04-28-2010, 01:56 AM | #1 |
Member#: 132978
Vehicle:2004 Mike angel tund efr 7670 1.05 Twiscroll |
dyno tune 2.35L Ej22t sti heads gt35r 571 whp @ 25 psi
its come a long ways, still needs more work. id2000's will be the next round.
big thanks to kert millerspec.com, mike @ cnc motorsports. dyno pull Location: CNC motorsports Las Vegas NV Temp: 76 F elevation: 2028 above sea level weather: cloudy Car: 2004 wrx Tuner: Kert Miller Millerspec.com Dyno: dynocom dc pods transmission: 5 speed 1-4 ppg helical synchro stock 5th All pulls were in 3rd gear base line pull: 07 sti stock 251 whp @5700 rpm target boost: 30 psi Peak Torque at RPM: SAE J1349 Target Boost: 30psi Target AFR: 10.8 @ 28psi Fuel: E85 105 Octane Unleaded mods: engine:2.35L ej22t block: sti crank, pauter forge rods, cp forged pistons, stock sti heads. all blueprinted balanced, built by revolutionmotorsports in Colorado by adam (drac9 on nasioc) Custom Perrin gt35r .82 a/r rotated kit full 3" downpipe, anti surge housing tial 44mm wastegate. Arc ram intake. Perrin equal length headers, 3" custom full catback. Fuel: e85, walbro 255 feeding custom coverperformance surgetank feeding bosch 044 external pump. sard 110psi max fuel reg, Bosch ID1000's injectors, aeromotive fuel rails, push lock an fittings. cooling: Greddy grex oil cooler, blitz radiator, Full race Reverse FMIC, tial bov. crucial thermostat. drivetrain: PPG 1-4 helical synchro trans, Twin exedy clutch, r160 quaife lsd rear diff. Electronics: HYDRA 2.5v EMS closed loop, aem digital gauge: fuel pressure, oil pressure, coolant temp, boost, apexi egt. dyno plot @ 25psi Uploaded with ImageShack.us dyno plot @ 24 psi
04-28-2010, 02:58 AM | #2 |
Member#: 167462
SCIC
Vehicle:2003 wrx sedona red |
what does a stock sti or wrx pull on this dyno and why are you only revving to 7k?
04-28-2010, 03:04 AM | #3 |
Member#: 239875
TXIC
Vehicle:2010 STI |
bro, the music is real tight but I'd like to actually hear your car.
04-28-2010, 03:26 AM | #4 |
Member#: 105814
04-28-2010, 03:51 AM | #5 |
Member#: 132978
04-28-2010, 03:54 AM | #6 |
Member#: 132978
04-28-2010, 08:06 AM | #7 |
Merci Buckets
Moderator Member#: 88606
Vehicle:2018 Grand Cherokee Velvet Red Pearl |
We have a required format for posting dyno tunes/pulls and 1/4 mile times in prove power bragging. You can find the format here. Please update your first post when you get a chance. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764 |
04-28-2010, 08:22 AM | #8 |
Member#: 87653
South East
Vehicle:97 Supra / 17 GTR 16 Z06 / 07 STI / 05 Evo |
This is crank hp?
04-28-2010, 10:00 AM | #9 |
Member#: 140163
Vehicle:03 STi hellaflunctional |
no mod list, no care nice numbers though.
edit: saw the mod list in the video |
04-28-2010, 10:38 AM | #10 |
Member#: 103232
Vehicle:GTX 3071R'd 11WRX PPG,4.44,LSD,E85,6spdx3 |
+1^^^ mod list...
04-28-2010, 10:57 AM | #11 |
Member#: 54304
South East
Vehicle:04 STi TopSpeed-dAng! |
That dyno chart is hard to read.
Does it show that you are losing power from 5600 to 6300 and then making power again??? why would this happen? |
04-28-2010, 11:21 AM | #12 |
Member#: 198522
Vehicle:00 LGT -> WRX swap White Birch |
04-28-2010, 11:59 AM | #13 |
Member#: 132978
ok stock pull 07 sti 251 @ 5700rpm on this dyno.
majority of mods are in beginning of video. |
04-28-2010, 01:05 PM | #14 | |
Member#: 140163
your thread is gonna be locked if you don't follow the format stated in this thread... |
04-28-2010, 01:44 PM | #15 |
Member#: 89554
Vehicle:2006 EVO SE Black E85 30PSI dd |
Need to clean up timing, that dip can be reduced with a nicer curve.
04-28-2010, 02:37 PM | #16 | |
Member#: 54304
South East
The fuel system was capable of making 570 hp at 5600 but only ~500 hp at 6000... Most tunes I see have the same AFR at 5500 as 7000 rpms. Unless they decided to run a good bit richer above 5500 the dip has to be something else... |
04-28-2010, 09:31 PM | #17 |
Member#: 186870
SWIC
Vehicle:2010 WRX OBP |
Car must pullllll
04-28-2010, 11:00 PM | #18 |
Member#: 151009
Vehicle:05 STI OBP under construction |
very nice must badass on the road...can you post some pics of the engine bay i want to see how rotated intake mani set up came out
04-29-2010, 02:56 AM | #19 |
Member#: 132978
updated, hope this pleases the mods. sorry for not following format.
04-29-2010, 08:54 AM | #20 |
Member#: 198522
cams?
04-29-2010, 10:45 AM | #21 |
Member#: 108089
Vehicle:2003 WRX NF Performance |
need some headwork
04-29-2010, 06:04 PM | #22 |
Member#: 112179
Vehicle:2015 0RS,15STI,16wrx Red, Black, Black |
Did you sleeve the block?
04-29-2010, 06:10 PM | #23 |
Member#: 36033
SCIC
Vehicle:CEO PhatBottiTuning 2006 STi GTX3582 + Meth |
assuming that your boost isnt falling off the planet up top it would seem your car should be able to take a crap load more timing.....that 100hp fall off is weird.
A gt35 should be making peak hp close to redline on a 2.35 litre. |
04-29-2010, 10:41 PM | #24 |
Member#: 219094
Vehicle:07 95L-RS Rally custom OBS paint |
04-30-2010, 12:35 AM | #25 |
Member#: 56203
Vehicle:00 RSTI Coupe Twin Scroll 2.5XTR EJ207 |
you can still sleeve it...and peps do
