03-01-2010, 10:33 PM | #1 |
Member#: 214872
South East
Vehicle:04 Sti WRB |
Another Hella 500 question thread OH YEAH!!!
I made some mounts, wired up, and intstalled my hellas today. Aaaannd no light.
I grounded the switch, relay, both lights; connected the hellas, ran that black wire back to the relay, ran the yellow wire to the switch, ran the red wire to the battery, and left off the green wire that the directions say to run from the high beams to the relay because of what I've read on the multiple hella threads about subaru wiring. If anyone can help I would greatly appreciate it.
03-01-2010, 10:39 PM | #2 |
Member#: 239594
i have the hella 500's on my 02 wrx..all i did was use the factory connector for the factory fog lights.
03-01-2010, 11:31 PM | #3 |
Member#: 214872
South East
Sounds alot easier, but I'd like to have them completely independent of my other lights
03-01-2010, 11:46 PM | #4 |
Member#: 139853
Vehicle:2002 wrx....its tsxy silver |
so.....what keyed source, if not highs, are you using to complete everything. If you use a relay, you need to tap onto the lights, or some other keyed on source....or some other constant 12v if you want them on whenever
03-01-2010, 11:51 PM | #5 |
Member#: 193528
Vehicle:1997 V8 Tomei Swap Coat of many colors |
03-02-2010, 12:02 AM | #6 |
Member#: 55252
SCIC
Vehicle:* pullup bar * |
there's gotta be a supply source.. which is kind of like a remote line.. whenever the source you tap from is on, the lights can turn on.. if it's not on, then the lights won't
for instance, i have my stuff sourced from my amp.. so when my stereo is on, the lights can turn on.. so even if my car is on but my stereo is not, my lights won't turn on hope that's clear lol |
03-02-2010, 12:36 AM | #7 | |
Member#: 214872
South East
03-02-2010, 04:27 PM | #8 |
Member#: 214872
South East
OK Couldn't find that green wire with the plastic connector in it that was supposed to go to the high beams, but I had another piece of wire laying around and I ran it from the switch, to the stereo power wire. Nothing. Not even a hint of lights. Yes the stereo was on, I flipped the switch several times. What I've got: Both lights, relay, and switch grounded; red wire from relay to battery; black wire from relay to both lights; yellow wire from relay to switch; green wire from switch to stereo power. NO LIGHTS. I've looked at the Diagram and other than substituting stereo power for the high beams, I can't see anything I did wrong.... ????
03-02-2010, 04:32 PM | #9 |
Member#: 55252
SCIC
you followed VVV diagram??
03-02-2010, 04:39 PM | #10 |
Member#: 214872
South East
No I followed this one:
What I did different from your picture was wiring to the stereo power wire instead of the high beams, and I grounded the relay instead of wiring to the negative terminal of the battery. But the diagram I have says to ground the relay. |
03-02-2010, 05:24 PM | #11 |
Member#: 55252
SCIC
wow the one you got looks more complicated, i can barely make out what some of that stuff is lol
anyway, there's only 4 wires off the relay.. 2 are for the battery, one is for the power to go into the lights, and the last is the source maybe if you put the wire that'd be in the neg terminal there, it'd work coz the lights already have wires coming together to ground to the chassis |
03-02-2010, 09:43 PM | #12 |
Member#: 214872
South East
what do you mean by the wire that would be in the negative terminal? you mean connect the ground wire for the relay to the negative battery?
03-02-2010, 10:15 PM | #13 |
Member#: 55252
SCIC
the one where you said you grounded it instead of putting it in the battery neg.. perhaps it'd work if you'd put it in the battery neg coz the lights already have a ground
basically what i'm saying is have it exactly the way it shows in my diagram aside from the supply source and that should work as that's how i have mine wired |
03-03-2010, 08:41 PM | #14 |
Member#: 214872
South East
Update: First, I'm an idiot. I found that I had wired the relay to the antenna rather than the power for the stereo. Well I left the relay grounded after I found that out and corrected it. I noticed the relay clicking when I flipped the switch on and off, but no lights. Then I did what you said. I ran the ground for the relay to the negative terminal of the battery. Same thing, relay click, no lights, BUT now my switch is lit up, except in the "on" position, even with the key out of the ignition. So I'm getting somewhere, but still no light. And yes, I'm still going crazy haha
03-03-2010, 09:10 PM | #15 |
Member#: 230019
Vehicle:2006 Legacy GT Spec silver |
wow your having some issues, i just wired up my hellas today and followed their instructions which i see is a few post up, just follow that, seriously. what i did instead of using the supplied chip to take a signal wire from the head light i used a fuse tap and taped in to the headlights fuse in the engine bay fuse block, so whenever they are on i can turn my fogs on. i didnt ground to the battery, either. i just used ground points that were already used on the car. i guess make sure your grounds are good at this point.
03-03-2010, 09:21 PM | #16 | |
Member#: 214872
South East
03-04-2010, 03:10 PM | #17 |
Member#: 214872
South East
And it all boiled down to a bad fuse
03-04-2010, 06:06 PM | #18 |
Member#: 230019
awsome you found it!!
03-04-2010, 06:57 PM | #19 |
Member#: 55252
SCIC
glad you got it=)
03-05-2010, 04:05 PM | #20 |
Member#: 214872
South East
Thanks guys... now where's that dunce hat... i have a corner to go sit in
Another Hella 500 install question. | OUScooby | Electrical & Lighting | 18 | 02-06-2010 01:32 AM |
Another Hella 500 question for the experts | Type1 | Electrical & Lighting | 3 | 01-11-2006 04:57 PM |
Another Hella wiring question | brunetmj | Electrical & Lighting | 5 | 01-12-2005 08:17 PM |
Hella 500 questions?? Wiring?? | k2snow | North West Impreza Club Forum -- NWIC | 2 | 01-21-2004 05:34 PM |
Hella 500 question | stayfido | Electrical & Lighting | 12 | 08-23-2003 02:57 AM |
