View Poll Results: Which Color do you like? | |||
Gold | 294 | 27.68% | |
Hyper Silver | 139 | 13.09% | |
Chronium Black (gunmetal'ish) | 366 | 34.46% | |
Flat black | 229 | 21.56% | |
Bronze | 143 | 13.47% | |
Multiple Choice Poll. Voters: 1062. You may not vote on this poll |
04-12-2015, 11:02 PM | #8051 |
Member#: 110065
NESIC
Vehicle:13 Impreza Sport |
Finally got some wheels. XXR 527 17x8.25 +35 wrapped in 225/45. Now I need some springs to lower it a touch.
04-17-2015, 12:17 PM | #8052 |
Member#: 408644
Hello 2 all , one question about wheels. What is the max wide wheel for bugeye to fit 225/40/18 tires without and mods like roll fenders to fit perfectly with no rubs?
For example 18x8 ET35 (I had those and I think It can be wider) |
04-22-2015, 02:35 PM | #8053 |
Member#: 374639
527's 17.9.75 offset 25mill Chromium black MISSED MY DELIVERY YESTERDAY! Want to get them powder coated Neo Chrome...once they scuff a bit maybe... My real concern is the Fact im going to need Bigger & Wider mud flaps lol'z 2002 wrx sedan in that PSM color.
04-26-2015, 02:18 PM | #8054 |
Member#: 402115
SWIC
Vehicle:2012 WRX hatch WRB |
Got some 527s. 17x9.75. Stock height still. Need some suggestions on suspension. Probably won't do coils but will do springs and Koni yellows.
04-29-2015, 06:00 PM | #8055 |
Member#: 374639
Without Coil overs my friend you will suffer of what i call the Pappi syndrom lol no offense to our hispanic fellow tuners, but the poke looks extremly akward. Also try to not go lower then 35sidewall it makes the wheel look EXTREMELY small ill post pictures later tonight for ya
04-29-2015, 11:35 PM | #8056 |
Member#: 395506
Hey guys i drive a 2005 wrx lowered on raceland coilovers.
Im looking to buy a set of 531's in 18 x 9.5 +35. Would probably get a 215/40 tire. what kind of fender work and camber should i expect to make this setup fit and look right? All help is greatly appreciated! |
04-30-2015, 08:04 AM | #8057 | |
Member#: 370632
Vehicle:2013 Black Hatch STi Stasha |
but you'll most likely have to roll you rear fenders but i don't know for sure cause i havent worked on a '05 before but since youre lowered it will give you peace of mind |
05-01-2015, 04:00 PM | #8058 |
Member#: 410295
Vehicle:2015 Impreza Dark Grey Metallic |
I have a 2015 Impreza 2.0i on stock suspension height. I want wheels where I don't have to roll/stretch fenders.
Would I be able to accomplish that with XXR 527 18x8.75 et35, planning to use 235/40/18 tires???? |
05-27-2015, 11:22 AM | #8059 |
Member#: 380117
iPhone pics 4 dazeee
06-11-2015, 07:12 AM | #8060 | |
Member#: 250157
Rub or no rub, that is the question? =)
I am running 17X9/+42 with 245/40 on the same gen, but my is 2011 WRX (stock suspension) so shocks have more travel than your STI suspension. I have no rubbing at all. I drew out graphically to determine the poke between 17x9/+42 and 18x8.75/+33, they are virtually the same. You have 18in wheels so they are 0.5in closer to your wheel wells compared to my 17s. Do you think that extra 0.5in is what causing you to rub??? (I am assuming you are still on stock suspension from your pics where I don't see any lowering). How much of a gap do you have between the edge of front and rear fender until they touch the Pilot SS tires?
Would appreciate your help to determine if I need to roll fenders and dial more negative camber on stock suspension. If I do, I might as well purchase coilovers if I have to go to alignment shop to fix the camber. Quote:
06-12-2015, 06:53 AM | #8061 |
Member#: 340470
Vehicle:2017 WRX Limited Crystal White Pearl |
This thread has 162 pages. So wondering if 531 18x9.5 +35 will work on stock 04 STi suspension, clear the Brembos, and not need any roll out modification?
