Welcome to the North American Subaru Impreza Owners Club Tuesday March 19, 2024
Old 11-27-2012, 08:23 PM   #26
rube23
Member#: 92710
2008 STi
Obsidian Black Pearl
The JDM double din bezel eliminates those gaps! but the camera is covered though, not sure if thats a deal breaker for anyone.
you will have to do some minor trimming to the tabs which hold the air vent in place, either for the stock bezel and the JDM version. I checked both.
Dont mind the fingerprints !
rube23 is offline   Reply With Quote
Old 11-27-2012, 08:35 PM   #27
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
rube23 - that's awesome news! I was wondering if the overall height would work with the JDM panels. No need for me to wonder now
Here are the dimensions in case anyone needs them. We have plenty of every color in stock, plus a new faux carbon piece (not on the site yet)!
Click the image for more photos and details
[email protected]
IA Performance is offline   Reply With Quote
Old 11-27-2012, 09:02 PM   #28
zedix
Member#: 336913
2010 Impreza Ltd
Interesting! Do you ship to Canada? I'd definitely consider returning the double DIN kit I got and buying one of these instead...
zedix is offline   Reply With Quote
Old 11-27-2012, 09:20 PM   #29
IA Performance
Member#: 25194
Dark Gray
zedix - we sure do. A PM is on its way to you now.
[email protected]
Old 11-27-2012, 09:25 PM   #30
rube23
Member#: 92710
2008 STi
[email protected]
do you have any pics of the faux carbon fiber piece?
Old 11-27-2012, 09:27 PM   #31
zedix
Member#: 336913
2010 Impreza Ltd
[email protected]
Thanks, PM'd you right back.
Anyone know the difference between the Subaru of America bezel and the Japanese ones? Any difference apart from color?
Old 11-27-2012, 09:31 PM   #32
rube23
Member#: 92710
2008 STi
the Subaru of Japan Double DIN AV Panel Black Silver has a nice thin black rubberized coating on it and is silver painted on the edges....thats the one in my pic above. I think thats the best looking one.
Old 11-27-2012, 09:50 PM   #33
IA Performance
Member#: 25194
Dark Gray
rube23 is exactly correct. The only difference is the texture. The JDM unit has the thin rubberized matte finish, whereas the US version has a semi gloss finish (not rubberized).
If you send me an email address I can send over the carbon photos tonight.
[email protected]
Old 11-27-2012, 09:53 PM   #34
rube23
Member#: 92710
2008 STi
sent you a pm with email address. thanks!
Old 11-28-2012, 09:11 AM   #35
Angelus911
Member#: 89967
2020 Volvo S60
Gray
This is awesome, wonder how this would work in a '12 Impreza. It amazes me just how ****ty car audio headunits are out there in terms of UI. Wish a company would take the tablet market and integrate that into headunits.
Old 11-28-2012, 10:07 AM   #36
V8sPFFF06sti
Member#: 236314
2015 WRX Limited
Pearl White
could you use the first dash piece and fit a regular ipad back there? so the opening would be mostly screen?
just a hypothetical
and im guessing you could do something similar with a ipad mini (same dimensions as a nexus 7)
when you installed the jvc head unit did you have to get a install kit for that? like the slide in bracket thingy?
i have 08 STi so no phone option so if i did this i woundnt have to worry about that part i would just want it for touch screen.
V8sPFFF06sti is offline   Reply With Quote
Old 11-28-2012, 01:49 PM   #37
zedix
Member#: 336913
2010 Impreza Ltd
Nope It's just sitting there. I didn't want it to be flush with the bezel so an install kit would have just gotten in the way. There's support in the enclosure for it so it's just lying there. Keeping it simple!
Old 11-28-2012, 02:56 PM   #38
thinkjoey
Member#: 339169
2009 Impreza 2.5i
This is spectacular. Great stuff.
thinkjoey is offline   Reply With Quote
Old 11-28-2012, 04:06 PM   #39
nrizzo
Member#: 284164
2009 WRX Sedan
WRBlue
Does anyone know if there is a way to keep the headunit controls without having a headunit hidden somewhere? I am planning on doing this, but I already have amps from a previous install so I was planning to just wire the nexus directly to an amp.
