07-12-2010, 04:44 PM | #1 |
Member#: 120219
Gillman Subaru The Big Event 2: Shop Day Registration and info
The Biggest Big Event! You don't want to miss this one!
The shop will be open at 8am on August 21st. There is so much going on on August 21st we can't list it all here, see the Big Event thread for info on the other stuff happening that day. Main "Gillman Big Event 2" Thread here: http://forums.nasioc.com/forums/show....php?t=2020491 If you want to bring your car in and work on it post here so I can add your name to the list. Please give the following information: 1. Name and user-name on forum 2. Car year and model 3. Work to be done - There will be a required $20 payment to Gillman for using their bays. With this fee you will get two bands and one t-shirt. One band is for you and one for a passenger. - If you are going to be in the shop you are required to have a band. - If you are not working on a car, but want to be in the shop you will need to pay $5 for a band. - No one under 13 will be allowed in the shop area. - We are doing this to keep the shop area a little less congested for everyone's safety. - No open toed shoes, flip flops, or sandals. - There is a 2 hour maximum per car per shop bay. If you run over the 2 hour maximum, you will be charged an additional $20, plan your time accordingly. - The money collected for working on your car, and entry into the shop will help to offset the additional required safety equipment, and other needs for the day. If you have questions please let me know and I will answer them to the best of my extent. With each arm band you will get a raffle ticket and be entered to win some really cool Subaru prizes! Also please tip the techs for their time, they are coming in on a day off and are not getting paid for this. As a guide for what you should expect to be able to do at the shop day, things such as downpipe, springs, swaybars, turboback, basic services, interior stuff, shifter bushings, CV joints/boots (we did a few of these last time) should be things you plan on doing at the shop day. Obviously other jobs can be done too, but expect to run over the allotted 2 hours and have to pay the additional $20 for 2 more hours. If anyone has any questions on how much money you should be prepared to tip for the help of the technicians, please feel free to ask! There will be 20% off parts and Subaru merchandise for this event! Just contact the parts department for help. Come on out and have some fun, work on your car and meet some of your fellow Subaru enthusiasts!!!!! I can almost promise you that The Big Event 2 will be the biggest event yet, and you won't want to miss it! Thanks, Sam (samagon) I LOVE POOP Last edited by Gillman Subaru; 07-13-2010 at 05:47 PM. |
07-12-2010, 04:44 PM | #2 |
Member#: 26859
TXIC
Vehicle:of TXIC I also like (oYo)!!!! |
All, please try to be specific about what you plan to do as we would like to be as prepared as possible in the shop.
Additionally, some of the things you may want to do will be too difficult to accomplish at the shop day, lower control arms, clutch swap, rear main seal, these are examples of things that are going to be too difficult to accomplish, so it will be good to know what you want to do so that we can let you know ahead of time that this may be more than we can tackle at the shop day. thanks very much for your understanding! See the first post for a list of things that are good ideas for the shop day, I've just talked to Amir and he says that timing belts should be okay, but keep in mind that if you run over the 2 hour limit, it will be another $20. and remember the alignment rack is also available, and Ding Lifters will be on site as well! List of Shop Day Entrants: 1. Mary - AWD Tuning Legacy GT? Stuff? 2. TurdFerguson WRX air sucking valve 3. Tom, taco_tom 2004 Sti Stuff? 4. Daniel, CRAZYFOOL999 2007 WRX Oil Change, tranny and coolant flush, maybe alignment? 5. Kauve - KauvSTi 2007 STi Sway Bars, springs maybe Downpipe? 