11-01-2005, 02:24 PM | #1 |
Member#: 34986
Vehicle:2003 WRX Black |
Any advantage to a protune AP Stage II? Anyone sharing protune maps??
Im running Helix UP/DP with a stromung dual tip catback. Currently I'm running AP stage II right off the shelf.
Couple questions. With this setup what kind of gains, if any could you get from a protune. Second, is there anyone out there sharing protune maps? Anyone have one that I could try with my setup? Just wondering...
11-01-2005, 05:03 PM | #2 |
Member#: 58163
Vehicle:2002 Stage 2 WRX World Rally Blue |
I am not sure you can share protuned maps, I may be wrong though.
Either way using someone elses protuned map on your car is a bad idea. Stock cars can perform different from each other, then when you start modding they become even more different. Same mods doesnt equal same tuning. OTS maps are very conservative which is why they can be used by everyone. Custom maps are car specific, so using one not made for you your car may run fine, may lose performance, or may have you purchasing a new engine. I would not risk that for the possible 10-20 hp from a custom tune on Stage II. |
11-01-2005, 05:31 PM | #3 |
Member#: 32764
Vehicle:2003 WRX with 91K New Motor & Paint WRB |
Would you guys say that cobb stage II runs closer to lean? My issue is I pulled my plugs at 55K and they were rather white... I was running a txs short ram and for part of the time a TXS RFL BOV..
I have the money for an AP but not for EGT and airfuel gauages and a decent boost gauge... what would you recommend I do... If stage II is safe enough and I keep and eye on my temps and oil levels think I should give it a go... I have the factory boost gauge. |
11-01-2005, 07:06 PM | #4 |
Member#: 77483
NWIC
Vehicle:2009 Audi A3 2.0T q Lava Grey |
No, most people would say that the Cobb OTS maps run rich. Your BOV and SR made it run lean .
11-01-2005, 09:03 PM | #5 | |
Member#: 95396
SWIC
Vehicle:2004 silver wrx Cobb AP Stage 2 |
Cobb AP Stage II OTS w/ K&N Typhoon, anyone Test? | subaru_steve | Newbies & FAQs | 36 | 07-21-2010 07:30 PM |
Cobb Stage II vs. Td04 Protune ? | SideWay | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 6 | 11-29-2007 11:46 PM |
Gains from Protune over Stage II | advanracing62 | AccessPort | 19 | 06-03-2007 09:21 PM |
AP Stage II Maps ? | Assassin4457 | AccessPort | 0 | 12-05-2006 12:05 PM |
Any advantage to a protune AP Stage II? Anyone sharing protune maps?? | seasons | Engine Management & Tuning | 21 | 11-08-2005 12:52 PM |