Also are there any ideas on how to integrate a backup camera into a Nexus setup like this?
nrizzo is offline   Reply With Quote
Old 11-28-2012, 04:26 PM   #40
V8sPFFF06sti
Member#: 236314
2015 WRX Limited
Pearl White
i know on the 06-07 there was specific kit set up you could buy that held an ipad and then you mounted the headunit where the clock was. check if someone makes an alternate mounting place for headunits.
i would think you would have to run the nexus through the headunit through the amps to the speakers.
you would have to check the specs of the nexus if it allowed incoming video and buy the proper cord.
Old 11-28-2012, 09:28 PM   #41
Ish9
Member#: 210884
2008 Impreza STI
He could do it with out the radio. I did a similar setup with the original Ipad. Used an Ipad to RCA cable, ran that to a six channel equalizer, then from there to two amps(one for sub the other for components) then to the speakers. It gives you tons of control and a solid setup.
Ish9 is offline   Reply With Quote
Old 11-28-2012, 10:26 PM   #42
V8sPFFF06sti
Member#: 236314
2015 WRX Limited
Pearl White
/\ word
Old 11-29-2012, 09:58 AM   #43
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
So I take it your tablet has cellular service since it is downloading from the cloud? When you pair your phone are you pairing with the tablet or to the headunit? It will be a pain to pair to the headunit since you have to pull the dash apart to access the buttons (i guess you would only have to do this once though). It would also be a pain if you actually use the normal radio since you wouldn't have access to preset buttons which I guess your steering wheel controls would scroll through but if you ever pull your battery and lose your presets then you have to pull the dash again.
Idk I see positives and negatives, but whats important is that it works for how you want to use it.
KOJAK-02-WRX is offline   Reply With Quote
Old 11-29-2012, 10:18 AM   #44
Salvation27
Member#: 292403
2012 Legacy
Graphite
He has his cell phone's data plan teethered to his tablet. Easy to do with free apps from the market.
Also- if you want Radio on tablet- IheartRadio, TuneIn or other apps provide live audio feeds on 1000s of stations as well
Salvation27 is offline   Reply With Quote
Old 11-29-2012, 10:20 AM   #45
Salvation27
Member#: 292403
2012 Legacy
Graphite
Originally Posted by rube23 View Post
Use a dremel- and notch out a hole for the camera- but I don't see you using it that much- unless you Skype from car or want to take pics of you and your friends driving rocking out
But, overall, this is great. Wish I had $$ to buy a Nexus 7. My Touchpad (with Android on it) is too big 10"
Old 11-29-2012, 12:35 PM   #46
V8sPFFF06sti
Member#: 236314
2015 WRX Limited
Pearl White
Old 11-29-2012, 01:16 PM   #47
zedix
Member#: 336913
2010 Impreza Ltd
- Tablet is auto-paired to phone via BlueTooth as soon as they are within range. Phone calls and texts are displayed on the tablet (app is called TabTalk). That also gives the tablet full internet using the phone's data plan.
- My phone is paired to the headunit using BlueTooth as well. This lets the call's audio go to the head unit. Once they are paired you never need to touch the headunit again.
- Normal radio is done using TuneIn radio on Android.
I don't see any negatives
Old 11-29-2012, 01:18 PM   #48
zedix
Member#: 336913
2010 Impreza Ltd
Definitely thought about this, but without the headunit you would lose two things:
- Handsfree Bluetooth calling
- Steering wheel controls
Old 11-29-2012, 01:38 PM   #49
KOJAK-02-WRX
Member#: 208052
2004 SGM FXT-6speed
*SOLD* 02 PSM WRX
Dang you, now I want one
Old 11-29-2012, 01:45 PM   #50
spawn11587
Member#: 79603
Excellent pics
spawn11587 is offline   Reply With Quote
