07-19-2007, 04:21 PM | #1 |
Member#: 96860
NWIC
Vehicle:2006 STI Black |
Need some help with Hella Horn Install
Hey guys, I just got my horns and I need some re-assurance with the things I have ..
Is this all I need for an install? Excluding crimper and strippers .. the one that remove wires not clothes! 16-14 Gauge Bullet Terminal Male/Female ATO Fuseholder 20AMP Fuse Heat Shrink 14 Gauge Wire
07-19-2007, 05:37 PM | #2 |
Member#: 83072
Vehicle:2016 WRX Lapis Blue Pearl |
Give a look at this thread to compare supplies needed:
http://forums.nasioc.com/forums/show....php?t=1133994 You'll want to get some female quick disconnect crimp on connectors. The connection terminals on the back of the hella's and on the relay they use have male quick disconnect terminals. And i would also advise getting one male quick disconnect to plug into one of your stock horn connectors so you don't have to splice the wire. |
07-19-2007, 05:44 PM | #3 |
Member#: 154455
you might want to get a multi-meter. to make sure you are grounded out properly and as well as having the right amount of current.
07-19-2007, 05:44 PM | #4 |
Member#: 154455
but other then that.. you look like you are all set.
07-19-2007, 05:46 PM | #5 |
Member#: 154455
sorry i am new to here.. and i was woundering about what kind of horns where you putting on.
07-19-2007, 05:47 PM | #6 | |
Member#: 112992
SCIC
Vehicle:2006 WRX TR Crystal Gray |
also a zip tie to mount the relay I took a look at the that thread and thats pretty much how you want to set it up |
07-20-2007, 09:11 AM | #7 |
Member#: 104078
Vehicle:2013 WRX SWP |
I also made some y-connectors pre install and soldered them and heat shrinked them which made my install go quickly!
07-20-2007, 09:12 AM | #8 |
Member#: 104078
07-20-2007, 09:18 AM | #9 |
Member#: 120152
safedrives is the vendor
occasionally you can find them used they are 118 dB horns (ie frikkin loud!) I would recommend putting a switch in there too so you can switch between the stock horn and supertones. you know, so when you toot at a friend you aren't making him go deaf, just the ass in the SUV who tries to sideswipe you last night |
07-20-2007, 07:43 PM | #10 |
Member#: 82147
SCIC
Vehicle:2005 WRX Sedan Aspen White |
Some Dielectric Grease for the terminals is also a good idea.
07-20-2007, 07:51 PM | #11 | |
Member#: 66540
Vehicle:2004 WRX Sedan 2005 Legacy GT wagon |
07-20-2007, 07:53 PM | #12 |
Member#: 96860
NWIC
Can anyone give me a certain size, nut/washers/bolts, that'll work for the 06 radiator on the sides?
07-21-2007, 02:28 AM | #13 |
Member#: 146086
Vehicle:2007 STi Limited 482 UGM |
They really arent that loud. Much louder and more manly than the stock horns, but I expected them to like break windows I guess. I also got them because they look tight.
Also, I bolted the relay behind the grey plastic part behind the right section of grill (if you can figure out wtf Im talking about). Fit perfect and completely protects it from rain. |
07-21-2007, 12:20 PM | #14 |
Member#: 152860
SCIC
Vehicle:2007 WRX Wagon |
Thats funny, some SUV yesterday was being really gay. Alright I was just sitting at a stoplight and some SUV comes up behind me and just stands the thing up with her brakes. Luckily I left an entire car length in front of me to the old lady in the caddy. So I moved up and this dang car inched up on me for a lot of the car length. They then started to inch right as they saw the light went green. They forgot about the old lady. I almost rearended the old lady by trying to avoid the dang SUV, stoplight after stoplight. God, I need some supertones. Does it affect the temperature of the motor? Two supertones that is.
07-21-2007, 11:20 PM | #15 |
Member#: 146086
On an 06/07, they are partly covered by one of the grill frame parts. Im sure they decrease the radiator cooling ability a little, but Ive never had problems and I havent heard of anybody else having problems either.
07-21-2007, 11:40 PM | #16 |
Member#: 96860
NWIC
Can anyone answer the bolt size on the radiator?
07-22-2007, 06:26 PM | #17 |
Member#: 144043
NWIC
Vehicle:06 Stage 2 sti OBP master tuned 298/313 |
I just used the stock bolts that were already there. I will post some pics in a minute once their done uploading. Just did my install today took about 1.5-2 hours. start to finish.
07-22-2007, 06:30 PM | #18 |
Member#: 144043
NWIC
Here's min installed didn't like them both being in the middle like everyone else so heres what I did.
Had to remove this piece from each side. All I can see that its for is to make the front a little more clean because it hides 2 bolts on each side. (might help direct air slightly). To remove them there are 3 screws on the top of each piece and then there is a clip on the bottom. Once you get them apart just put the screws back in because thats what holds your outer trim piece on. After removing them you will find a bolt on each side that is holding part of the radiator (i think) you can't miss them because the are in the exact same place on either side. |
07-22-2007, 07:52 PM | #19 |
Member#: 78893
VIC
Vehicle:2013 Scion FRS |
i just installed it in the center. it isnt straight, so the hellas look like they are
havent had a problem since. and boy do i love using them |
Need help with Hella Horns install. | Angel81 | Mid Atlantic Impreza Club -- MAIC | 5 | 04-14-2009 07:26 PM |
help with hella horns | markadopolus | Electrical & Lighting | 9 | 05-28-2005 06:05 PM |
Might need some help with Cobb AP install (Portland Area) | Dark Baal | North West Impreza Club Forum -- NWIC | 5 | 03-04-2005 11:47 AM |
Need help with hella 500 install please! | workin4audi | Electrical & Lighting | 10 | 09-02-2004 04:40 PM |
Need some help with an install, pics within! | dorifto88 | Interior & Exterior Modification | 5 | 04-26-2003 11:26 AM |
