11-10-2014, 01:19 PM | #101 |
Member#: 232477
Vehicle:2015 WRX STi |
Very cool junior. What do you expect out of the super 99?!?!
11-10-2014, 01:46 PM | #102 |
Member#: 64908
Vehicle:10.8 XT+9.2@155 GR+ 9.1/157mph 2015 STI |
So far I have reached my goals with the different setups/turbos.
I honestly expect to break the car on the 99. I dont know what lets go, but I plan on something not being happy with the extra 100-150whp I plan on giving the car. If it holds together I expect 9.2-3s at 153-155mph passes |
11-10-2014, 04:34 PM | #103 |
Member#: 319017
Vehicle:15 Prius 2JZ miata Death Trap |
Can't wait to see what the super 99 breaks so I can plan on the same part breaking . That turbos massive.
Sent from my iPhone using NASIOC |
11-12-2014, 07:29 PM | #104 |
Member#: 199906
Vehicle:2008 Infiniti G37S World's quickest: 11.13" |
Hey man: BIG props on those 9.68 AND 10.53 passes. I'm impressed but not surprised. Like an olympian, you make it LOOK easy.
If I was at a stadium, you know what bleacher side I'd be sitting on , however, I love a good scrimmage as much as the next guy. Well played! Coop (Who put his Mustang GT auto into the elevens last Sunday at Island) |
11-13-2014, 09:29 PM | #105 |
Member#: 64908
11-13-2014, 09:38 PM | #106 |
Member#: 134211
wow clean break, do the make a hardened output shaft with out having to install a complete (race gearset) ?
11-13-2014, 10:35 PM | #107 |
Member#: 145585
Vehicle:2002 S202 10.8@128 Yellow |
Great Runs!
11-14-2014, 09:04 AM | #108 |
Member#: 76785
Vehicle:2000 700Whp The RSTI SRP |
looking good! cant wait to see a clean pass!
11-14-2014, 09:34 AM | #109 |
Member#: 58957
Vehicle:2010 WRX STI SSM |
if the tires are not wrinkled it aint right
11-15-2014, 11:24 AM | #110 | |
Member#: 64908
Right now the output shaft is the fuse, until the good diffs go in and carbon DS I rather not break more expensive parts by upgrading the output shaft. I can deal with breaking the OEM ones. For what it is worth the P&L drag car uses a twisted 5-6yr old stock output shaft and cuts plenty of 1.3 60fts. Granted my car is about 1k heavier, but I think I will be ok with it. Thanks Neither can I!! This turbo at the same LC settings as the old PTE builds 10 more psi of boost. I think the days of bogging are behind us now. That is how I feel about it as well. |
11-15-2014, 11:34 AM | #111 |
Member#: 319017
Super 99 on or?
11-15-2014, 12:23 PM | #112 |
Member#: 64908
11-15-2014, 12:24 PM | #113 |
Member#: 319017
Want to shareeeeeeee some more info on how much power she made .
11-15-2014, 01:04 PM | #114 | |
Member#: 64908
I didn't dyno it BUT it's sipping way more fuel at the same boost then when it trapped 147. I will get it on the dyno eventually, but likely not before I go to the track. It spools almost identical but used up the rest of my fuel system Sent from my iPhone using NASIOC |
11-15-2014, 08:41 PM | #115 |
Member#: 285083
Vehicle:2006 STi WRB |
Im confused with so many changes going on all the time lol but is this the same car or a different car then the car you had at MIR-world cup finals on the ETS tmic?
Also what did you end up thinking of the GS tmic and the ETS tmic? |
11-15-2014, 11:09 PM | #116 |
Member#: 207638
TXIC
Vehicle:2004 WRX Yellow |
Same car.
11-15-2014, 11:25 PM | #117 | |
Member#: 64908
I like the ETS TMIC better, it worked exactly as I thought it would. Nothing wrong with the GS, but the ETS did work better for me. |
11-20-2014, 11:42 AM | #118 |
Member#: 48350
Vehicle:WRX 03/04/07 hybrid PSM |
In an honest opinion, would the ETS Top mount work well for a daily driver with a 58-65 lb/min turbo? Cruising around with the occasional pull. It looks like it works well for the strip. 04 Sti.
Thanks, James |
11-20-2014, 12:20 PM | #119 |
Member#: 76785
I ran a TMIC on the Dom4 for a year and would say yes, it would work well in the application you described.
11-21-2014, 11:54 PM | #120 |
Member#: 241943
Vehicle:2065 Magic Carpet Swirl Rally Bleu |
Crazy stuff Junior... Excited to see what it does with the super 99, sub'd
11-23-2014, 10:22 PM | #121 | |
Member#: 64908
Nice work with the Mustang, the v8 TT life has been calling my name for some time now Some updates Took the car to test and tune again today. Pretty happy with the results so far. Turned the boost to 35psi for the first pass Didn't get the slip because I was told to slow down and go to tech. I literally had to chase down the guy in the other lane for a picture of it Turned up the boost to 39, bogged to a 1.9 ran it to the 1/8th and then slammed the brakes HARD to not get the boot.... Still run a 10.8@88mph and get the boot, no slip. Find the guy and the car went 118.XX to the 1/8th The way she is picking up the mph on the back half, I expect some nice trap speeds on a full pass at that power level. I think I want to finish the season on the 17s and not break anymore axles or trans parts with the slicks. Jr |
11-23-2014, 11:29 PM | #122 |
Member#: 166005
Vehicle:2005 Saab 92x Beaten Silver |
is that on the PTE or super9x?
Way to get down, but it sounds like you need to hunt down a rental! |
11-24-2014, 01:14 PM | #123 |
Member#: 170370
South East
Vehicle:2006 STi Precision 6262 Powered... |
Great numbers man! Im looking forward to see what it does all out on the super99 with the 15's.
11-24-2014, 05:01 PM | #124 |
Member#: 377106
Vehicle:2015 WRX WRB |
11-26-2014, 11:48 PM | #125 |
Member#: 64908