Got a chance to get some for free. |
06-12-2015, 08:59 AM | #8062 | |
Member#: 370632
I havent experienced any rub in the front because the suspension is higher than the rear, and the rear has a much worst lip. I've only experienced rub in extreme conditions i.e. 4 passengers and doing stupid things on back country mountain roads in west virginia Is that setup on your car now or are you going to be putting it on soon? I don't think you will need coilovers, If you havent put this setup on your car yet then i would suggest putting them on, and do some tight mid speed corners in a parking lot and listen for rub. If you have rub then a fender roll will get rid of it better than coilovers. I know youre gonna want to eliminate some wheel gap when you go to coilovers (youre not gonna lift your car afterall) and that would exacerbate the problem. Good luck sir! |
06-15-2015, 05:06 PM | #8063 |
Member#: 337830
06-18-2015, 01:29 AM | #8064 |
Member#: 397721
Hey, everyone! So I've been looking through this thread FOREVER and I've searched and searched and searched EVERYWHERE for information on the XXR 552s and XXR 969s. I haven't seen anyone rocking these wheels anywhere and I'm really curious to know if anyone on here has these or has seen these wheels before. The 552s are similar to the Enkei RPF1s and the 969s are similar to the Work Emotion CR KAIs. Can anyone help me out with this please? Pictures and input is appreciated!
PS: I'm looking at the XXR 552s mainly in the size of 18x8.5 +36 offset with a tire size of maybe 225/40/18. |
06-18-2015, 03:53 PM | #8065 |
Member#: 165300
SWIC
Vehicle:2006 WRX Steel Gray Met. |
that is because they just came out...
06-18-2015, 05:22 PM | #8066 |
Member#: 397721
I know. But they've been out for a minute though it seemed. However, despite that. I still haven't seen any "real" images of the wheels in natural light. Only images I've found were the display images on the website. It's hard to tell what some of these wheels look like when they have a white backdrop behind them. Haha
06-18-2015, 05:28 PM | #8067 |
Member#: 165300
SWIC
Im looking too. I was interested n the 552s 18x10 +25
06-18-2015, 05:51 PM | #8068 |
Member#: 397721
Yeah, I like them. They look aggressive, clean, and attention grabbing, but not too flashy. I was looking at 18x8.5 +36 offset. Do you think I'd have to do any fender modifications? I have coilovers but haven't installed them yet because I want to put everything on all at once.
My car is a 2005 WRX. |
06-18-2015, 10:57 PM | #8069 | |
Member#: 421831
06-19-2015, 06:07 AM | #8070 |
Member#: 397721
Ah, yes!!! Thanks a lot! Just what I was looking for. Looks great! I'm tied between these XXR 969s and the 552s. Those 969s look nice!
06-19-2015, 12:42 PM | #8071 |
Member#: 421831
06-19-2015, 01:11 PM | #8072 |
Member#: 165300
SWIC
06-19-2015, 01:36 PM | #8073 |
Member#: 421831
06-19-2015, 04:08 PM | #8074 | |
Member#: 423904
06-24-2015, 09:06 PM | #8075 | |
Member#: 307041
BAIC
Vehicle:2002 impreza wrx psm |
Can i get some help to please? I just got a set of xxr 527's in 17x9.75 +20 and trying to get some tires and not sure of the size to get? I got a 02 wrx sedan stock height right now will lower though would like to just toss some tires on and some springs to be able to use the wheels if possible. I got the wheels as a trade so that is why i have that size i did not purchase the size just trying to get some use out of the wheels or is it best to sell or trade for another size/set etc thanks |
Enough of teh Sex threads! | Remy E. LeBeau | Off-Topic | 18 | 08-19-2013 07:47 PM |
teh burn thread | Samuelleeogden | Off-Topic | 13 | 09-06-2005 08:28 PM |
Teh Welcoming Thread.. | PwNeD | Texas Impreza Club Forum -- TXIC | 7 | 10-06-2004 10:42 AM |