6. Emilio - omnithreat 2008 WRX Oil Change, Air Filter, Rear Diff Fluid, Transaxle Fluid 7. Vince V - iconone 2005 wrx alignment and brake check. 8. John Paul - jp102895 2005 WRX Valve Cover Gaskets replacement and oil cooler seal replacement. 9. dzywrx 2004 WRX Engine and Trans Mounts. 10. Tharun - Brownboy 2005 Subaru Legacy Fluids/Belts 11. Tuan - WRXTuan 2004 Subarx WRX Replace busted CV b00t... probably something else, like using the restroom. 12. Brian - Spacepope 2004 WRX stainless brake lines, brake fluid, gear oil 13. Omar aka slOwmar - sr20dehauler - (I might need about 3 hours) 2005 Forester XT Front control arm bushings (2 hours tops -alignment), tranny/front/rear diff fluids, brake flush, alignment 14. Nancy - Frogspitt 2008 STI Brake pads/rotors and maybe CBE 15. J Phillips - Tex-WReX 08 sti Alignment 16. Jon - madspecvman 2004 sti ss brakes and fluid flush; tranny and rear diff fluid; steering rack bushing; spark plugs; maybe front wheel bearings 17. Othniel - Letum001 2005 sti springs installed 18. Donald-donnie25 2005 wrx radiator flush and filll; tranny drain and fill; all differentials drain and fill; both front axel replaced 19. Luis Martinez (real and Forun Name) Impreza WRX 2009 Replace Spark Plugs; Replace Brake Fluid and Inspection lines 20. glilly / Greg Lilly 08 STI Cobb Heat shield & add negative camber to front. ...ohh, and maybe my 2nd oil change. 21. Butterz / Marshall 2008 Legacy GT 30k mile service and maybe spring/swaybar install 22. Ericsson - Juan 2008 STI 30k mile service or as much as possible 23. Armani - euclideanbell 2008 WRX SEDAN Alignment check, Possible tire balance?? 24. Stephen Duering/ PearlandSTi 2010 STi Cobb downpipe and heat shield 25. Gonzo_TFTD 2005 FXT Timing Belt 26. TJ Tran - junkb0y Impreza WRX Wagon 2007 Install catback exhaust 27. Stephen Proctor 2007 STI Downpipe 28. Jamil-Jamil7 97 Impreza Motor and tranny oil change and coolant flush 29. Victor - Vlenhoff 2010 WRX Re-grease sway bars, Trouble shoot Fog lamps, activate shock sensor 30. Brian - Blitzkrieg 2003 WRX Change tranny fluids, flush radiator and a few radiator hoses, one running to the turbo is spongy and melting. 31. Tom (T-dub) '07 WRX Could i do my 60k mile service (w/ techs help)? I've been told it takes about 4 hours. Hell if I could just get the spark plugs replaced I'd be happy. 32. Shawn (shawns_sick_STi) 04 STi check for bent front right suspension pieces and trouble shoot EDFC. 33. skuby 02 WRX Alignment Last edited by samagon; 08-18-2010 at 05:12 PM. |
07-13-2010, 10:48 AM | #3 |
Member#: 123142
TXIC
Vehicle:2011 Subaru STi Satin White Pearl |
07-12-2010, 05:20 PM | #4 |
Member#: 183645
TXIC
Vehicle:2007 STi & 09 SpecB www.awdtuning.com |
CAN'T WAIT! I just got off the phone with Scott about getting more goodies to hand out. Anything else that we can do, just let us know!
Not sure yet what we'll be doing yet, but I'm sure we'll find something to work on, so please go a head and put us down for a spot. 1. AWDTuning 2. TBD j/k (I'll just have to remember to find our shoes and pack them up before we head to Houston) ~Mary |
07-12-2010, 06:12 PM | #5 |
Member#: 123142
TXIC
I'll be there. I will be in the shop too. Just don't know what I'm doing yet either.
07-12-2010, 10:37 PM | #6 |
Member#: 88254
TXIC
I really need a clutch put on my wife's 02 wrx. Would the techs be helping me if I sign up or do I need to ask someone on the forum? I have no problem tipping, I just need the job done right. Im sure its much easier with the car on a lift opposed to in my garage. Any help would be greatly appreciated
07-12-2010, 10:47 PM | #7 |
Member#: 82323
TXIC
Vehicle:I'm a lead farmer, mother****er! |
I'm just curious, but why are there three threads, including two which are exactly the same?
07-12-2010, 10:49 PM | #8 |
Member#: 235609
TXIC
Vehicle:2008 Stg 2 STi Blue |
07-12-2010, 10:53 PM | #9 |
Member#: 82323
TXIC
And that can't be done in one thread? Considering that over three quarters of the information in the two threads are identical? So go yourself there, jackwad.
