10-16-2013, 09:02 AM | #1 |
Member#: 303384
Vehicle:04 Impreza WRX Silver |
Tactrix openport 2.0
so just got my openport 2.0 and reflash adaptor for my 04 wagon. I am dissapointed that it is without any user interface manual, steps to reflash or just read the ecu map etc. so im now on the hunt for other tactrix usrs. and perhaps a light mod stock reflash. ie catback and snorkus delete.
10-16-2013, 12:51 PM | #2 | |
Member#: 197384
NESIC
Vehicle:2006 WRX Ltd OBP |
You're looking for a stage one map. |
10-16-2013, 01:00 PM | #3 |
Member#: 303384
Thanks, yeah I have been on there all day, though I cant find a search option. I have found a stock map retune with no mods(as in bone stock) and the closest map is a stage 2 with a turbo-back and stock everything else. I however only have a catback. So I believe I will take the stock map and use to "tweek" until I get a good result for having a catback set up. Im getting ready to go save my OEM map though. lots of reading and research on this.
10-16-2013, 02:17 PM | #4 | |
Member#: 51961
RMIC
Vehicle:2005 STi 2012 WRX |
10-16-2013, 03:39 PM | #5 |
Member#: 303384
So either the Stock reflash tune or the Stage 2 reflash would be ok? the only change I see that is made is some light timing and boost absolute changes. the stage 2 one goes to a 2.1 Bar absolute. Im almost sure the stock turbo cannot even produce boost that high nor would the stock WGA hold it. but I plan to test the "stock" reflash tonight or this weekend. I want to get a real good understanding of it by spring when I upgrade my stock turbo and get a full exhaust.
10-16-2013, 04:35 PM | #6 | |
Member#: 194062
MAIC
Vehicle:2003 Impreza WRX PSM |
10-16-2013, 01:00 PM | #7 |
Member#: 332644
SCIC
Vehicle:07 STI It's white |
http://www.romraider.com/forum/viewf...1dd9aec20993c1
There are a lot of opensource people on here. I recently switched to opensource and honestly wouldn't go back. It takes some getting used to but if you read and experiment you will know more about your car and why it works then with other tuning systems. |
10-16-2013, 02:39 PM | #8 |
Member#: 99442
International
Vehicle:2006 SGM STI I'm on CORN YO! |
the company that makes the cable doesn't make all the interface software. It's your job to figure out how you are using the cable. It's used for TONS of other interfaces besides OS tuning....
10-16-2013, 04:34 PM | #9 |
Member#: 51961
RMIC
No, only the stock reflash tune (aka stage 1). As I said, all you have is a catback and a snorkus delete, neither of these affect the tune, so as far as the tune is concerned, you have a stock car. The only part of the turboback that shifts you from stage 1 to stage 2 is the aftermarket downpipe, which you don't have, so you're stage 1/stock.
2.1 bar absolute is only 16 psi relative, the stock turbo can easily hit that at mid-RPM. It just won't be able to carry it to redline. You need an aftermarket downpipe before you try this though, the stock downpipe is too restrictive and will raise the EGT too high if you attempt to run that boost. |
10-24-2013, 09:04 AM | #10 |
Member#: 303384
so ive been logging my new tune. How high of egt is too high? Just so i know what to lookout for.
10-16-2013, 07:54 PM | #11 |
Member#: 303384
yeah i have been looking at the maps and perameters. So when i get a chance im saving my stock map and doing the stock reflash after i see the compairison to the oem map
10-17-2013, 12:56 PM | #12 |
Member#: 262903
MWSOC
Vehicle:2003 WRX Silver |
I've got an aftermarket TMIC, up-pipe, downpipe, fuel rails, and a manual boost adjuster. Stock manifolds and stock catback. I did have STi injectors but one was clogged so I had to throw the stock ones in. Would this be a Stage 2?
10-17-2013, 09:41 PM | #13 | |
Member#: 51961
RMIC
up-pipe - Boost parameters (namely initial WGDC) may need to be modified due to the drop in restriction, similar to installing a catless downpipe on a stock tune. With an MBC though, probably nothing is required. downpipe - Puts you in stage 2 category, not much else to say fuel rails - Nothing required MBC - You should probably zero out your boost error tables, since the ECU is no longer controlling boost. You should probably consider selling the MBC and switching back to an ECU-controlled EBC though, since it will retain the low IAM boost limp mode, and it will be able to taper boost at high RPM to optimize power, something the MBC cannot do, and is actually pretty significant on a small turbo like the TD04. |
10-18-2013, 12:50 AM | #14 | |
Member#: 262903
MWSOC
So I could download a conservative stage 2 map and probably be okay to run it for awhile then right? Also, will an '02 WRX map work for an '03? Last edited by Toadz; 10-18-2013 at 01:01 AM. |
10-17-2013, 01:11 PM | #15 |
Member#: 197384
NESIC
You've got a lot of reading to do if you're doing the tune yourself. You will lose all safety features of the stock ecu using just a MBC. Not to mention part throttle full boost.
10-17-2013, 09:25 PM | #16 | |
Member#: 262903
MWSOC
I've downloaded my current map off the ECU so how can I post it to the forum so someone can take a look at it? |
10-18-2013, 09:04 AM | #17 |
Member#: 197384
NESIC
Yes you can swap all the plumbing and ebcs from your other motor over. Don't forget the restrictor pil.
I wouldn't guess on any tune being safe. You've got the tactrix, do the logging. Pretty much as long as you're not getting knock or minimal amounts ~1° of correction you should be safe. |
10-18-2013, 09:32 AM | #18 |
Member#: 262903
MWSOC
I've done some logging but I haven't been able to get a wideband yet so I've been hesitant about making any changes.
10-19-2013, 07:54 PM | #19 |
Member#: 303384
the stock flash i got is great for my stock set up. Got a boost in psi and corrected timing but also a more stable low end and idle
10-24-2013, 08:32 AM | #20 |
Member#: 303384
so after about a week with this tune im loving the way the car drives. My oem tune logs got erased by mistake. (hate the number system it uses to name files) but im fairly certain there is a slight relearn time on a flash. Going back to stock to get new logs and compair on my new tune. Anyone know or have idea how long it takes to relearn?
10-24-2013, 08:34 AM | #21 |
Member#: 303384
mainly wondering because im going to a test and tune track sat and wondering about how many runs between reflashes it might take to be *dialed in*
10-24-2013, 10:42 AM | #22 |
Member#: 51961
RMIC
Using the stock EGT sensor? I have no idea, since it's located all the way in the uppipe and has questionable accuracy to begin with. With a real EGT sensor located in a runner close to the heads, around 1600 F is generally considered the upper limit for a safe tune.
10-24-2013, 06:38 PM | #23 |
Member#: 303384
ok cause right now i avg 1200 to 1350 when i make a pull. Cruise its between 1150 and 1250 the first day on the reflash i had a log run in the 1900 range...seems questionable since max ive seen since was 14xx
10-24-2013, 06:41 PM | #24 |
Member#: 303384
i would also think that at the turbo egt wouldnt be off by more then say 200 degree. If the dp is what is causing the restriction heat build up would be there the most.
10-24-2013, 08:07 PM | #25 |
Member#: 51961
RMIC
The biggest heat drop is across the turbine. As long as the EGT sensor is located before the turbo it won't do TOO bad, but yeah it could be up to a couple hundred degrees lower than at the head just due to convective/radiative heat loss in the header/uppipe. Wrapping the header and uppipe will help.
