Brakes & Suspension Forum sponsored by The Tire Rack |
04-15-2008, 10:04 PM | #1 |
Member#: 154013
Vehicle:2012 S4 Monsoon Grey |
I accident took off the 4 bolts behind my 4 pot caliper help.
This was my first time doing brakes on a subaru and I accidently took off the 4 bolts behind the caliper and basically the caliper splits into 2 pieces. Do I need to rebuild my caliper now ? Or did I just get air into the system because my brakes are totally dead the pedal is very soft and the car does not brake. Help me out please thanks.
I tried to search numerous of times.
04-15-2008, 10:40 PM | #2 |
Member#: 31002
Vehicle:2002 WRX Blue |
You probably have air in the system. Did you see any fluid leak out? Bleed it and you should more than likely be fine. That, of course, depends on if you put it all back together correctly.
04-15-2008, 10:42 PM | #3 |
Member#: 7958
Vehicle:09 GH B+ |
if the seals/boots look fine no need to rebuild- you definitely are going to need to bleed the system though after getting the caliper back together
might be worth searching for the torque specs on the four pots calipers- I don't have them or I'd post them |
04-15-2008, 10:43 PM | #4 |
Member#: 154013
all I did was was take off the front portion of the caliper and I said oh **** wrong! and I put it back and bolted it back to the back piece. Are there seals in the middle ? I didnt see any. I went to a mechanic and he told me he has to rebuild the caliper because its leaking. I think he is bull****ting me because I didnt see any seals there where the fluid passes from one part of the caliper to the other.
04-16-2008, 09:32 AM | #5 |
Member#: 7958
Vehicle:09 GH B+ |
the seals and boots are around the pistons. try bleeding the system and see how it works
04-16-2008, 09:47 AM | #6 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
haha I did the same thing several months back. Of course I caught the mistake a bit earlier as I noticed the fluid leaking out. I did not have the caliper more than a mm apart. A quick bleed and I was on my way. Do all 4 corners though...there is no reason to skimp on the bleeding.
Make sure you clean up any brake fluid on the caliper and rotor. |
04-16-2008, 12:18 PM | #7 |
Member#: 154013
Problem solved. Bled the brakes , split the caliper cleaned her up with some alchol and reseald it. Its good now.
04-16-2008, 02:41 PM | #8 |
Member#: 7958
Vehicle:09 GH B+ |
good deal looks like you weren't the only person to do this, probably not the last- this thread should help others if they find themselves in this position
so I took off the flames and now I have a stubborn glue bead | Big_Hitter | Texas Impreza Club Forum -- TXIC | 26 | 03-31-2008 01:41 PM |
Took off the top part of my STi wing... | spntclgfnd | Interior & Exterior Modification | 78 | 03-29-2007 11:51 PM |
i took off the vacuum hoses and found this | OvrClkdPmp | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 10 | 11-25-2005 04:48 PM |
Took off the STi splitters and installed this... | wrx2k4blue | Member's Car Gallery | 18 | 07-04-2005 04:31 AM |
Rattle from WRX subaru 4 pot calipers??? HELP! | alfriedesq | Brakes, Steering & Suspension | 11 | 05-30-2001 07:26 PM |
