12-06-2012, 02:09 AM | #1 |
Member#: 337170
Vehicle:2003 wrx silver |
arp, seriously?!
I was planning on fitting my engine with ARP studs and main bolts till I found out they would cost me $600 combined! that is insane for bolts! are there other routes I can take or should I stick at stock? I ordered Manley forged pistons and eagle H beam rods so it will handle abuse of 450+ whp but I plan to achieve only 350. ideas?
12-06-2012, 02:39 AM | #2 |
Member#: 111048
Vehicle:I <3 debt |
why do you need main bolts?
12-06-2012, 03:39 AM | #3 |
Member#: 337170
12-06-2012, 03:42 AM | #4 |
Member#: 97135
12-06-2012, 03:51 AM | #5 |
Member#: 339830
International
Vehicle:2007 Forester |
better is pay for good parts for motor build than for refurbish engine..
12-06-2012, 03:53 AM | #6 | |
Member#: 111048
Vehicle:I <3 debt |
no offense. add to the price of those bolts a nice line hone and that'll put ya well over a grand for just those 2 parts. |
12-06-2012, 04:14 AM | #7 | |
Member#: 337170
12-06-2012, 04:34 AM | #8 |
Member#: 230719
Vehicle:2005 Sti Andrewtech & TurboXS FTW |
Do it right the the first time.
I did ARP case bolts, head studs, and rod bolts |
12-06-2012, 04:40 AM | #9 |
Member#: 337170
what was the total? I got my pricing from JSC. I'll have to bite my lip and pay up it looks like! I don't want to have problems later down the road especially since these motors can't be worked on while in the car
12-06-2012, 05:37 AM | #10 |
Member#: 309599
Vehicle:2006 WRX STi CGM |
Shoot me a PM with what you need and maybe I can help you out. A motor build is extensive and a large investment. Rule of thumb, be READY to pay the double amount of your budget if stuff requires attention/replacement right away. It can get costly quick.
12-06-2012, 06:39 AM | #11 |
Medium Frank
Moderator Member#: 140114
Vehicle:2020 Subaru Outback |
At 350 whp you don't need ARP anything.
12-06-2012, 11:41 AM | #12 |
Member#: 255776
Vehicle:2010 LR WRX MPS powered. |
I didn't get ARP case bolts for my motor, I stuck with stock for that, but I did go with ARP H11's for my studs.
12-06-2012, 02:52 PM | #13 |
Member#: 337170
that's what I was thinking. it's getting a 20g turbo and a big tmic with EQL headers. besides that, I have invidia turbo back, aps 65mm intake pulling from the fender, and 1,000cc injectors. although arp would be a great piece of mind! I'll more than likely do it.
12-06-2012, 03:28 PM | #14 |
Member#: 255776
Dom told me I didn't need ARP head studs, but I wanted the peace of mind as well. Just do them if you can afford it. It'll keep your mind at ease.
12-06-2012, 03:48 PM | #15 |
Newbie Moderator
Moderator Member#: 91347
Vehicle:2004 Tacoma Crew Cab 2012 Triumph 1050 |
Do some research in the "Built Motor"
I think you'll find that your stock block is fine. Doesn't sound like you're changing any internals. |
12-06-2012, 03:51 PM | #16 |
Member#: 300551
SCIC
Vehicle:2002 FOZ STI 2.34 Fullers Garage |
12-06-2012, 03:55 PM | #17 | |
Member#: 300551
SCIC
Add meth, stroker and it looks like my build. I just used arp head and rod bolts. We are along ways from needing block bolts. Last edited by mod maniac; 12-06-2012 at 07:17 PM. |
12-06-2012, 03:55 PM | #18 |
Member#: 255776
Dom and I briefly spoke about them and he said that the regular ARP studs aren't much better (if at all) than the stock bolts. I don't think he would have let me spend money on the regular ARP studs He's a good dude. Puts up with a metric **** ton of questions from me...
12-06-2012, 03:57 PM | #19 |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
12-06-2012, 03:58 PM | #20 | |
Medium Frank
12-06-2012, 04:13 PM | #21 |
Member#: 255776
I'm guessing 08+ WRX and he's worried about the stock tranny so he's going to keep it around 350.
12-06-2012, 04:44 PM | #22 |
Member#: 337170
here's my story, slipped a rod bearing and limped home. luckily I was a mere 1/2 mile from home. it's my 03 wrx and I want to build it to be fast but still last 100,000-150,000 miles. trying to save the tranny so I'm gonna stick with the stock clutch. the plan is to put the H beam rods and forged pistons in, stock cams, oem gaskets, get the crank, flywheel, and pressure plate balanced, and BC valves. 3 months after I finish the motor I'll add the 20g turbo and gt spec equal length headers. an intake manifold MAY be in the list but not for sure. gonna stick with TMIC. I already have the invidia turbo back, 1,000cc injectors, and the APS 65mm cold air. it should be capable of 420+ but I'm hoping to maybe run low boost and sit around 350.
12-06-2012, 04:48 PM | #23 |
Member#: 255776
Well, at 350whp with your tranny, I'd be worried. At 420whp... good luck.
12-06-2012, 05:02 PM | #24 |
Medium Frank
He can write a long post, but not fill out his profile.
And you can upgrade your clutch while the motor is out. Plus the whole "glass transmission" argument is about as dumb as all the ringland arguments. |
12-06-2012, 06:01 PM | #25 | |
Member#: 337170
edit: just used safari and went to the full site and updated everything! I<3 iPhone Last edited by rushdylan; 12-06-2012 at 06:10 PM. |
