08-30-2010, 07:39 PM | #1 |
Member#: 48191
Vehicle:2012 WRX Ducati Monster |
Lining up engine with transmission spline
Engine is out of the car for delta cams, new clutch and related maintenance items. I spent about 4hrs yesterday trying to get the engine lined up with the transmission which is still installed in the car with no success at all.
Most every clutch install guide I read says to pull the tranny not the engine, I'm wondering, should I just pull the tranny and either mate them outside the car and install as one unit OR pull tranny reinstall engine then tranny. I'm open to any tips and tricks for getting engine to line up as is, otherwise looking for suggestions for easiest resolution.
08-30-2010, 07:55 PM | #2 |
Member#: 54525
Vehicle:2000 ej20g rs blue ridge pearl |
Spinning the crankshaft pulley has worked for me in the past. The only other advice I have is be patient. Sometimes it helps to jack the transmission up an inch or so and that can help it slide together.
08-30-2010, 08:33 PM | #3 |
Member#: 173615
Vehicle:2015 WRX Limited DGM |
are you doing this yourself? I've always spun the driveshaft with it in gear to get it to spline
08-30-2010, 08:34 PM | #4 |
Member#: 89233
South East
Vehicle:99 RS Aspen White 2014 Outback SWP |
It is a little harder to line it up with the motor swinging. As long as you have the disc aligned in the center, it will just take a little patience.
08-30-2010, 08:47 PM | #5 |
Member#: 65347
all about the angle... make sure the dogbone is off and jack up the trans as high as you can so the engine mounts clear. Then hang the engine on the sling in the same angle. And finally as already mentioned you can spin the crank to help it mesh. If everything is on point it will come right together.
08-31-2010, 10:12 AM | #6 |
Member#: 42970
Vehicle:1998 2.5RS BlkDmdPrl 2000 2.5RS SilverthornMet |
Please, by no means take this as an insult...But did you use an alignment tool when you installed the clutch? Did you replace the pilot bearing and is it seated properly?
If so, sorry for stating the obvious. Crazier things have happened... -adam |
08-31-2010, 10:34 AM | #7 |
Member#: 120
AKIC
Vehicle:1997 Legacy 2.5GT 1996 Impreza coupe |
Agreed with all the earlier comments. The few times I've done this I had the front of the car up on low jackstands, then used a floor jack to jack up the front of the tranny (basically until it hit the top of the tranny tunnel), and had the engine on an angle (rear of the engine lower) so that it would line up. A breaker bar on the crank bolt will let you jiggle the crank a bit - shouldn't take much.
Pat Olsen |
08-31-2010, 03:19 PM | #8 | ||
Member#: 48191
The car currently sits on jack stands at close to their highest point, i was thinking that being so high made it tough to get proper leverage, lowering it to their lowest setting will be part of my next round of battle. |
08-31-2010, 03:40 PM | #9 |
Member#: 41986
Vehicle:'06 STI/'85 Brat |
I bolt the clutch disc in the pressure plate but leave the bolts just hand-tight so the disc wiggles around a bit. Then I push the tranny onto the engine and tighten the bolts through the starter hole once everything is lined up. No alignment tool necessary.
Disclaimer: I'm not sure if that's an acceptable/safe/smart way of doing it, but that's how I've done it. I'm not an expert, and my posts don't replace thinking Jacob |
08-31-2010, 06:14 PM | #10 |
Member#: 114177
RMIC
Vehicle:2004 Impreza 2.5rs 70 Datsun Fairlady |
I pulled the engine on mine, i think it's easier to install the cams with it out and i also did the Exedy LW flywheel and clutch while it was out. Cams and flywheel made it real fun. Is it getting close enough the pins are hitting? also it does make it a ton easier if the trans is jacked up and angled toward the engine a bit.
08-31-2010, 07:55 PM | #11 |
Member#: 38469
Vehicle:07 LGT spec-b Crystal Grey Metallic |
I put a little bit of grease on the splines and make sure theres no rust on the input shaft. keep it in gear, raise the trans, put a wrench of the crank pulley bolt and move it around and it usually slides in. Its not easy if you're doing this by yourself...sounds like you are. keep the faith, it'll go.
09-05-2010, 08:56 AM | #12 |
Member#: 48191
Update: I lowered the car from the jackstands 2nd highest position to their lowest position and was able to get the engine/tranny to mate within 10 minutes.
Similar Threads | ||||
Transmission splined shaft alignment | pkejsn | Transmission (AT/MT) & Driveline | 0 | 03-12-2010 06:00 PM |
2003 engine line-up | Drummer | Normally Aspirated Powertrain | 1 | 01-19-2009 12:00 PM |
remove wrx 04 transmission splines | Crazy650 | Transmission (AT/MT) & Driveline | 0 | 10-15-2007 11:57 PM |
2.0 EJ20 Engine With Transmission Only 25,000 miles on both | Ravenous | Private 'For Sale' Classifieds | 9 | 06-01-2004 05:37 PM |
ARGH! Up Pipe about an inch off line up with manifold | Altered BeasT | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 10-29-2001 10:03 AM |