07-12-2010, 11:15 PM | #10 | |
Magic 8 ball says Ban
Moderator Member#: 7245
TXIC
Vehicle:20 Gladiator 22 Bronco |
The main thread is general information and discussion. The car show thread is just that, the shop day thread is, ...see where this is going? |
07-12-2010, 11:49 PM | #11 |
Member#: 82323
TXIC
Oh, I get it. I'm just looking at the content of the threads and wondering why they're so repetitive. Because they are.
07-13-2010, 04:59 PM | #12 | |
Member#: 26859
TXIC
07-13-2010, 11:36 AM | #13 |
Member#: 125498
TXIC
Vehicle:2004 WRX STi Java Black |
I want some of this,
-Tom, taco_tom -2004 Sti -Stuff |
07-13-2010, 11:40 AM | #14 |
Member#: 76565
International
Vehicle:CLXX Stricta Parata Neci! |
I'm there to help whoever needs it. I'm broke and have no money to do work! LOL
07-13-2010, 12:51 PM | #15 |
Member#: 120546
TXIC
Vehicle:2007 WRX TR Rudolph the Red Nose |
-Daniel - CRAZYFOOL999
-2007 WRX -Oil Change, tranny and coolant flush |
07-13-2010, 04:06 PM | #16 |
Member#: 235128
TXIC
Vehicle:W211 E55 |
- Kauve - KauvSTi
- 2007 STi - Sway Bars & Downpipe |
07-13-2010, 05:26 PM | #17 |
Member#: 145747
TXIC
Vehicle:2011 Mazda Double with Cheese |
I have an idea of something I need to do, but I need to figure out if it'll be feasible for shop day and if I'll have the funds for it right now.
07-13-2010, 05:33 PM | #18 |
Member#: 26859
TXIC
downpipe, springs, swaybars, turboback, basic services, interior stuff, shifter bushings, CV joints/boots (we did a few of these last time), things of that nature are what you want to try to do on the shop day. If you have an older wagon, you can do the roof rail delete in under 2 hours.
07-14-2010, 09:42 AM | #19 | |
Member#: 145747
TXIC
07-14-2010, 09:49 PM | #20 | |
Member#: 26859
TXIC
07-13-2010, 05:28 PM | #21 |
Member#: 163635
TXIC
Vehicle:2008 Impreza WRX Texas Fire Car |
-Emilio
-2008 WRX -Oil Change, Air Filter, Rear Diff Fluid, Transaxle Fluid |
07-13-2010, 05:32 PM | #22 |
Member#: 88254
TXIC
dang, im still gonna show up on shop day even though I apparently can't get my clutch changed, possibly put my sti in the show. Can anyone help me with this on a dif day?
07-13-2010, 07:12 PM | #23 |
Member#: 123142
TXIC
Lol @ Sam with my 'air sucking valve'
07-13-2010, 08:04 PM | #24 |
Member#: 174252
TXIC
Vehicle:2014 BRZ SWP |
lol.. crap.. I want sways now..
07-14-2010, 11:48 AM | #25 |
Member#: 174883
TXIC
Vehicle:135i 05 CGM WRX 2006 Yamaha R1 |
I hope I can get a alignment this time.
Vince V - iconone 2005 wrx alignment and brake check. |
Similar Threads | ||||
Gillman Subaru presents: The BIG EVENT 2 with Dave Mirra - August 21, 2010 | Gillman Subaru | Texas Impreza Club Forum -- TXIC | 235 | 08-28-2010 11:26 PM |
The Big Event - Shop Day Pre-Registration Thread | Turd Ferguson | Texas Impreza Club Forum -- TXIC | 130 | 02-05-2008 12:33 AM |
Is everyone at the Big Event going to be drinking Snapple all day? | AliBenn | Texas Impreza Club Forum -- TXIC | 17 | 02-04-2008 05:18 PM |
The Big Event - Car Show Pre-Registration Thread | glilly | Texas Impreza Club Forum -- TXIC | 91 | 02-02-2008 07:41 AM |
