09-08-2006, 11:15 PM | #1 |
Member#: 95259
How to disable daytime driving lights?
I recently had an HID conversion kit installed in my Tribeca. The lights look great when they're turned on. However, in daytime driving mode not enough current is being supplied to the lights. As a result you get a strobing effect. Does anyone know how to bypass the daytime driving lights?
10-03-2006, 09:07 AM | #2 |
Member#: 124994
Without doing any rsearch, I can say that the DRL have a switch connected at the e-brake. I imagined that if you were to disconnect that switch you may be able to bypass it. Try it an dlet me know how it worked?
06-23-2008, 12:35 PM | #3 |
Member#: 25159
Vehicle:2015 BrAkes stop you BrEAks make you broken |
Does anyone have any further info on disabling the DRL?
I had the dealership disable them but now the brights or parking lights don't work. |
06-30-2008, 04:23 PM | #4 |
Member#: 103713
Subaru, for some reason has wired the DRL so they are near impossible to disable. I had a Saturn (pull a fuse) and now a Santa Fe (pull a fuse) and had no problems.
An Outback I had would not do it (or I would have put it on my web site) nor would the Tribaca. It's my wife's car, so it doesn't bother her. But automatic headlights. $30K and you have to manually turn on lights. A crappy $15K Ford has auto headlights, so do all Hundia cars. Just don't try SilverStars. They burn out in 3 - 6 months due to these DRLs. You'd think someone would come out with an adaptor that's wired to the battery. Under 10 volts, they stay off. Over 11 volt, it pulls current from the battery wire. |
06-30-2008, 04:26 PM | #5 |
Member#: 25159
07-04-2008, 11:34 AM | #6 |
Member#: 103713
My Hunida Santa Fe has auto headlights, you can just turn them off. Not sure why Subaru still has manual light and no easy way to disable DRL. I have driven way too many times at night with just the DRL on !
11-13-2008, 04:27 PM | #7 |
Member#: 22146
Vehicle:2012 Acura TSX wagon WRB |
Has anybody tried the DRL off methods used on the 05-06 Legacy? --> http://legacygt.com/forums/showthread.php?t=2117
I don't know why it doesn't work on 07+ Legacy, so maybe no luck with Tribeca either. Wouldn't hurt to look for it. I did it on my 05 Legacy I had in no time. |
11-13-2008, 06:24 PM | #8 | |
Member#: 25159
It really, really bothers me that I can't turn my headlights off. |
11-14-2008, 09:15 PM | #9 |
Member#: 22146
That really stinks. I'm with you on wanting to turn them off.
11-18-2008, 12:11 AM | #10 |
Member#: 194617
Would love to turn ours off as well. Prior to finding this and other forums, I'd searched pretty extensively on the web without any luck.
11-18-2008, 08:35 AM | #11 |
Member#: 25159
Everyone should call/email SOA and ask for instructions on what to do if they need to turn off the headlights.
I did this and SOA told me to depress the parking brake one click. I pointed out that to now release the parking brake I have to depress the p-brake pedal all the way and that didn't seem like a good idea whilst driving. |
03-23-2011, 12:23 AM | #12 |
Member#: 260427
Anyone have success with this yet?
03-23-2011, 09:23 AM | #13 |
Member#: 127558
I use the 1 click method in my 06 and don't have any problems with releasing it just by going down another click. I did find a wiring diagram showing where I can cut the DRL wire, but haven't done it yet. I'll probably wire in a switch when I do though.
KuoH |
03-23-2011, 09:38 AM | #14 |
Member#: 25159
I've had HIDs installed (Apexcone/DDM lifetime warranty) since I posted this and I just leave the headlight switch in the "on" position all the time and have had zero issues.
I had the center console opened up to install the XM module but I didn't see the DRL module in there so it either looks different than I thought it should or it's really buried deep. |
03-23-2011, 09:49 AM | #15 |
Member#: 215454
Vehicle:2005 9-2x Aero Black |
My daytimes come on when I blow a headlamp, keeps me from getting a ticket but you know you need a new one.
This mod have any affect on that? Thanks |
04-11-2012, 09:30 PM | #16 |
Member#: 315716
Vehicle:2013 Wrx premium Plasma blue pearl |
to disable it you have to open your glove box take out all the screws then you will see a panell with plugs one of them is the driving lights pull it out and your done
04-11-2012, 09:47 PM | #17 | |
Member#: 25159
I really hope it's this simple. :fingers crossed: |
04-12-2012, 12:11 PM | #18 |
Member#: 315716
i found a diy thread i am going to be doing it to my car sunday so i will research it and get back to ya what year and model is your car because i know this works with the 06 and 07 impreza's
04-12-2012, 12:15 PM | #19 |
Member#: 315716
http://www.wrxtuners.com/forums/f93/...ts-06-a-10234/
that tells u how to do it u can take out your glove box or if your can fit u can just look under the glove box |
Similar Threads | ||||
HOW TO: Disable Daytime Running Lights on '06 | DECALFX | Newbies & FAQs | 311 | 05-31-2012 08:46 PM |
How to disable Daytime Running Light in 2007 Impreza | wlit | Electrical & Lighting | 3 | 04-01-2010 09:40 PM |
HELP...need to disable daytime running lights on my 06 legacy | Anamagous | North West Impreza Club Forum -- NWIC | 5 | 08-17-2009 12:51 PM |
Show me how to disable daytime running lights. | sc00bywagon | Electrical & Lighting | 6 | 07-31-2005 08:37 PM |
how to disable daytime running lights in WRX? | christurismohk | WRX Forum Archive | 21 | 01-26-2001 09:03 AM |
