Welcome to the North American Subaru Impreza Owners Club Sunday November 22, 2009
Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 11-06-2009, 05:10 PM   #26
X JBM X
Member#: 179639
06 STi / 96 Bronco
Bren Tuned
Originally Posted by tylerq219 View Post
also try putting in fuel cleaner (chveron). does it only do it when wet out? can you tell what side thats not idleing right? ie swap injectors and plugs
+1...I would definitely run some seafoam thru there.
X JBM X is offline   Reply With Quote
Old 11-06-2009, 05:11 PM   #27
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
plugs have been changed. i have a bottle of injector cleaner im going to put in shortly i just need to fill my tank first. it does it regardless of whether its wet/dry/cold/hot.
just got the call from napa and the sensors are in. going to pick them up and change them when i get home. wish me luck.
97 Pimpreza is offline   Reply With Quote
Old 11-06-2009, 07:22 PM   #28
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
URGENT! how do you remove the cam shaft sensor with the valve cover in the way? do you need to take of the valve cover on the drivers side to replace it?
Old 11-06-2009, 09:19 PM   #29
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
Anyone?
Old 11-07-2009, 12:38 AM   #30
tylerq219
Member#: 68213
92? justy rally car
white/blue/mud #44
wait wat?!
tylerq219 is offline   Reply With Quote
Old 11-07-2009, 12:58 AM   #31
rabbitnutz
Member#: 51940
View Member's Myspace Profile
sent you the .pdf's
rabbitnutz is offline   Reply With Quote
Old 11-07-2009, 03:12 AM   #32
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
wait wat?!
I had a day of so I actually had time to work on the car myself?
Old 11-07-2009, 03:20 AM   #33
tylerq219
Member#: 68213
92? justy rally car
white/blue/mud #44
does not compute
Old 11-07-2009, 06:05 PM   #34
subieyourself
Member#: 42874
06 STI / 92 Miata
07 Ford Edge / 05 Ranger
I had a nissan 240 that had similar symptoms. Turned out to be the cat. It was clogged or something. Not really sure how to check that without pulling the cat or how much work that is.
subieyourself is offline   Reply With Quote
Old 11-08-2009, 02:40 AM   #35
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
it's got a new cat.
changed the cam sensor today. it still drives like crap. its also backfired on 3
different occasions today. i filled my tank and put a bottle of injector cleaner in today as well...
this problem is really starting to stress me out
Old 11-08-2009, 01:56 PM   #36
dlong27
Member#: 191010
2002 Impreza TS
Dark blue n' rock chips
Looks like I've been beaten to it already, but definitely try Seafoam, put about 2/3 of the can in your gas tank, and try pouring about 1/3 of the can directly into your throttle body very slowly with the motor running, then turn it off, and start it back up about 5 minutes later. I just did this on my car, cleared a knock sensor CEL, and pretty much cured my cold start ticking. The idle is a lot more consistent now, and doesn't drop quite as quickly, best 10 dollars you can spend!!
dlong27 is offline   Reply With Quote
Old 11-08-2009, 07:09 PM   #37
IHateHynes
Member#: 88916
07 STi WRB+Silver
97 Impreza Wag Green+Rust
I see you changed the cam sensor, what about the crank? In my car the crank was the worst condition of the 2. It was covered in corrosion.
IHateHynes is offline   Reply With Quote
Old 11-08-2009, 09:01 PM   #38
bcarm
Member#: 100068
2008 STi
AW
Pimpin aint easy.
bcarm is offline   Reply With Quote
Old 11-08-2009, 11:35 PM   #39
eatus ravenous
Member#: 26068
2007 07 wrx tr
S.W.P Bren tuned
contact speen st automotive . they are an independent subaru only shop . they will not do you wrong .
tell them Big mike sent you .
eatus ravenous is offline   Reply With Quote
Old 11-09-2009, 12:39 AM   #40
bren wrx
Member#: 59454
E46 M3/E36 M3/RC51
tuning subies in MA
have you scanned it?
bren wrx is offline   Reply With Quote
Old 11-09-2009, 09:13 AM   #41
Acejam2k
Member#: 42645
2007 STi Stage 2
Crystal Gray Metallic
Blown headgasket.
/thread
Acejam2k is offline   Reply With Quote
Old 11-10-2009, 10:59 AM   #42
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
Yes, crank sensor was replaced before the cam sensor.
The car isn't driving any better (though it does have its good days).
I also don't think it's the head gasket since there is no smoke coming from the exhaust
and no coolant in under the oil cap.
Bringing her to a shop today... I just need to decide which one...
Oh, and thanks for those .pdf's rabbitnutz, they came in handy with the cam sensor.
Old 11-10-2009, 11:07 AM   #43
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
I think I am going to bring my car here today unless I discover any Subaru specific shops closer to me within the next few hours. Let's just hope it can make the drive...
Old 11-10-2009, 11:39 AM   #44
Garandman
Member#: 101117
2009 WRX 5 door
Right on. One of our '97 OBW's had the hesitation and SeaFoam nearly eliminated it. Just be prepared for the cloud of smoke.
Bet this car has 120K+ miles on it. I used to run a bottle of Techron through it a couple times a year.
Garandman is offline   Reply With Quote
Old 11-10-2009, 12:12 PM   #45
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
It actually just broke 100k last week.
Old 11-10-2009, 12:15 PM   #46
Bimmubishi
Member#: 48713
1988 Raider-1JZGTE
DSG PLEASURE EVO DRIVER
Is there a CEL for anything?
Have you removed the plugs to have a look at them?
Bimmubishi is online now   Reply With Quote
Old 11-10-2009, 01:12 PM   #47
rabbitnutz
Member#: 51940
NP. have you tried seafoam yet? i'm starting to think it might also be a stuck PCV or Idle Air valve.
Old 11-10-2009, 01:18 PM   #48
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
Read the OP before posting. No CEL's and the plugs were the first thing replaced.
Old 11-10-2009, 01:20 PM   #49
97 Pimpreza
Member#: 123693
2000 Impreza RS
STM
haven't done the seafoam yet. I was gonna do that today before I brought it to the shop. For a stuck PCV or Idle Air Control Valve would I just replace them or would I clean them? I know for my old Maxima I had to clean the PCV not replace it.
Old 11-10-2009, 02:04 PM   #50
Bimmubishi
Member#: 48713
1988 Raider-1JZGTE
I read the OP. There's no mention of it. Why don't you read your own OP.
I was more interested in what the plugs looked like not if they were replaced.
I'd keep helping you but you certainly don't appreciate my time. Later.
My car has been hesitating/bogging for a month and a half now. It wasn't that
bad at first it got progressively worse and now my car is pretty much undriveable
because it has a really bad hesitation, very little power and even sputters sometimes.
I have taken it to the shop 3 times in 2 weeks and shelled out way too much money
for the work that was done on a problem they still cant find. Does anyone know of any
shops around the Worcester/Sturbridge/Webster area that are cheap and good with
Subarus?
Things that have been replaced so far:
  • Spark plugs
  • Spark plug wires
  • Coil pack
  • Fuel filter
  • Crankshaft position sensor
  • Camshaft position sensor
  • (put injector cleaner in; need to do some more driving with this tank of fuel)
Bookmarks
Message Board Statistics All times are GMT -4. The time now is 05:53 PM.
