05-29-2008, 12:42 AM | #1 |
Member#: 181127
Vehicle:1999 Civic Rust |
Couple Qs about the 08...
Well I just got an 08 WRX. I want to put HIDs on it but I was wondering if the DRL will cause something to go wrong. I thinking not but safety first .
Also what is the difference between a Turbo-Back and a Cat-Back? Thanks!
05-29-2008, 12:44 AM | #2 |
Member#: 169656
NWIC
Vehicle:2008 WRX 4DR SSM 331hp/362tq MPS tune |
Turbo back has aftermarket downpipe...catback uses stock cat/downpipe.
05-29-2008, 12:49 AM | #3 |
Member#: 181127
05-29-2008, 01:08 AM | #4 |
Member#: 164049
NWIC
Vehicle:2002 WRX MBP stg2 dom tuned |
aftermarket dp+aftermarket cat back=turbo back. Doesn't matter if it has cats or not, thats for you to decide.
05-29-2008, 01:18 AM | #5 |
Member#: 181127
Now lights?
05-29-2008, 01:59 AM | #6 |
Member#: 171076
SCIC
Vehicle:2011 Wrx DGM STG 2 |
you would want to disconect the DRL the lower voltage on the DRL circuit will mess things up. HID's need a good 12v's for the initial start up
05-29-2008, 08:33 AM | #7 |
Member#: 181127
05-29-2008, 12:56 PM | #8 |
Member#: 176519
NESIC
Vehicle:2009 BMW 335i xDrive Barbera Red |
Disable your DRL's. Drop in some 2008 STI HID's. Plug and play. That was my first mod and it was really easy. Only problem is finding 2008-09 STI headlights for less than $1200. Check people who work with insurance reclamations. I got mine from a guy on here for $475 that were off an '08 STI that got rear-ended with only 500 miles on the odometer. Plus, they'll be super easy to resell if you ever get rid of your car.
05-29-2008, 02:59 PM | #9 |
Member#: 181127
I don't think you guys know what I am trying to say
Ok, the DRLs run on the high beam bulbs..Right? I want to get HIDs for the LOW BEAM. My question is Will the DRLs interfere the LOW BEAMs when the HIDs come on? I myself don't think so, but then again I am not to sure. Better safe than sorry. |
05-29-2008, 03:44 PM | #10 |
Member#: 107000
Vehicle:2015 BMW X1 |
Just disconnect the DRL's you will have no problems with the HID's.
Nice to see you made it over here. |
05-29-2008, 04:44 PM | #11 |
Member#: 181127
05-29-2008, 07:16 PM | #12 |
Member#: 171076
SCIC
sorry dude had mine disconnected so long i forgot... if you dont mind the DRL then you can keep em without any worries with the low beam HId's
05-30-2008, 01:31 AM | #13 |
Member#: 44501
NWIC
Vehicle:that 's, like, your alternate facts, man. |
05-30-2008, 09:26 AM | #14 |
Member#: 181127
05-30-2008, 11:35 PM | #15 |
Member#: 174252
TXIC
Vehicle:2014 BRZ SWP |
disabling your drl would be wise if you like your hid kit
my corolla's started flickering with drl so i had to disable (it was annoying and im sure the bulb did not like flickering either) |
05-31-2008, 02:00 AM | #16 |
Member#: 156861
Vehicle:2005 LGT Wagon 5MT color |
Not for the OP, but for future knowledge.....
When you install a retro or a kit Xenon lights, just use a relay to power the ballast. That way the ballast always gets 12v when signal is sent to it (DRL or normal headlight). No flicker...no damaged expensive lights |
05-31-2008, 10:02 AM | #17 |
Member#: 48199
Vehicle:06 WRX WRB |
Easiest way to remember...
Turbo Back = Goes from the turbo to the tail pipe. Hence turbo back.... Cat Back = Goes from the catalytic converter back. Hence cat back.... Whether you use a aftermarket highflow cats or no cats isnt part the equation. The difference is where the pipe starts. Since the cats are in the downpipe (pipe that connects the turbo to the cat back section) thats they pipe that makes the difference between a turbo back and cat back.... See what I'm saying? Turbo back = downpipe + cat back.... |
I've read about the 08 being loud in the back, how about the front? | newportbleucheese | Impreza Forum | 4 | 04-17-2009 11:57 PM |
Couple Qs about tuning... | aboogabooga | Tri-State Area Forum | 1 | 07-07-2008 07:05 PM |
06-07 Forester XT 5mt power handling limits? And a couple Qs about the recent 5MTs | Davenow | Transmission (AT/MT) & Driveline | 12 | 05-02-2007 11:30 PM |
Couple questions about the windshield heater button... | STL WRX | Interior & Exterior Modification | 2 | 02-09-2007 03:05 PM |
couple questions about the WRX | notorious | Newbies & FAQs | 6 | 05-06-2002 12:06 AM |
