03-12-2010, 06:00 PM | #1 |
Member#: 240977
PRSIC
Vehicle:2000 outback wagon Blue |
Transmission splined shaft alignment
I had some backlash causing noise in the center diff gears on my 2000 2.5L A/T, so I removed the transmission, dis-assembled the diff case and added thrust washers to remove the backlash/noise. (I'm a gear engineer, so that part comes easy) I'm now re-assembling and asking what the best way is to assure alignment with the splined shafts and notched collar, so I dont damage the transmission when I tighten the tranny back up to the engine.
I have the tranny back in position and the small snap ring back in place on the collar already, but the bolts start resisting with about 3/8" left to go. Any feedback would be greatly appreciated.
95 Impreza 1.8 engine, transmission, diff, shaft, axles | DariusL | 1993 - 2001 Impreza Specific Parts | 7 | 04-19-2009 06:47 PM |
Propeller Shaft alignment | mc2 | Transmission (AT/MT) & Driveline | 3 | 04-08-2009 09:46 AM |
Machine Shops That Spline Shafts? | dan1587wrx | Tri-State Area Forum | 4 | 02-12-2009 12:58 PM |
remove wrx 04 transmission splines | Crazy650 | Transmission (AT/MT) & Driveline | 0 | 10-15-2007 11:57 PM |
Clutch disk loose on input shaft splines? | Bird61780 | Transmission (AT/MT) & Driveline | 0 | 04-18-2005 10:34 PM |
