |
Member#: 355937
SCIC
11-29-2015, 09:27 PM | #19373 |
Member#: 262503
11-29-2015, 10:01 PM | #19374 | |
Member#: 403464
E. Canada
Witch year of sti struts did you put on? |
11-30-2015, 02:40 PM | #19375 |
Member#: 342985
ilwaukee, what are your wheel specs? Found a 18x9, 20et with 215 width tires but worried it will be quite aggressive. Thoughts compared to your setup?
08 2.5i and 08 Sti Suspension | WRXbrother | Brakes, Steering & Suspension | 10 | 08-22-2017 12:30 AM |
Will an 08 WRX intake fit an 08 2.5i? | Racing101 | Normally Aspirated Powertrain | 26 | 01-19-2012 11:57 AM |
08 STI Wing on 08 2.5i impreza | juny102004 | Interior & Exterior Modification | 13 | 01-18-2012 09:46 AM |
Will 08+ WRX gauges swap into 08+ 2.5i? | Simeon Priest | Interior & Exterior Modification | 10 | 03-26-2010 02:17 PM |
08 2.5i mod question | deunique1 | Impreza Forum | 1 | 10-03-2007 02:35 PM |
